Page 12 of 12 FirstFirst ... 289101112
Results 1,101 to 1,137 of 1137
  1. #1101
    Sep 2016
    Ill have mine in the next two weeks, GX Med frame, ill weigh it on a proper scale once I have it.
  2. #1102
    Hopefully this doesn't break any rules but for anyone looking to "build" up a bike, my used carbon scout is for sale, just needs a few small parts to complete it.
    https://www.pinkbike.com/buysell/2289124/
  3. #1103
    Jul 2017
    Does anyone know what the suggested or OE fork offset is on 2017 Scouts?
  4. #1104
    just whatever the standard 27.5Ē offset is. Any normal fork will do.
  5. #1105
    Oct 2017
    Anyone here with a medium or large Scout Carbon and a 125mm Reverb Stealth with the Connectamajig hose connector? Is there enough space to push the post all the way in to the frame or does the Connectamajig hit the rocker pivot axle?
  6. #1106
    Sep 2016
    Anyone know what glue they use to attach the rubber pads on 2018s? Mine lifted a little on the rear chain stay where the derailleur hose comes through
    Sent from my iPhone using Tapatalk Pro
  7. #1107
    Dec 2017
    Quote Originally Posted by rad3144 View Post
    Pics and how do you like I‎t?????? Oh, and how much does I‎t weigh?
  8. #1108
    Sep 2016
    Iíll get some pics in a bit, headed to a friends house in a bit to finish it up, heís got a scale so Iíll let you know
  9. #1109
    Sep 2016
    Sheís a porker, as luck would have it itís pouring rain here so no rides yet
    Med Gx Build
    Diety bladerunners, diety knuckledusters, dhf 2.6 3c up front and 2.6 Rekon 3c rear
    3-4 oz in each tire of sealant. Also switched out the dumb plunger to a reverb paddle 1x
    Pretty happy with it. I came from a heavy plus hardtail with 3 inch tires so I doubt Iíll notice the weight. First impressions are the front wheel is way out there! In a good way.
  10. #1110
    Sep 2016
    Scout Build Thread
    Letís not forget about this lil guy right here
  11. #1111
    May as well just scrap it at this point.
  12. #1112
    Dec 2017
    Med Gx Build
    She is a beauty!!!!! Iím waiting to ride one in Feb when my lbs gets I‎t in, but I‎t is hard not to order I‎t up. Looking forward to a ride report.
  13. #1113
    Sep 2016
    Quote Originally Posted by max_lombardy View Post
    Yep itís trashed
  14. #1114
    Sep 2016
    1st ride was in the wet, suspension wasnít set up right so I fought it a lot, so Iíll do a proper ride report in the dry or at least drier I can say that sbg is legit, going at speed itís like all the sudden ďoh this feels good and solid and tracks wellĒ hard to describe. Iíve got some tinkering on suspension to work on to make it pedal a little better, I set sag in the rear at the top of tr recommended 17-19 mm, going to set it at 17 and bring up lsc I had it open. This was more of a shakedown ride for me, I will update with a proper report later
  15. #1115
    Sep 2016
    And sheís dirty
  16. #1116
    Sep 2016
    Also check your hangers on new builds, mine was significantly out of whack
  17. #1117
    rad to the power of sick
    Reputation: superlightracer's Avatar
    Weights have been published on the specs.
    Some great sets for the trainer:
    http://soundcloud.com/deejayfeelgood
  18. #1118
    Sep 2016
    Anyone know the largest oval it can run 2018? They say 34 but Iím assuming a 34 oval might rub
  19. #1119
    Sep 2016
    Proper ride report: 2018 gx scout, I finally got a good ride in tonight, this bike is rowdy as hell. Once I stop paying attention to the front wheel thatís way out there and just riding it clicked for me. It just wants to go fast, had a couple of steep punchy climbs that sucked but as long as you keep momentum this thing just wants to move. Iíve still got some suspension tuning to do itís still a little harsher than I think it can be, Iíll borrow a shockwiz soon and see what data it kicks out. Overall Iím very pleased with this bike, excited to get it on some more challenging trails. Iím in ne texas so we actually have to earn the downs so I do a decent amount of climbing and itís not bad at all. Letís get to some complaints. The RockShox Reverb is a turd, I came from a transfer and the RS is a piece of shit, cold weather it doesnít like to work. I canít even believe that Sram things anyone wants the dumbass plunger, gtfo with that garbage, swapped-to the reverb 1x (if I had it to do again I would do a cable replacement, Wolf tooth etc. almost same price) Probably swap it for a BikeYoke revive eventually. Gx Eagle: mostly happy with it, getting a weird pop sound (sounds like a spoke moving) in the drive train when putting down power, seems to be after Iíve gone airborne or worked the rear shock a lot, and doesnít do it all the time. aside from that it shifts great and reliably. Brakes are noisy, may be my half assed bedding in, rear brake does the tink tink thing, Iím going to replace stock pads with semi organic and see if that does it. Otherwise they work fine. If I were being picky I would say the paint is VERY easy to scratch. I scratched mine with an Allen key when I was building it so Iím not that worried about it after I broke the seal. Still working through some fit stuff as well.
