Page 11 of 12 FirstFirst ... 789101112 LastLast
Results 1,001 to 1,100 of 1169
  1. #1001
    Quote Originally Posted by JDub713 View Post
    Build complete, ready for big bear this summer
    Good to see the original Limeade versions representing!
  2. #1002
    Apr 2014
    Has anyone messed with removing the Transition decal on the carbon frame and put a different color on it?
    If there's no mountain, it's just biking.
  3. #1003
    Reputation: Calhoun's Avatar
    Nov 2008
    Quote Originally Posted by jfett View Post
    Not a decal on the carbon frames
    "Mi amor Nuevo Miťrcoles!"
    -cabra cadabra
  4. #1004
    Mar 2011
    Hi all, as previously commented I find the standard monarch RT3 is great untill I ride over bigger square edge rocks where it really hangs the bike, it also gets overwhelmed in rock gardens or bigger rooty trails.
    Obviously it's limited to a certain degree by the amount of travel but was wondering if anyone has tried getting it tuned to improve the performance and if so what did you get done and what was the outcome.
    (Currenty run with 3 bands in the shock).
    Noticed the avalanche tune but would prefer not to send it off to the US and preferably get something done via TF ETC.
  5. #1005
    Feb 2010
    Check out my shimstack for Smuggler: Smuggler shock options
    It should also work on Scout. If you are willing to give up the lockout function of the shock you can revalve the Monarch to perform much better. This setup is for heavy rider (I'm over 100kg). If you are lighter, you must definitely select lighter rebound stack and most probably reduce the stiffness of the compression speed stack (i.e. instead of three 0.25mm shims something less). It will probably take two or three attempts to get it right.
  6. #1006
    Reputation: Macharza's Avatar
    Jun 2013
    Has anyone tried the angle set for the Scout?
    How much the bb height drops
    Thinking about 1 degree angle set.
  7. #1007
    Quote Originally Posted by Macharza View Post
    Not to derail or anything but if you're running a Pike the 150mm air leg is cheaper than an angleset, slackens it out and raises the BB slightly. I don't think I'd want to go any lower than a stock Scout BB for most places.
  8. #1008
    Jan 2014
    It will lower the BB by about 1/16". In other words, almost nothing.
  9. #1009
    Alittle pricy but running 160mm forks slackens the HA. Transition themselves mentioned this in a recent interview on the Scout.
  10. #1010
    Jun 2013
    Thanks guys for advice!
    I'm already running DVO Diamond 150 fork and ordered from Works Component a new 1 degree angle set
  11. #1011
    Jan 2017
    Scout Build Thread-unnamed.jpghey guy ! just come back to the belgian race, finish 57/250 guy,lot of big bike in steep section but this little rocket was faster ! incredible bike, maybe i will buy his big brother !
  12. #1012
    Quote Originally Posted by Rideflo59 View Post
    Awesome looking Scout mate. Any problems getting the braided lines through the internal cable routing channels? I was a bit worried the bigger OD on the braided cables would be a problem.
  13. #1013
    Jan 2017
    Thx Bro ! The most difficult was the brake c‚ble (aviation by hope) bust just take 10-15minute for put it ! The TITS technology is nice
  14. #1014
    Cheers for the reply. I'm hoping to get a carbon frame for my Scout sometime and was worried if the TITS system would work with braided lines. Well done on the Enduro result!
  15. #1015
    Jan 2017
    Quote Originally Posted by toodles View Post
    that's gona be find! the worst was the cable's seatpost because the space for fit in the seat tube it's pretty smal but my fing is maybe so tall for this haha
  16. #1016
    Nov 2008
    Question for you folks, I have a stock 160mm rotor on the back of my Scout now. If I want to move to a 180mm rotor, what adapter do I need?
    Thanks again!
  17. #1017
    Feb 2016
    Quote Originally Posted by lightenup View Post
    Thanks again!
    Shimano F180P/P2 Disc Brake Adaptor > Components > Brakes & Shifters > Brake Adapters | Jenson USA
  18. #1018
    Reputation: midwestxmike's Avatar
    Apr 2014
    ... and if we just ...
    I'm 5'9 and running the 125mm KS Lev on my medium Scout with no issues. Not sure what Reverb would suit.
    @ 5'9" were the same height, and I'm pretty sure I saw you mention having stumpy legs as do I haha.
    my questions are, how slammed is your post into the frame, what crank arm length do you run, and with your build do you think you could run a 150/160mm dropper?
    Braaap!
  19. #1019
    I'm running a BikeYoke 160mm dropper now with nearly maximum insertion (works great!). I used to run a 125mm KS Lev which was at maximum extension (short post length).
