Results 1 to 3 of 3
    Replacement ring on X9 2x10 crankset
    I beat up my 38t ring on my sram X9 cranks. These were taken from the stock s1400 cranks that came on my Bandit. Do I have to replace with a stock ring or are there other options available?
    Reputation: in the trees's Avatar
    Mar 2005
    Direct mount, narrow/wide ring and 1x10!
    rider
    Jan 2005
    I'm a big fan of Middleburn chainrings: shift great & last long with the hardcoat and are reasonable in cost for the quality. In the USA, MTB Tandems is the distributor, contact them about fitment. I'm fairly sure that you can use a standard 104mm 4 bolt ramped ring w/o any issues but why not check and be sure?
    BBG bash guards are nice and a good value if you want to make your next ring last...
    Abandoned the 26" wheel in May '03
  1. Convert 2 ring crankset to a single ring?
    By monkies in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-29-2013, 10:17 AM
  2. replacement 32T chain ring on Bontrager Comp crankset (2001 Trek Fuel 90), 3x9 gears
    By notafreak in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-08-2013, 02:35 AM
  3. Shimano XTR Trail 2x10 cranks/ring replacement and compatability
    By Cato in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-04-2012, 01:52 PM
  4. Can I put the small ring (22) from an M542 Crankset onto a Deore XT M781 crankset?
    By bobonker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-09-2012, 12:04 AM
  5. XT 2x10 Crankset Compatible with SRAM 2x10 Drive Terrain??
    By sbchisholm in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-01-2011, 07:30 PM
