    Sep 2013
    Smuggler rear tyre
    Hey guys,
    Just wondering if anyone has tried fitting the new minion dhr 2.4 in the rear of a 16' smuggler? If so what was the id and ed of the rim?
    Thanks in advance
    Sep 2013
    For anyone that is interested I went ahead and bought the new 2.4 wt minion dhr. I mounted it up on a zelvy Carbon rim with an internal diameter of 30mm and external diameter of 35mm. It fits on a 16 smuggler fine with no issues.
    Still no issues? Thinking about picking this tire up for my 2016 smug. I ride in Los Angeles so mud isn't usually an issue.
    Aug 2016
    Yep I'm also running a 2.4WT DHR II on my Smuggler. Using a 27mm internal rim and works fine. Only got WT version as was all local shop had in stock. Even in mud does not get clogged up.
    I actually put the 2.5 DHF which I run on front, on the rear and it actually fits also. But very tight clearance. Would not run unless really had too.
  1. Smuggler vs Scout? Can I make a smuggler more nimble?
    By BobbyLight350z in forum Transition Bikes
    Last Post: 02-02-2016, 12:24 PM
  2. Smuggler - What rear tyre are you running? Any rub?
    By groundskeeperwilly in forum Transition Bikes
    Last Post: 01-10-2016, 02:41 AM
  3. Rear tyre choice
    By mtbfree in forum Wheels and Tires
    Last Post: 08-22-2015, 05:46 AM
  4. Smuggler rear tire thread
    By m-dub in forum Transition Bikes
    Last Post: 07-15-2015, 10:49 PM
  5. Maxxis rear tyre
    By shakeyakey in forum Nicolai
    Last Post: 09-24-2011, 09:06 AM