    170mm cranks on both bikes.
  20. #1020
    Apr 2014
    Thanks! Good to know!
    Braaap!
  21. #1021
    Just put a DB Inline on my Scout. My Monarch was due for a service and with the Inline so reduced in price I thought I would give it a try. Just after a few laps I can highly recommend it--much more small bump absorption and plush on the rough stuff going downhill. I know they are supposed to have some durability issues, but since Ive got the monarch for backup, no worries!
  22. #1022
    Air or cool?
  23. #1023
    Quote Originally Posted by max_lombardy View Post
    Air or cool?
    Air. Rode it again this afternoon and my initial impressions still hold true. I still have some tuning to do, but pretty psyched on it in general.
  24. #1024
    Man, every time I ride this bike I'm so stoked on it! There's honestly not a single thing I'd change on it. Not even carbon frame, so pleased with the alu version. Thanks TR!
  25. #1025
    How does the stock shock tune work for light rider (<140lbs)? Has anyone performed any custom tuning specifically for light weight riders?
  26. #1026
    Nov 2006
    Quote Originally Posted by ashwinearl View Post
    I'm quite a bit heavier at -215 geared up. To me the stock tune is more geared toward riders lighter than me as I found the compression and rebound damping a bit light.
  27. #1027
    Apr 2014
    Alright, one more question. What is the measurement from center of BB to center of seat rails?
    Braaap!
  28. #1028
    Lol you haven't bought one already?
    Ok, alloy scout full Bikeyoke insertion (all the way in frame) with the post fully extended is 670mm from BB to seat rails.
    I'm running mine so full extension is about 690mm from BB to rails.
  29. #1029
    Apr 2014
    HAHA I did buy one, but I bought a Fox Transfer at 150mm and it was waaaay too long.
    my seat sits at 660.4mm pretty sure I can make it work..
    Braaap!
  30. #1030
    Apr 2014
    New Used Scout
    I bought a Scout used from somebody and I love it. I've ridden it twice now. Most of the first ride was spent adjusting everything to my liking. I put Shimano MX80 flats on and ESI chunky grips but everything else is the Scout 3 build. It's all SRAM at the moment which I'm not sure about. I prefer Shimano brakes which I will be switching out soon but I haven't decided on the drive train. The GX 1x11 shifts fine, can't complain, but I don't like the feel of the shifters. But the bike is awesome!
  31. #1031
    The White Jeff W
    Reputation: jeffw-13's Avatar
    New to me 2015 Scout XL
    Manarch RT3 shock, Manitou Mattoc fork, KS Lev dropper, Stans Flow Mk3 rims on Hope hubs, 2.6 Nobby Nics, SLX brakes
    Sent from my SM-G900V using Tapatalk
    No moss...
  32. #1032
    Quote Originally Posted by jeffw-13 View Post
    2.6s??? How's the clearance on the rear??? You must get some occasional rub??
  33. #1033
    The White Jeff W
    They're fine. They actually measure under 2.5 on the Flow rims. Visually they dont look any bigger than 2.35. A littie disappointed, to be honest.
    No moss...
  34. #1034
    "El Whatever"
    Reputation: Warp's Avatar
    I'm 140lbs give or take depending on gear. Stock tune is not bad on the Debonair but I'm not using full travel. I did not bother to play with the volume but that may do it.
    I'm replacing the Debonair with a Float X... I will let you know but it will take time before I get to any conclusions/impressions.
    Check my Site
  35. #1035
    Reputation: motomike's Avatar
    Feb 2005
    This thread needs more pictures. Just built up this Scout frame yesterday.
  36. #1036
    Apr 2014
    super sick build!
    Braaap!
  37. #1037
    Wow that looks awesome.
  38. #1038
    Agreed! Unique and very nicely done!
  39. #1039
    App-a-LATCH-un
    Reputation: Appalachian's Avatar
    Quote Originally Posted by motomike View Post
    Is that a dhf 3c in the rear?
    Fifty-two, I mean fifty-four bicycles on the wall
    Ready to ride, ready to ride until the last of them falls
  40. #1040
    Feb 2005
    Quote Originally Posted by Appalachian View Post
    Yes, a 2.5 DHF wide trail. Best tires around at the monent!
  41. #1041
    Feb 2005
    Pretty happy with the Scout so far. It's a nice little change from riding a Patrol for 3 years. I wanted something a little more nimble and lively and this is definitely it.
  42. #1042
    Jul 2015
    Scout Build Thread
    Do you guys think that there is going to be an updated scout this year or just the new sentinel?
