Page 1 of 4 1234 LastLast
Results 1 to 100 of 310
    Reputation: bullit43's Avatar
    Dec 2010
    Patrol build thread
    i think it´s time for the Patrol to have a build thread,here´s mine:
    Frame M Orange
    Shock Rock Shock Monarch Plus RC3
    Fork Rock Shox Pike RCT3 160mm 27.5 2016
    Handlebar EASTON Haven 35 750mm
    Stem EASTON HAVEN 35 40mm
    Headset FSA NO.57E
    Grips ODI Ruffian
    Cassette SRAM XX1
    Right Shifter SRAM X1
    Crankset RACE FACE Turbine cinch 175mm
    Rear Derailleur SRAM X1
    Chain SRAM X1 Shimano 11V
    Pedals Superstar
    Front Brake Shimano XT 2016
    Front Rotor Shimano RT76 180mm
    Rear Brake Shimano XT 2016
    Rotors Shimano RT76 180mm
    Saddle ANVL (cromoly)
    Seatpost Rock Shox Reverb Stealth 125
    Front Tire Maxxis Highroller II 2.4
    Rear Tire Maxxis Highroller II 2.3
    Wheels NOTUBES Flow Ex with DT SWISS 350 Hubs
    Weight 13.740kg
    May 2013
    me gusta!
    Just out of curiosity, why the (most expensive) xx1 cassette?
    I will also go for a SRAM drivetrain, but save the bucks on the back (cassette and derailer max. gx /x1) and put the higher-value parts on the front - since I've destroyed many derailers in the past and the cassette is still a wearing part for me.
    Since you ride a M patrol (and I guess you aren't over 6") have you thought about 170mm cranks? Just to compensate the low bb a bit and avoid some more pedal strikes. I'm thinking about this, but I'm 6"1 and I dunno if this will work out.
    I wonder if anyone has tried a 170mm fork on the patrol?
    Dec 2010
    I choose the xx1 because it was the only one available at my LBS,the cranks i already have. I'm 5.5 tall .
    May 2013
    here´s mine:
    Frame L Black
    Fork Rock Shox Pike RCT3 160mm 27.5 2015
    Handlebar SYNTACE HIGH 20 Carbon 780mm
    Stem SYNTACE MEGAFORCE 60 mm
    Headset Canecreek 40 upper, Acros Lower
    Grips ODI Troylee
    Cassette Shimano XT
    Shifter Shimano XT
    Crankset RACE FACE Next SL 175mm 22-36
    Rear Derailleur Shimano xtr Shadow Plus 10 speed
    Fron Derailleur, Shimano XTR direct mount
    Chain Kmc sl 10
    Pedals Look quartz
    Front Brake Magura MT 5
    Front Rotor Magura Storm SL 203 mm
    Rear Brake Magura MT4
    Rotors magura storm SL 180mm
    Saddle selle Italia SLR XP
    Front Tire schwalbe Hans Dampf tubeless
    Rear Tire schwalbe Rock Razor tubeless
    Wheels Ryde Trail 25 with DT SWISS 240s Hubs with cx-ray spokes
    Weight 12,90
    Attached Thumbnails Attached Thumbnails Patrol build thread-imageuploadedbytapatalkhd1440258774.473032.jpg
    Dec 2010
    Very neat that stealth look
    Reputation: HeavyFlow's Avatar
    My 2015 Patrol III with a few upgrades
    Mine is a stock 2015 Patrol III with a few upgrades:
    1) New KS LEV Integra dropper post
    2) New Easton Haven 35mm Bars and Stem (so sexy!)
    3) Put my used Atlas cranks on in place of the low-end stock cranks.
    4) My used VP Harrier pedals
    The Haven bars and stem dropped major weight and the carbon bars are so comfortable I swear I can do shuttle runs for 30-40% longer before I get arm fatigue.
    I love how the Haven bars in flat black with red totally match the pike's black and the red on the o-ring! This ended up makign my red pedals actually work whereas before with no other red it looked kind of "off".
    The only other thing I would like to change are the wheels but I can wait until I destroy them at which point I would like to try a slightly wider rim (32mm internal now) and a better rear hub.
    Dec 2010
    Quote Originally Posted by HeavyFlow View Post
    Same setup as mine,now with Pike Decals ,Specialized Saddle and Sixpack Racing plastic pedals.
