Results 1 to 2 of 2
    Revo 32 10x135 freehub question
    I think I need to replace my freehub- i can pedal without going anywhere, the cass just spins. I don't have the tools to remove the freehub so can't take a look at the pawls right now. What I need to know is will the link below for the '12 freehub work with any cass? There's that huge area without any splines which is different that the current freehub I've been running for nearly 2 years:
    Transition Bikes
    I guess the cass will slide back on just fine as long as some of the splines line up? That smooth gap area is for weight savings? The quicker I can get an answer, I'll order the replacement from TBC.
    Nevermind. It's the hub itself, not the freehub that is damaged. LBS removed the the fb, cleaned it up, then noticed the issue when putting it back together so trying to figure out what hub to go with as a replacement...