    Because a scout might be my next ride and they are on sale
  43. #1043
    Apr 2014
    Quote Originally Posted by dcycleman View Post
    There will probably be an all new bike that is similar to the Scout. My guess would be boost spacing and their new geo. With that said, I wouldn't hesitate on getting a Scout...this bike rips and has been my favorite bike so far.
    Braaap!
  44. #1044
    Jul 2015
    Quote Originally Posted by midwestxmike View Post
    Yeah, I think I'll probably jump on a scout anyhow
  45. #1045
    From what was leaked earlier on the web, the new 'Scout' has the new SBG geo update (longer, slacker, steeper SA, reduced fork offset) and maybe a travel increase? I love my current Scout though - it's a more nimble and playful bike than my Patrol. Grab one if they're on sale!
  46. #1046
    Reputation: bikeboardorblade's Avatar
    Anything you miss from the Patrol? I'm in the ever debated Scout vs Patrol dilemma. Coming off of another 6" travel bike in unsure if I want to"risk" it with the Scout or stick with what I know (long travel).
    Sent from my XT1650 using Tapatalk
  47. #1047
    If you were ever going to go with the shorter travel bike, the scout would be number one on my list. If you build it up with solid parts the thing will slay
  48. #1048
    I'd be swapping everything over from my Tracer. 150 or 160 Lyrik, Spank/Hope wheels, and then likely pick up a Topaz out back.
  49. #1049
    I've got both and if I had to pick one I'd take the Scout again hands down. Blows me away how capable that bike is. If you're only doing Enduro races maybe go the Patrol, otherwise I really doubt you'll be disappointed in the Scout
  50. #1050
    Feb 2005
    Agreed on all counts.
  51. #1051
    Apr 2014
    I just made the switch from Mach 6 to Scout...nothing missed, way more fun, and I've bettered my trail times significantly.
    Braaap!
  52. #1052
    Sep 2004
    holy shit, thats pretty cool. whats the shock & tyres you are running?
  53. #1053
    Reputation: reydin's Avatar
    Feb 2007
    I'd know that bike by those wheels anywhere.
    If I had a black light this place would look like a Jackson Pollock painting.
  54. #1054
    Jul 2015
    Have a scout 3 alloy in black coming home tomorrow
  55. #1055
    Feb 2005
    Quote Originally Posted by mrback View Post
    Cane Creek Inline Coil with a 400lbs Valt spring, and I run Maxxis 2.5 Wide Trail DHF MaxGrip tires front and rear. Lots of traction!
  56. #1056
    Been logging tons of hours on mine recently, trying to get in as much time as possible in the high country while I'm able. After a year it's still my favorite bike thus far. Just pulled off the shock to see how the bearings feel (half expecting to feel that notchy crunchiness) but they're smooth like butter.
  57. #1057
    Well folks here you have it:
  58. #1058
    It looks sweet! I think if I were to build one I'd go for the new coil-sprung Ribbon, full XT, Hope brakes and wheels.
  59. #1059
    I've often thought that my current Scout would be quicker than my Patrol on some of the enduro trails around here. If anything the new version would be even more suitable. Pretty impressive stuff. Really like the new colour too.
  60. #1060
    Anyone gone from a smuggler to scout or vice versa?
  61. #1061
    For the past two weeks I've been running a 2degree slackerizer from Superstarcomponents. I like it and it also has a 5-10mm+ stack on the headset to help with pedal strikes
  62. #1062
    Jun 2013
    I have opposite feelings. Here where I ride, there are plenty of rocks and roots. I choose Patrol, the rear is much better and feeling very smooth. The new Super Deluxe is so sensitive. Sorry
  63. #1063
    The White Jeff W
    Driveside chainstay I'm not original owner so I ordered a replacement. Transition is super fast responding.
    No moss...
  64. #1064
    Nov 2008
    Time to send this one out to pasture:
    https://www.pinkbike.com/buysell/2258307/
    -cabra cadabra
  65. #1065
    Quote Originally Posted by Calhoun View Post
    What gives? I've thought about selling my Scout but I know I'll regret it! I am thinking my next move might be to a sentinel, but I'd like to clock a little time on one before I pull the trigger.
  66. #1066
    Nov 2008
    wanting to try some new bikes. It's an annual thing and there a lot of new bikes that look pretty sweet, including the SBG stuffs.
    -cabra cadabra
  67. #1067
    anybody in here have ridden both the scout and the santa 5010v2? how do they compare? had the 5010v2 its a very very nice and playfuŲ bike but L is a littlebit too small and XL was too long for my likings. the large scout is inbetween. finish and workmanship on my santa frames are flawless....how is transition? i also like the lifetime warranty from santa, why only 2 years from tranny?
