Page 3 of 3 FirstFirst 123
Results 101 to 128 of 128
  1. #101
    Dnn
    Dnn is offline
    Reputation: Dnn's Avatar
    Sep 2014
    Quote Originally Posted by ptd View Post
    FWIW, I'm on a Scout, never ridden a Patrol.
    I've got Fox 36 @ 150mm and a -2 degree headset.
    Coming from a 160mm bike, it does what I wanted, now 90% of the ride is better, 10% of gnarly -marginally- worse. On the 160mm it was all a bit un-fun and tame except on the 10% gnarly.
    I miss bombing the 10% gnarly, so I wish I had a carbon Patrol - ha!
    As a fun bike - great
    As a race bike - maybe miss 160mm but my personal times are comparable
    n+1
    Thats some heavy "modding" ...
    That setup would make for a 64.5 HA even more slack than the patrol.
    I can see what you're doing by making a more responsive rear with a slack setting.
    But for me I dont like the idea of changing a bike that much.
    You're absolutely correct that I should focus on the 90% of my riding, but my riding style is quite varied in the way that my group dont ride for "speed/effectiveness" at all. We seek out all the technical features and have fun on those.
    It's a tough choice, good thing I have at least a month before the 2017 models are announced and I "need" to decide
    n+1 works for some, not for me.
  2. #102
    Dec 2012
    Anybody have issues with the low BB height of the scout (330mm vs 339mm on the patrol)? I ride a Bandit, same BB height as scout and get plenty of pedal strikes and I set the sag to about 20%. Given the recommended 35% sag on the scout, I think I'd be smashing pedals all day long.
  3. #103
    Nov 2008
    Quote Originally Posted by gibsonlespaulspecial View Post
    The bb drop is only 10mm on the Scout and 15mm on the patrol. So sag wont play that much of a role here.
  4. #104
    Nov 2008
    Quote Originally Posted by lightenup View Post
    But yes, you are going to hit your crank arms on stuff
  5. #105
    Dec 2012
    The website says 20mm bb drop for the Scout, no? Most trail bikes seem to have ~15mm drop + ~25% sag. Seems like 20mm drop + 35% sag just might be too low, of course that's just me looking at the geometry table and not having trail experience with the bike. My LBS is having demo days for all their brands except Transition...
  6. #106
    At least your LBS carries them...
  7. #107
    Nov 2008
    Your correct scout 20mm drop, patrol 15mm drop.
    As for too low, yeh its a tradeoff. Being low to the ground has some nice benefits for in the bike handling department. I do agree, I hit my crank arms on things, but I'm rocking an alloy crank that is not expensive.
  8. #108
    Aug 2015
    Quote Originally Posted by Konanim View Post
    Just my 2 cents:
    I took a Scout and a Patrol together with a friend for a test ride.
    We took turns riding AM loop that includes tech uphill, some flowish descents, very tech downhill and some kickers and drops (largest drop was 5ft).
    We redid most of the sections swapping bikes to get a feel for the difference and this was excellent because we could compare back to back runs.
    Patrol:
    Climbs pretty well for a 160mm, even surprising
    Slower to change directions
    Gives a bit of a "disconnected" feel i.e you feel/react to terrain in a more muted manner
    Pumps OK
    Absorbs drops/ Landings like butter
    Scout:
    Fast and Agile
    Turn on a dime and feels a lot more planted than Patrol
    You can feel terrain (I mean this in a good way - supple not jittery, but allows you to react)
    Pumps amazing!
    Manuals and bunnyhops easily!
    Climbs easier than Patrol
    Descends quicker than Patrol (again - depends on the rider)
    Absorbs drops/ Landings well (5ft drop was fine!) but you need to be a bit more precise - less room for error
    Note: Currently riding a Kona Process 134, I ride AM with a focus on descents and occasional DH. I don't ride long rides (no more than 25k)
    Conclusion:
    I was all set to buy the Patrol but was amazed by the Scout.
    My friend (who rides another 160mm enduro bike) felt the same way.
