Results 1 to 24 of 24
    Plus tyres in Scout/Patrol?
    Who done it?
    What's the widest plus/non plus tyre you've fitted?
    In rear tri I mean. I know a 2.8 will fit in the Pike.
    Reputation: motomike's Avatar
    Feb 2005
    I run 2.5 DHF 'wide trail' tires on my Patrol and they fit great.
    Thanks, how much room left over?
    Reputation: martinizer's Avatar
    Bump. Also interested in finding out if a 2.8 plus will fit in the rear end of the Patrol.
    Quote Originally Posted by motomike View Post
    Any chance you have a pic of that setup? I'm thinking about it for my scout with some 29mm internal rims. Undecided if it'll be too much or not.
    Jun 2010
    With a Maxxis Minion DHR2 WT (2.4 width) there's clearance on the Patrol, but not a lot of extra room. My Aluminum 2015 Patrol has lost a fair bit of paint in that area. I'm using a 35mm (inside measure) rim with the DHR2 WT in the back. great tire. enough clearance.
    I'm not saying' the 2.8" tire won't fit (don't know), but I would expect mud and rocks to nick up the paint or other finish on the bridge if you're using something big.
    It's not a plus bike, but has plenty of clearance for big tires in the "Non-Plus" range.
    Not sure that helps, but it might.
    Thanks Uber!
    Jun 2012
    Was at Highland MTB Park this weekend and my buddy rented a Patrol there (which he loved) and out of curiosity I through my rear wheel onto it in the parking lot. I'm running a Maxxis Rekon on a Easton Heist 30 that measures out to 66-67mm (~2.6") at 21psi and while it technically fit it was really close on all sides especially on the seat stays. No room for mud or kicked up stones.
    Quote Originally Posted by StumpyandhisBike View Post
    To be clear, this was a 2.8 Rekon you stuck in there?
    Jun 2012
    That's correct.
    Ok thanks. Scout c/s is 5mm shorter so there's a reasonable chance these 2.6's might fit.
    Plus tyres in Scout/Patrol?-maxxis-27.5-x-2.6-rekon-forekaster-tiresfrostbike-2017-120-600x400.jpg
    May 2014
    I have a rocket ron 2.6 fitted to 30i rim on the back of my scout, it still has enough clearance for preventing tire rubbing on the stays, but i think that's as big as i can go on the scout.
    Aug 2013
    2.8 Rekon in the rear with plenty of clearance. Way more than my Tracer had with 2.4 Ardent.
    May 2014
    Pics or we won't believe you
    Aug 2013
    Yes, one photo is sideways, but you get the drift. 2.8 front and rear mounted on Ibis 714 wheel set. 41mm wide outside.
    Attached Thumbnails Attached Thumbnails Plus tyres in Scout/Patrol?-image.jpg
    Quote Originally Posted by payze View Post
    Carbon or alloy frame?
    Mine is alloy and there's no way a 2.8 would fit as rorhound has done above.
    May 2014
    Alloy frame, that's a really close fit rorhound!
    Envoyé de mon XT1092 en utilisant Tapatalk
    Aug 2013
    It's not as close as the pictures seem to make it look. There's plenty of clearance. My first real ride will be tomorrow. If it rubs I'll let you know.
    Alloy frame
    Just a thought, what's the b/b height of your rig running those tyres?
    May 2014
    Quote Originally Posted by tungsten View Post
    It's 33,5cm with a 150mm fork.
    These tires are not big, just wider
    [/IMG]
    335 is that all, eh? Was hoping the RR 2.6 would be taller.
    I swapped out my fork making it a 150mm and then ran HD 2.35 'cause they were taller than the NN and got a bb height of 330 leaving about 7mm clearance right there by the yoke where your RR is closest.
    So, I was hoping the RR 2.6 would be near to 7mm or whatever larger across it's entire profile (if that makes sense) boosting the bb height.
    I thought this because with the thread pattern the RR looked like it would be constructed more like a HD than a NN.
    Almost bought one of those on-line just to try now I'm glad I didn't.
    Maybe they'll come out with a 2.6 HD. lol....and thanks for posting those.
    Aug 2013
    First ride today. No frame rubbing. Climbs great and handles great.
    May 2014
    Yes i was disapointed too' i hoped the 2,6 was a tiny 2,8 in terms of air volume. But anyway it climbs better than my previous rocket razor and can go a bit lower on the pressure.
    It's not all that bad and fits great on the scout
    Envoyé de mon SGP512 en utilisant Tapatalk
    May 2017
    motomike - You mentioned running 2.5 DHF WT...what internal rim width if you don't mind me asking. I have a frame and i30 wheels and about to buy tires. I want to go as big as possible with a little room to spare, but hoping the 2.5 DHF WT will work.
  1. Scout, Patrol ect... Cable Noise Fix!!!!
    By crazbiker4 in forum Transition Bikes
    Last Post: 07-17-2017, 01:44 AM
  2. Bearing lifespan - scout, patrol
    By darrenspink in forum Transition Bikes
    Last Post: 12-25-2015, 07:15 AM
  3. Carbon Patrol and Scout???
    By Travis Bickle in forum Transition Bikes
    Last Post: 10-24-2015, 08:43 AM
  4. Scout for a Patrol trade
    By bkies in forum Transition Bikes
    Last Post: 06-03-2015, 02:41 PM
  5. Bandit to scout or patrol
    By Kirky72 in forum Transition Bikes
    Last Post: 04-05-2015, 11:46 AM
Members who have read this thread: 43