  68. #1068
    I had a Scout the first year it came out and absolutely loved the bike. That year a buddy of mine took me to bike park and I was hooked on park riding. I sold the Scout to buy a Santa Cruz Nomad3. I regretted selling the Scout from day one. I ended up adding a V2 5010 because the Nomad was not as much fun on local/flatter/less technical riding. While I really liked the 5010 no matter how much I tinkered with the rear I could not find a happy medium between plushness and support.
    The thing with that Scout was how easy it was to set up. Set sag like they recommend and it handles 95% of the riding. The reason I sold my Scout for a bike park rig was it handled a majority of the trails fine, but rapid continuous hits overwhelmed the rear.
    If I had to choose between the Scout and 5010V2 I would pick the Scout. It was more of a hooligan bike than the 5010. Iím not the greatest rider out there and am not a hooligan, but the Scout just made me feel more confident in whatever I was trying. The 5010 is more of a precise bike, it rewards riders with more skill than I have. The Scout allowed me to try things I maybe didnít have enough skill to accomplish, but took care of my deficiencies rather well.
    With the V2 Scout having SBG I gotta say Iím really thinking of selling my Nomad and buying another Scout. I think the new Scout will handle bike park duty better than the original, and still be a better pedal friendly trail bike.
    I really love the lifetime warranty on the Nomad, but I rarely keep a bike longer than 3-4 years anyway.
    BTW I sold the 5010V2 to pay some bills so the N3 is my do it all bike now.
  69. #1069
    N3 is a beast for a do-it-all bike! I think youíre right about the new scout being even more of a hooligan than the last. I think the bike deserves a 36 and a rezzy shock from the get-go. Iím starting to think about my next build for 2018 and the Sentinel is pretty tempting. Iíd like to try the new scout too but I donít really think it would make much sense to swap my current scout for a Ď18. Just too similar.
  70. #1070
    I thought about buying the frame and using my components on the new Scout but Iíll have to buy the correct fork to get the right offset. Going that route and I might as well buy the complete bike kit. $1999 for frame and figure $700-$900 for a fork and then some boost adapters for my wheels, new headset, spare parts, worn drivetrain , etc and I might as well get the complete bike for $3999!
    Anyone want to buy a 2017 Santa Cruz Nomad CC XX1 large?
    I really like the Scout with 150mm up front and 65 degree HA with a long reach and short stem. I am really curious how the bike rides.
    My original Scout with 150mm fork was so playful! I canít imagine a bike that playful with better downhill capability!
  71. #1071
    Scout or Smuggler Coil, its for sale 450.00
    Scout Build Thread-img_0009.jpgScout Build Thread-img_6689.jpgScout Build Thread-img_6690.jpgScout Build Thread-img_6691.jpgScout Build Thread-img_6692.jpgScout Build Thread-img_7431.jpgScout Build Thread-img_7574.jpg
    Transition Scout Carbon
  72. #1072
    Apr 2014
    Finally finished putting this one together...
    Braaap!
  73. #1073
    Sep 2015
    What stem is that? I am looking for something similar with a bit of rise.
    Sent from my VS987 using Tapatalk
  74. #1074
    Apr 2014
    Quote Originally Posted by johnny5jz View Post
    Its an Ordnance Bikes prototype stem 35mm rise. Available real soon.
    Braaap!
  75. #1075
    Sep 2015
    I will keep an eye out for it. I like the bars I have, but I need a bit more rise.
  76. #1076
    Jan 2014
    Hope has a 50mm stem with quite a bit of rise if you don't need the 35mm.
  77. #1077
    The White Jeff W
    Just to follow up...big thumbs up to Transition customer service. I made initial contact via email the evening of Wednesday 8/27. Warranty form was emailed to me within 20 minutes and the new chainstay was on my doorstep on the other side of the country in a week. The video and torque specs on the website made the installation a breeze. Nothing but good things to say about TBC for their CS and support of do it yourself-ers.
    Couple side notes - lower pivot bearings were seized. I had a couple in the parts drawer (from a Hope hub) so i replaced them. I messed around with them later and was able to free them up after removing one of the seals and cleaning them with brake cleaner then a soak with PB Blaster then repacked with grease. They're rough but probably still usable.
    The 2017 chainstay they sent looks to have a little less tire clearance that the 2015 it replaced. My (undersized) 2.6 Nobby Nics still clear but it looks tighter.
    No moss...
  78. #1078
    I wonder if they added some material to the stays and thus reduced the cracking?
    Also, in the end was the replacement on warranty or paid?
    The White Jeff W
    I paid for it since I wasn't original owner.