    May 2013
    Frame L Black 2016
    Fork Fox 36 Float FIT4 160mm 27.5 2016
    Handlebar Renthal Fatbar 780 20mm
    Stem Renthal Apex 40mm
    Headset CC40
    Grips Ergn GE1
    Cassette SRAM GX
    Crankset X01 Directmount 175mm
    Pedals RaceFace Atlas
    Front Brake Shimano Zee
    Front Rotor Shimano RT76 200mm
    Rear Brake Shimano Zee
    Rotors Shimano RT76 200mm
    Saddle SQLAb
    Seatpost Rock Shox Reverb Stealth 150
    Front Tire Maxxis Highroller II 2.3 3C Tubeless
    Rear Tire Maxxis Highroller II 2.3 Tubeless
    Wheels DTSwiss EX471 with DT SWISS 24 Hubs
    Weight 14,1kg
    Hell, I dunno how someone can get under 13kg ....
    Weight 14,1kg
    Try changing your tyres you can remove 2 lbs easy and your brakes weight a lot!
    Happy new Transition Patrol (4) owner here! Completely stock, only added a chainguide because my chain came of too often. Absolutely awesome bike!
    Frame: Patrol Size L Satin Black Matte)
    Shock: RockShox Monarch RT Debonair
    Fork: Marzocchi 350 R 27.5 160mm Fork
    Stem: RaceFace Ride 35 50mm
    Handlebar: RaceFace Chester 35 (780mm x 20mm)
    Headset: FSA No.57SC
    Grips: Velo Single Clamp
    Saddle: WTB Volt Sport
    Seatpost: KS eTen Integra (100mm)
    Brakes: Shimano Deore M615 Brakes / Shimano RT64 Centerlock (180mm) Rotors
    Chainguide: e*thirteen XCX+ I05
    Shifter: SRAM X5 10sp
    Derailleur: SRAM GX 10sp Type 2.1 Rear Derailleur
    Cassette: SRAM PG1020 (11-36) with Hive 42t Extended Range Cog
    Chain: KMC X10 Chain
    Crankset: RaceFace Aeffect Cinch (DM32t, 170mm)
    Wheels: WTB STP i25 27.5 32h Rims / Shimano Deore Hubs
    Tires: Maxxis Minion DHF 27.5×2.3 EXO Dual Front Tire, Maxxis Minion DHR II 27.5×2.3 EXO Dual Rear Tire
    ''Anybody who thinks wood isn't magnetic, hasn't ridden a bike in the forest.''
    Jan 2016
    Quote Originally Posted by eps4mtb View Post
    here´s mine:
    Frame L Black
    Grips ODI Troylee
    Cassette Shimano XT
    Shifter Shimano XT
    Chain Kmc sl 10
    Pedals Look quartz
    Weight 12,90
    How do you like the Magura MT 5's? I am thinking of putting them on the front, and back. The MT 5 is actually cheaper than the MT 4. Do you like the SL rotors? I think I would use the same rotor selection as you did.
    Patrol build thread
    Here's mine:
    Medium with Monarch plus
    Pike RCT3 dual position
    HopeTech Enduro Pro 4 Wheels
    High roller 2 front (waiting for a magic )
    Hans Dampf rear
    XT m8000 11 speed cassette, mech, chain, shifter
    Zee brakes
    Raceface Aeffect cinch crank
    One up oval chainring 32T
    150mm Reverb stealth
    Chromag Fubars
    Anvl Forge saddle (waiting on a matching Chromag Lynx)
    6 pack grips
    Answer stem
    Hope headset
    Superstar Bano X pedals
    May 2013
    Quote Originally Posted by RGBAW View Post
    Hi sorry for the delay, wasnt here for some time.
    I like the maguras a lot. I came from avids, and i hate the dot fluid. Pulling water all the time and my cellar is pretty humid, so i had to change the fluid every three month.
    In europe the mt4 is cheaper then the mt5, but the lever is absolutely the same, in my experience a 4 piston brake on the rear weel is pretty overkill. The rotors are fine, quite light and not too noisy. I have a second weelset fo bike park, there i use the normal rotors, as they have much more material and therefore a better heat capacity.
    I use the mt5 on my blindside in parks a lot and i did not have any problems.
    Hope i could help!
    Reputation: Techspec360's Avatar
    Just wrapped this one up! Couple hucks off the rock piles and drops in the yard, this thing is gonna be a blast!
    Feb 2016
    Quote Originally Posted by Techspec360 View Post
    Beautiful bike! Love the blue, What grips are those?
    is that the same blue as the 2014 Scouts? Yours looks a little lighter.
    I just got a blue scout and looking for close matching blue parts.
    Quote Originally Posted by BobbyLight350z View Post
    Grips are Raceface love handles, Easton also has some blue ones that look like they'd match the color too. Not sure if it's the same color or not..
    Mar 2016
    With only 3 days! This thing is a blast to ride!
    Mar 2016
    This thing is blast to ride!