    The Scout handles better and responds quicker and suits a more active rider. If your trails/riding is more to run over everything and hold your line, maybe Patrol is the better choice. For me, the Scout was the winner! (... and I was biased against it)
    I'm considering upgrading the fork to 150mm to give me a slightly slacker HA for descents.
    Again, reviews can only go so far and a back to back test proved this
    Good Luck!
    How does the Scout compare to the Process 134?
    Riding Washington State singletrack since 1986
  9. #109
    Sep 2004
    I'm in a bit of a quandary & need some advice. I'm currently rocking a scout & love its agileness & how playful it is. I did have a patrol beforehand & while at first I missed its extra travel I grew into the scout & sold on the patrol. I'm in the lucky position of being able to get a carbon patrol & wondered if anybody out there has rode the carbon vs alu vs scout. I've read that the carbon patrol is a lot stiffer & accelerates noticeably quicker but the geo is the same but would like any opinions from carbon patrol owners. thanks
  10. #110
    Nov 2014
    Bought a Scout 2 a couple weeks ago. I rode it back to back w/ the Patrol and really liked that bike too. You can't go wrong with either. The Scout, however, is just a bit more fun to play around on and while there are a lot of good 160mm travel bikes available, there aren't many aggressive shorter travel bikes. If I were to have a one bike stable, I'd might go with the patrol-- but I'm just going to keep my 2011 Reign X for the really intense stuff. I've actually been mostly riding with the rear shock in the locked position which makes it a fun ride for the local park.
    By the way, the Reign X has a low BB as well, so I was prepared for lots of banging against the BB and pedal strikes, but it's actually slightly better, probably because the rear isn't so squishy. That and it's a heck of a lot easier to just hop over big roots instead of having to run over them.
  11. #111
    Jun 2015
    Hey everyone, this thread has been amazingly helpful. I'm reaaaaaaally hoping to upgrade to a Scout from my 2012 SC Heckler this fall or next spring/summer. I'm wondering what are the best online retailers to buy from? A quick Google search shows wrench science and evo. I've never ordered anything through either so I'm not sure if either is any good. Are there others as well? I think the closest LBS to me is about an hour away that only carries a limited amount of transition bikes. Plus, I'm a bit of a hermit so I prefer to buy online anyways. 👍
    I'm in wesrtern Colorado if that helps. I'd appreciate any advice, thanks! Cheers!
  12. #112
    Nov 2014
    I got mine through evo. They were very friendly.
  13. #113
    Jun 2015
    Cool and good to know. Thnx for the heads up
  14. #114
    Sep 2015
    Quote Originally Posted by motomike View Post
    Ok, its a rainy day here so I'll bite. Due to a theft, I have significant time on both the Patrol and Scout. It is a really tough comparison because both bikes are so fun, but I'll try to explain what I found....
    -I truly believe both bikes are just as capable at going as fast as you want. The difference to me is the feeling. The Patrol wants to smash the trail to pieces, the Scout wants to go just as fast but jump over things the whole way.
    It's a really tough call between the two bikes and I'm still contemplating on which one to keep now that the Patrol mysteriously came back home. If you have any more specific questions between the two, fire away!
    For all intents and purposes, I live in South Lake Tahoe and we have quite a bit of rocks on our trails here, but a lot of steep tech climbing to get to anything downhill. Ive owned a 2005 rocky mountain slayer 5 and 5 71deg HA and currently ride a 2006 Enduro 6 and 6 with a 66.5deg HA.
    I'm leaning towards the scout because I love flying uphill and never had an issue with my Rocky except for the super steep headangle. there aren't too many big, huckable features on our trails but they do get rough (lots of rock steps, rock constructed erosion control lines and baby heads).
    Did you feel like you were getting beat up doing the slightly gnarlier/gnarly downs on the scout or is it simply having to pick a line rather than blow through? Once again I'd love to slay my buddies once again gong up and I don't mind picking up the back end of the pack down as long as I'm not getting bounced around the trail constantly.
    Also, how does BB clearance compare on the two?
