Results 1 to 8 of 8
    Shock tuning or replacement shock to get Scout to be more "poppy"
    This is my 2nd season on a scout. Last fall I upgraded to the carbon version. I'm about 215 lbs naked and am on a size L. I absolutely love this bike. One of the most fun bikes I've ever owned, I feel like it fits me perfect and generally love the way it rides.
    I've always thought the Scout was a pretty playful bike. Maybe I shouldn't have done this but last weekend I traded bikes with a friend for a really fun section of rocky, DH trail in moab. Think high speed but with a good amount of chunk. His bike was an Evil The Calling. We are both around the same height and weight and run the same pedals so it made it easy to swap.
    It completely blew my mind how easy it was to get the Evil off the ground. This bike wanted to jump off of everything and air over everything. At the same time it felt like it soaked up the square edge hits just a bit better and was more composed when things got really rough. I did feel like cornering was a downgrade though, when it came time to lean the bike over it had a more "on it" instead of "in it" feeling and it felt kind of tall.
    Getting back on my Scout had me feeling like it really took a lot of work to either get the front wheel up off the ground or the whole bike in the air. I never felt this way before and always felt like the Scout was super playful but now I've got it in my head that things could be better.
    I'm running the stock RS Monarch RT3 with a couple of spacers and the recommended sag. I need to check my rebound and compression settings, not sure what exactly they are at at the moment but I think it's minimal compression and a fairly quick rebound.
    I'm wondering if:
    1) with some shock tuning I could get some of this "poppy'ness" found on the Evil?
    or
    2) are there other shocks out there that might get me there?
    Reputation: 2w4s's Avatar
    Mar 2005
    I really like my ccdb inline, you can definitely dial in more pop. Just to elaborate a better a bit more, I did one ride with the stock rtc3 before deciding it was crap, the replacement inline is much better, can run less sag but still get great tracking and pop. Hope that helps.
    Reputation: Calhoun's Avatar
    Nov 2008
    Quote Originally Posted by dfinn View Post
    I'm wondering if:
    or
    depending on how much you want to spend those are both good options.
    cheapest would be to try and tune to the Monarch. I think you could get close, and if you have access to a ShockWiz you'll get even closer.
    That said... my Scout really has benefited from upgrading the shock. I am running a Fox Float X and it has really brought to bike alive. Last year I rode the Whole Enchilada on my Scout and had a miserable time. Bike felt great up high, but the lower, chunkier part of that ride was terrible. The shock felt like it blew through the travel and got hung up on everything. Last month I took the Scout back to Moab and rode from UPS down and it was a completely different story. Pumping and popping everything, and the chunk was not an issue this time. Probably the most fun I've had on that ride.
    I also have a Fox VanRC that I sent to Push for the MX tune, that shock is even better in the chunk but it kills some of that pop. With the coil the bike feels very stable at speed and will still pop off features but not nearly as easy as the Float X.
    I've personally had issues with Cane Creek shocks in the past. I know they have since addressed a lot of the tolerance and assembly issues but it may be a while before I am confident recommending them again. The DVO looks pretty good and I have read a lot of positive reviews of both the product and the customer support.
    Of course getting the shock you have tuned by Avalanche is another option. Rockshox Monarch SSD/HSB Modifications
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
    The Fox sounds like a good option, thanks Calhoun. Do you know specifically which Float X you have? looks like they come in different tunes and possibly different air cans too? Evol?
    Nov 2008
    I bought the shock used on PB and here was the seller's description:
    Tune Info: 2017, FLOAT X, F-S, K, 3pos-Adj Evol LV, FOX, AM, 7.5, 2.0, 0.4 Spacer, CXF, RM, Climb M, Rezi CL, Orange Logo
    -cabra cadabra
    CAPTIN HARDCORE
    Reputation: crazbiker4's Avatar
    I am currently on a Scout and one thing you may want to look at is your bar height. You said the Evil popped off stuff easily and the front end came up easy as well. Also, a shorter stem will help as well.
    My bars are 35mm tall and I have 15mm of spacers under the stem. Running a 35mm long stem. If your bars are lower then you will have more weight on the front
    [B]Chillin...Riding I hopeB]
    Monkey
    Reputation: Jozz's Avatar
    Calhoun,
    Do you prefer the feel of the Fox over the Ohlins?
    bumping and old thread but it's relevant.
    I finally tried a different shock on my Scout after owning an aluminum version and a carbon version, both with the RS monarch. I never really liked that shock all that much but I guess I'm kind of lazy since it took me this long to replace it. It always felt kind of dead and lifeless, it seemed to pack up and fast chunk too. After a season on this new carbon frame the monarch was needing a rebuild, it was feeling pretty bad and losing air on a daily basis. Rather than look at getting it rebuilt I figured it was time to try something different.
    I'm currently in Whistler and I found a local ad on PB for a Fox Float X in the right size and with what looked like the right tune (C39D).
    I've got a few days of pedaling around Pemberton and Squamish and today I did a Top of the World -> Khybers and then a bunch of laps in the bike park on the jump trails. It seemed like this covered the gamut of riding conditions, at least the ones I care about.
    This shock has totally transformed this bike and brought it to life. It's so much more playful and poppy now off the little stuff but at the same time it soaks up the bigger bumps 10x better than the RS shock ever did. Previously the rear used to feel like it was just slamming around in the rough stuff and the Fox shock keeps everything composed and quiet back there. The bike park is really, really rough right now even on the jump trails. There's HUGE holes in every berm. This new setup handled it great. I really wish I had done this a while ago.
  1. Difference in "Beti" shock tuning?
    By coke in forum Yeti
    Last Post: 03-16-2017, 07:44 AM
  2. Replies: 2
    Last Post: 07-28-2015, 12:52 PM
  3. 2010 Gary Fisher Wahoo Shock Replacement G2 Frame 26"
    By ChuckD8 in forum Shocks and Suspension
    Last Post: 08-08-2014, 08:13 PM
  4. Replies: 4
    Last Post: 08-01-2014, 06:57 PM
  5. Replies: 2
    Last Post: 02-21-2014, 10:32 AM
Members who have read this thread: 14