    Reputation: mint355's Avatar
    Mar 2012
    Hey guys here is my Patrol
    Sent from my SM-G925I using Tapatalk
    Mar 2016
    Awesome! What do you have to say about that shock on the Patrol?
    Just Birth!
    Dec 2010
    Mar 2016
    Just birth!
    Reputation: thegromit's Avatar
    Anyone with medium running a 150 dropper Im 5'8" I'm thinking it might be to long with the pivot bolt
    Life is like riding a bicycle. To stay balanced, one must keep moving. - Albert Einstein
    Hey guys, I know it's been mentioned before but just a reminder that the rear brake line WILL rub on your rear triangle seat stay. I proactively put Invisishield here to prevent damage to the surface and when it's dry that thing makes all sorts of rubbing noise, definitely a strong contact point.
    Mar 2016
    I run a L and with 5´11 i need a 150 dropper with any doubt...
    Quote Originally Posted by Mike640 View Post
    Yeah I'm on a medium. The seat tube length is said to be 16.5" but you can only put about half of that before you hit the pivot in/on seat tube. Plus a connectamajig makes it even less. Maybe I remove the connectamajig and run a standard line and get the little less.
    Is transition stocking mediums with 125 post?
    Mar 2016
    Im almost sure that the medium usually use 125 post....
    aaarrrggghh!
    Reputation: Ivan the Terrible's Avatar
    Mine
    I only have a handful of rides on this thing but it sure is fun.
    Quote Originally Posted by thegromit View Post
    I'm 5'8" (30" inseam) on Medium and use 125mm. Perfect length.
    Reputation: el_guillyt's Avatar
    Mar 2013
    A question for the patrol carbon users; do you think a braided brake lines (goodridge) will fit in the TITS feature? How tight they are? Appreciate any comments!!
    Enviado desde mi Nexus 7 mediante Tapatalk
    Quote Originally Posted by el_guillyt View Post
    The fit of the tit is pretty snug on regular brake hose, not sure how much larger the diameter of that stuff is. Careful on the opening on the bottom of the down tube, the angle of the hole and the finish is very sharp. Took the outer black coating off my hose in several locations.
    Mar 2013
    Thanks for the advice!! I think normal brake hoses are 5mm outer diameter and goodridge ones are 6mm....not sure about this figures but I know for a fact the goodridges are bigger... I've asked the dealer and he says no problem, they fit...we'll see
    Any one running double barrel on the patrol? I'm getting the frame with the DB coil and no base settings on canecreeks site, if somebody has one and would like share setting would be awesome!!
    Thanks again!
    Mar 2013
    Sneak pic....
    Nov 2015
    Patrol build thread-uploadfromtaptalk1458866110653.jpgPatrol build thread-uploadfromtaptalk1458866118841.jpg
    Has anyone had on issue with shifting cable getting caught up in the chairing? I just picked up my bike and was going over the bike and noticed the cable is mighty close.
    Sent from my D5803 using Tapatalk
    My Patrol.....
    After coming off a Scout I'm shocked how good the Scout was because the Patrol does not feel that much different! Just a little better DH.
    The di2 cable routing works perfect in the front triangle and stuck well to the rear with a the old external cable cover sheath and can't be seen in between the frame chain guard. I do need a longer cable though as i have had to use a cable connector at present.
    Bike weighed in at 28.lbs
    Patrol build thread-img_1501.jpgPatrol build thread-img_1504.jpgPatrol build thread-img_1505.jpg
    stejam,
    how do you shift to the larger chainring?
    Quote Originally Posted by dmar123 View Post
    stejam,
    HAHA good point! This was when i first built it and just thrown that XTR crank on to give it a go while i was waiting for a RACE Face BB tool. Its now got a NEXT SL crank and the rear di2 cables have been sorted
    Quote Originally Posted by stejam View Post
    I think we need to see another pic!
    Patrol build thread-img_1544.jpgPatrol build thread-img_1546.jpgPatrol build thread-img_1547.jpgPatrol build thread-img_1559.jpgPatrol build thread-img_1560.jpgPatrol build thread-img_1548.jpgPatrol build thread-img_1554.jpg
    Jun 2014
    Yes. The solution I got from Transition was to marry the shifter and brake lines to one another using a piece of tubing a zip-tie (start about 1" for the tubing length to keep them away from the tire).
    Mine isn't built yet, but just cycling the rear suspension will pull the shifter line straight into the chainring. Same issue. Going to try the tubing trick when I put the brake cable through. I'll try to get a picture of it.
    The seatpost internal routing is REALLY hard to pass the housing through down near the BB. The solution for this I got from Transition was to make an angled cut at the end of the housing to let it pass that corner easier, then square it off later. I'll see how that works tonight. Hopefully that saves someone else some headache.