    It occurred to me that the tire may have grown some since I first mounted it. I haven't measured since new. I'll have to get the calipers on it tomorrow.
    No moss...
  80. #1080
    The White Jeff W
    This bike loves flowy, pumpy trails. Having a ball at Raystown in PA
    No moss...
  81. #1081
    Sep 2015
    How do you like the mattoc on the scout?
  82. #1082
    The White Jeff W
    Love it. Its the first full suspension bike Ive owned where I felt like the front & rear were matched in terms of feel & ride charactetistics.
    No moss...
  83. #1083
    Sep 2015
    I have a sektor gold on mine and am looking to upgrade. For the price it seems the mattoc is a great fork.
  84. #1084
    Apr 2014
    regardless of price the Mattoc is an excellent fork.
    Braaap!
  85. #1085
    Sep 2015
    That's good to hear. I am hoping to get something soon. The Mattoc is at the top of my list.
  86. #1086
    Apr 2014
    the other underrated fork is the SR Suntour Durolux. It rips as well and they have a new Demo to your Door option on their site I might try soon.
    Braaap!
  87. #1087
    Iím very tempted by the Ribbon coil. Looks the business.
  88. #1088
    Have any of you guys ridden with a 60 mm stem? I know transition says the max stem on these frames should be 50 mm, but curious if you guys have any real world experience with the slightly longer stem. Any noticable ride impressions? Looking to trade my L for an XL, but interested in a quick fix if I cant find a trade/sale.
  89. #1089
    Iím sure it would be *ok but an XL would be a way better option. The way this bike is meant to be rhidden Just doesnít jive with a 60 mm stem.
  90. #1090
    Got me a new bar/stem combo.
  91. #1091
    Put it on the scale for the first time as well. 28.9# the only carbon on it is the rims and bar.
  92. #1092
    ride
    Reputation: ignazjr's Avatar
    We have a 2018 Scout, large, black, GX 12sp build that just came available. A customer ordered it but couldn't swing it. Get in touch if you want it - they are sold out til Jan or so at this point!
    Redstone Cyclery
    intense*transition*rocky mountain*turner
    web - tweet - FB
    Lyons, CO
  93. #1093
    Put it on the scale!
  94. #1094
    Dec 2013
    Any weight numbers on the 2018 Scout?
  95. #1095
    Jul 2017
    Quote Originally Posted by michaelbarnard View Post
    Wondered the same thing but can't find any numbers anywhere
  96. #1096
    Reputation: SierraOutsider's Avatar
    Mar 2015
    Quote Originally Posted by Jd82 View Post
    Fanatik's custom bike builder has frame only (no shock) at 8.5 lbs for a large.
  97. #1097
    I have a 2016 Large scout with a DVO Topaz shock and switched over to an XL 2018 Scout. My new frame was about 1.8 lbs heavier then my old one, thinking it came in a 9.6 or 9.8 lbs on my unofficial bathroom scale. It definately feels heavier, but just got it built up tonight and haven't been able to get out on it. May be a few days until the trails dry out here.
  98. #1098
    Monkey
    Reputation: Jozz's Avatar
    That is a lot of meat added to a small travel frame...
  99. #1099
    Quote Originally Posted by Jozz View Post
    Same. I was wondering where all this extra weight in the SBG bikes went.
  100. #1100
    While I would never consider myself a weight weenie, the weight on the SBG Bikes is kind of concerning.
    I have never counted grams, or purchased one component over the other because it was lighter........but pedaling around a 30 plus pound bike will take its toll.
    My old Scout was not lightweight build, just a solid working mans build. I never really noticed the heft in the bike until I went to some carbon builds. My last two frames have been carbon and I have to say that you do notice the lighter builds throughout the course of the day. Every time you take the bike off the rack, lift the front end, bunny hop, walk the bike up a section you donít clear you are expending energy on the heavier builds. It all adds up.
    I really want to try a new SBG Scout, but a 30 pound build is gonna weigh in on my decision. Pun intended.
  1. ARC-X Build thread
    By frknlitebike in forum Yeti
    Last Post: 09-15-2017, 08:26 PM
  2. My Origin 8 Scout 29er build
    By Bikin' Bric in forum 29er Bikes
    Last Post: 11-13-2013, 06:16 PM
  3. Origin 8 Scout 29 build
    By mountaingoatepics in forum 29er Bikes
    Last Post: 05-27-2013, 07:23 PM
  4. 2012 Origin8 Scout build post
    By joe_bloe in forum Singlespeed
    Last Post: 05-29-2012, 10:21 PM
  5. Replies: 13
    Last Post: 07-22-2011, 02:00 PM
Members who have read this thread: 284