    Thanks a ton!
  15. #115
    Apr 2016
    All the info on this thread is incredible. I too am looking at either a Scout or Patrol. Been riding a Superfly 29er for several years. I ride northern VT (kingdom trails and Burke park and Blue Hills Vietnam trails around Boston) and am 6'3" and around 220. Sounds like I can't go wrong with either bike but am wondering if given my size is the Scout still enough bike? Super gnarly DH is what I do the least but certainly do about 10-15% of the time.
    Thoughts?
  16. #116
    May 2013
    May I aks why you don't consider a smuggler?
    If one bike for all (scout or patrol), I would go for the patrol. In generell, I would always sacrifice some playfulness for more stability - but that's also personal preference.
  17. #117
    Apr 2016
    Thanks for responding!
    Quote Originally Posted by aenduro View Post
    Thanks for the quick response!
    Great question. I rented a Smuggler last weekend which is why I'm interested in the Transition brand now. It was great and I noticed that is wasn't quite as responsive around corners as my Suoerfly 29er. Maybe I just needed more time to get used to it? I then rode a Giant Trance which is a 27.5 which was great fun to ride, and more responsive quicker handling around corners but didn't feel as solid or well built to me. (?) not sure if my size and weight are that relevant in this decision making process.
    I'm not a gear expert and don't have huge experience with lots of different bikes. I've owned this Suoerfly and also a Rumblefish 1 which was my first full suspension bike. Both 29ers. I have learned so much riding them and have improved my skills monumentally riding up here in northern VT. I thought a smaller wheel would allow for some more flexibility and also help to improve my skills. There is such a multitude of equipment, geometry options et al it can be overwhelming. There was something about that Transition Smuggler that really felt different than other bikes I've ridden over the past few years. Just felt and looked like a bike that was built with some thought and care. I am also an active road biker and have 2 beautiful steel frame Pegoretti's so I appreciate a well made bicycle. Mountain biking is taking over now as my passion. (Will be selling one of my road bikes!)
    I appreciate the insights and experiences from all on this forum helps me learn a lot.
  18. #118
    Monkey
    Reputation: Jozz's Avatar
    I was pretty much set on the Scout already, and this thread confirms it.
    I'm still undecided on size though. At 6'-2" I've always ridden large frame. Current bike is a Carbine. I've parking lot tested a large Patrol with 50mm stem and it did seem a little tight...
    So at that height, who's ridding a large vs x-large?
  19. #119
    Nov 2014
    I'm about 5'10.5 and at the extreme end of the medium and low end of large. I think the Transition sizing graph is pretty spot on. I can ride either frame. But the scout is supposed to be "playful" and the smaller frame helps.
    I'm actually contemplating building up a hard tail now that I've been on shorter travel. I think the lesson I've learned is not to buy a bike for 10% of my riding, which is what I had before with the Reign. I can't bomb downhill like I could w/ 7" travel, but the other 90% is more fun which more than makes up for it.
  20. #120
    Apr 2014
    Scout 2017 is finally here!
    Scout 2017 Kit 3 with the following changes:
    1. Pike bumped up to 150mm
    2. Raceface Atlas bars cut to 780mm
    3. Superstar Nano X flats
    4. Raceface love handle grips
    Attached Thumbnails Attached Thumbnails Scout or Patrol - the big decision. Who's riden both?-p_20160908_085208.jpg
  21. #121
    Nov 2008
    Damn! Pike at 150 looks fun! Have you had it on the trails much? How has it been?
  22. #122
    Pike at 150 is sweet on these bikes. Thats what I've been running too. Bike looks great!
  23. #123
    Jun 2010
    Quote Originally Posted by Jozz View Post
    6'3" on an XL and even at that i don't have any extra room.
  24. #124
    Monkey
    Quote Originally Posted by uberstein View Post
    I have an order put for an XL 2017 Scout 3, black on black. Can't wait!
  25. #125
    Nov 2014
    Well since my Scout 2 got stolen I'm now back to looking at both the Patrol and the Scout. Some more input after 5 months of ownership below.