    Overall I feel like I get it now, the giddy up, SBG etc. it likes to go fast, rail turns, it just feels fun. Not sure how else to describe it. Thanks for reading my diatribe, I just felt like I should tell someone
  20. #1120
    Just got my SBG Scout last friday, rad3144, what's your weight and pressure in the rear shock you are running? Trying to set up mine and for now it's 112Psi, my weight with gear is 138lbs.(63Kg).Scout Build Thread-dsc_0205.jpg
  21. #1121
    Sep 2016
    Iím running 245ish rear weigh 225 ish with gear, body weight plus 20# seems to get it relatively close
  22. #1122
    Sep 2016
    Thatís also very much by feel it may feel even better with less air but to get the sag on the low end of the recommended 17-19 mm, (im right around 17.5mm sag) for you being lighter, may ride better at 19mm, mine felt mushy at 19mm sag
  23. #1123
    Thanks for the info. Tr guys suggested a good starting point should be body weight -15PSI when I asked them by mail, but even so I could'nt get to the recommended sag (15mm).
    any way, It ride awesome! Switching from 2013 Covert this bike feels better in any aspect, climb great, very nimble into corners, and love to jump anything.
  24. #1124
    Sep 2015
    Hello, does anyone own a Scout 2018 SBG in size S?
    Yes, I am.
  26. #1126
    Sep 2016
    Quote Originally Posted by dr_orlick View Post
    I thought 18 scouts itís 17-19mm? May be different for different sizes I guess
  27. #1127
    It is 17-19mm just said that needed to air down alot to get there(minus 20-25psi) and when trying what Transition suggested( minus15psi) was getting only 15mm of sag, hope I was more clear about that now.
  28. #1128
    Sep 2004
    Has anyone gone from the alu scout to the carbon? what were the major differences? worth the change? close out deals on the carbon.
  29. #1129
    Sep 2016
    That makes sense now
  30. #1130
    Sep 2015
    @dr_orlick
    I'm interested in Scout 2018.Can you describe me as you are with this bike? I am 5.6 tall and not so take the S or M.How tall are you?Thank you
  31. #1131
    Sep 2016
    Iím on a medium at 5í9
  32. #1132
    Quote Originally Posted by gippi1984 View Post
    @dr_orlick
    I'm 5"5 and with 40mm stem it feels spot on for me.
  33. #1133
    Sep 2015
    [QUOTE = dr_orlick; 13488486] I'm 5"5 and with 40mm stem it feels spot on for me.[/ QUOTE]
  34. #1134
    Sep 2015
    [QUOTE = dr_orlick; 13488486] I'm 5"5 and with 40mm stem it feels spot on for me. [/ QUOTE]
    Hello, what is your inseam? What saddle height do you pedal?
    I'm trying to understand if Scout 2018 S or M is better for me.
    Thank you so much
  35. #1135
    Jan 2018
    I am 5'8", and I demo'ed the M X01 last month and it fit perfectly. I decided within two trails that the Scout the bike that I need to have but I have somehow since slipped into analysis-paralysis and cannot stop agonizing over whether there is something similar that I would like even more.
    I am upgrading from a 2013 Pivot Mach 5.7 AL which I still have a ton of fun on, so anything new is going to be an upgrade in terms of what has come out in the last 5 years so I should just do it I guess.
  36. #1136
    Jul 2014
    Anyone have any opinions on building up a 2018 SBG Scout frame with a standard offset fork?
    My fork has 44mm offset. I figure that will slightly increase the wheelbase and the reduced trail compared to the stock 38mm offset will make it slightly less stable at speed, but I'm wondering *how* much real world difference there would be compared to the engineers' intent?
  37. #1137
    Just built this up for my son who has out grown his ripcord
    Found a scout frame at a seriously good price so snapped it up. Mixture of parts from his old bike, the parts bin, new parts.
    26 inch wheels (mavic crosstrail)
    160mm pike (26 A2C = 150 650b) with luftkappe
    -1.5 works components headset (65 head angle)
    Zee brakes
    Maxxis HR2
    XT crank the now 155mm NX crank (to be fitted)
    11sp XT
  1. ARC-X Build thread
    By frknlitebike in forum Yeti
    Last Post: 09-15-2017, 08:26 PM
  2. My Origin 8 Scout 29er build
    By Bikin' Bric in forum 29er Bikes
    Last Post: 11-13-2013, 06:16 PM
  3. Origin 8 Scout 29 build
    By mountaingoatepics in forum 29er Bikes
    Last Post: 05-27-2013, 07:23 PM
  4. 2012 Origin8 Scout build post
    By joe_bloe in forum Singlespeed
    Last Post: 05-29-2012, 10:21 PM
  5. Replies: 13
    Last Post: 07-22-2011, 02:00 PM
Members who have read this thread: 335
