Results 1 to 2 of 2
    Reverb Cable Routing on 2013 Bandit 29er
    I've got a 2013 Bandit 29er frame with the cable routing guides on the right side of the top tube for a dropper post. I'm planning on purchasing a Rockshox Reverb; I haven't messed with dropper posts before.
    They come in left mounting, right mounting, and a newer stealth style. I'm not doing stealth.
    Which side routing should I get? Does the cable routing work best on the same side (e.g. right side cable routing)? Or is it better to cross over (e.g. left side cable routing)? Does it matter?
    Reputation: bettes's Avatar
    I'm running a righthand remote under the bar on the left side (1x10 so no front shifter) Sits super pretty up front.
    Then I stuck the line through the seatbinder eye, fixed that in place with a tiewrap (line to the eye) and spiraled the line around the post so no cable rub on the frame!
    Attached Thumbnails Attached Thumbnails Reverb Cable Routing on 2013 Bandit 29er-858131_10151248269147396_633114857_o.jpg
  1. Blur LTC Reverb cable routing
    By ben_san in forum Santa Cruz
    Last Post: 04-26-2013, 06:18 AM
  2. SX Trail Reverb Cable Routing
    By citizenlee in forum Specialized
    Last Post: 10-19-2012, 03:29 AM
  3. Endorphin reverb cable routing
    By jubilee in forum Knolly
    Last Post: 02-11-2012, 11:46 AM
  4. Cable routing for Rockshox Reverb on a Tracer
    By brenrub in forum Intense
    Last Post: 11-02-2011, 04:39 AM
  5. Reverb cable routing on Firebird?
    By istvisinet in forum Pivot Cycles
    Last Post: 03-06-2011, 01:38 AM