    I rode both the Scout and a Suppressor (26" Patrol) down my favorite trails a few times back to back. The flow trail was more fun on the Scout. I could get more out of pumping and got more air off features. Fast rooty rocky was more fun on the Suppressor, if you're trying to go fast.
    I rode the Scout down Braille trail at Demo Forest near Santa Cruz right before it was stolen. This trails is majorly rutted and steep with roots all over. I was behind a group of peeps on enduro bikes and I couldn't keep up. I'm sure on the Reign X or Suppressor I could have just blitzed down along with them, but I was getting pitched around a whole lot trying to roll it. At the nastier bits I had to slow down and hop stuff. The bike did a somersault when I got bogged down in one rooty section, but I dismounted so it ended up OK.
  26. #126
    Aug 2014
    I have both bikes. Had the 2015 AL Scout (upgraded 2), demo'd the carbon Patrol, was blown away and got the 2016 Build 1, and now have one of each. The Patrol is a more stable bike, and is better in the chunk, just like you would expect in a 150/160 bike versus a 125/140 bike. Considerably better. I do have the Pike at 150mm on the Scout rather than 140mm.
    In truth, the Patrol is superior in every way, minus long rides where pedaling efficiency is better on the Scout. For me, I notice the difference in fatigue at about mile 14.
    I think it's simple. If you're more about trail riding, and want to have a bike that you can go ride pretty much everything minus the biggest of hits, and the roughest of the rough, then the Scout is probably the bike for you. More efficient, less fatigue. In "trail mode" the thing just rides like a dream on longer Epic rides. If you enjoy the bigger hits, rough stuff, and getting rowdy more than longer trail rides, then the Patrol is the ticket.
    I can ride the Scout over anything I've done on the Patrol...but it's considerably slower. You can't monster truck anything on the Scout. On the Patrol, it just soaks up everything, but doesn't lose the poppy feeling.
    Generally speaking, the Patrol is the better bike IMO. Unless you're headed out on a trail ride that's going to be over 15 miles of fairly intense paced riding with some steep climbs, the Patrol is a more versatile bike. My carbon Patrol is every bit as poppy as my AL Scout. I cannot speak for the Carbon Scout, but it wouldn't handle chunk or big hits as well as the Patrol regardless.
    The Patrol shines on the descents. It's planted, handles like a dream, and you can still hop anything. I can't keep nearly the pace downhill on the Scout that I can the Patrol.
  27. #127
    Yet another person with the same dilemma, scout or patrol? I'm coming from a large Turner rfx. At 5'10" I was right on that point between sizes.
    My riding is normally rocky steep trails in the Peak District (UK).
    The Turner felt like a burly all mountain/trail bike rather than the defined dh bike that some 260 frames can feel like, hence the dilemma.
  28. #128
    Nov 2014
    I reasoned this out in another thread. I'm just shy of 5'11", inseam about 30-31", wingspan also 5'11". Standing, I feel great on a medium. Sitting and climbing, large feels great. I can always adjust stem size, but can't make the frame longer for the climb. I owned a medium for several months. Just bought a large so I'll see if I'm right
    And I think basically you'll have a rougher ride on the Scout vs the Patrol, but it's easier to hop. So do you prefer to run things over and go fast or hop over things?
  1. Anyone rode the Patrol ???
    By afp3 in forum Transition Bikes
    Last Post: 10-30-2015, 03:54 PM
  2. Carbon Patrol and Scout???
    By Travis Bickle in forum Transition Bikes
    Last Post: 10-24-2015, 08:43 AM
  3. Rock a Patrol
    By Chad_Money in forum Transition Bikes
    Last Post: 01-06-2015, 02:20 PM
  4. Nissan Patrol anyone ??
    By jpvm in forum Car & Biker
    Last Post: 09-24-2012, 07:09 PM
  5. rocksox reverb or spesh comand post ? anyone riden both ??
    By twedspeed in forum General Discussion
    Last Post: 01-16-2011, 03:26 PM