    Nov 2015
    Quote Originally Posted by GH28 View Post
    Thanks. That is what I ended up doing. Except I used a cable connector thingy.Patrol build thread-uploadfromtaptalk1459478463345.jpg
    Nov 2015
    Here's a picture of the full bike. Build kit too. Still to muddy to ride here so it has been pavement and gravel trails. Looking forward to getting on some trails soon.Patrol build thread-uploadfromtaptalk1459478604811.jpg
    May 2005
    Here's my new baby...no rides yet and waiting on a shorter stem, but I'm super stoked!!
    Mar 2013
    Quote Originally Posted by bobman7 View Post
    I'm going to have similar setting than yours, dvo up front, Lev, carbon rims, cranks and handlebars and ccdb coil cs, xtr mech and xt cassette, how much does it weighs?
    Mar 2016
    With the stickers...
    May 2005
    [IMG]http://uploads.tapatalk-cdn.com/2016...7657b6b922.jpg[/MG]
    Mine came in a 29.2 with XTR trail pedals. A bit heavier than I expected
    Mar 2013
    I'm expecting around 31lb, I have a SA spring wich is around 150gr lighter and some mallet dh pedals, any way I will be super happy as my old rune was 32,5 lb with air shock and I was pretty happy because didn't felt heavy to me, so anything lighter and with coil is welcome
    aaarrrggghh!
    Mine came in at 29.5 complete, and this is for an alloy frame. The only extravagant part on mine are the Enve wheels. I am confused as to how these carbon builds are coming in so much heavier than mine. You guys running slime tubes? lol.
    Mar 2013
    I don't know were those extra grams are coming from?? I know there is lighter cranks, pedals, cassette, hubs, shock, fork, for example, but to me not worth to sacrifice reliability and quality for a few extra grams less and a lot of $$ less...
    mine's a comin. sitting somewhere in customs while the border people pick their noses. a couple weeks i reckon and it should be here. so. stoked.
    Mar 2013
    Here she is
    It came at 31lb, just what I thought, some may think it would be heavy, but to me is a no compromise build, it's 600gr lighter than my old bike, and I have transferred all the components and now running a coil spring... Superstoked, now time for a first ride
    May 2005
    DVO fork is a few hundred extra grams, otherwise I feel like I have a decently light build. Wheels are also coming in around 1700 grams or so iirc, so a bit heavier than your enves.
    Mar 2013
    No enves on mine, not really up to pay all that money for a brand, they don't offer so much compared to other carbon rims...
    Mar 2013
    Bike is awesome, handles really well, easy to ride, pretty happy after first ride!! Shock is almost dialled
    Nice!! - How do you find the coil? Currently running the monarch debonair but thinking of swapping for a Ohlins TTX coil.
    @Mike640, love the look with those stickers. I've got the black alu with the stock yellow and prefer this. Where did you get them from?
    cheers
    Nov 2013
    [QUOTE=el_guillyt;12570172][IMG]http://uploads.tapatalk
    Nice Build! I'm running coil on my suppressor, love it! Tracks amazingly in the rough stuff. I'm a pretty light rider and was having major spiking issues with the Monarch+.
    http://i63.tinypic.com/2i71cp2.jpg
    Mar 2013
    Coil feels awesome, super supple from the top with nice support in the mid travel, I think it's really appropriate for what I do and the kind of terrain I ride, traction is superb, I think I can't ride anything other than this kind of shock, ridding quality is top top
    good stuff cheers. What sort of terrain/riding are you doing with the coil?
    Do you lose the poppy feeling of the bike at all?
    I will be mostly riding UK stuff from rough DH to woods, snotty roots, mud etc. Also need's to climb as good as it does now with the debonair that sort of thing.
    all the best
    Nov 2013
    I'm running an Avy tuned Fox Van rc so its wide open all the time. I ride mostly South Mountain Arizona, USA. Its one big rock garden, lots of tech, and requires pedaling up in order to enjoy the descends. I personally think a well tuned coil matches the patrol/suppressor very well. Its much more lively, poppy, traction is unreal up and down!
    Nov 2013
    Quote Originally Posted by nibby View Post
    all the best
    In all honesty, I think you loose a marginal amount of pedaling efficiency in certain situations. In my case, I don't have a lock-out, and it pedals just as well as before if you are mindful of your pedaling technique. However, there are times where I have to really stomp on the pedals while out of the saddle and riding up and over rough patches with big rocks in succession, I can tell there is slight inefficiency due to how active the rear link can be. It still climbs techy lines no prob, and feels dialed descending, so i'm happy with the trade-off. Initially, I was looking at the CC CS coil, since on paper it sounds like the perfect solution, but I don't have the patients to deal with reliability issues that seem to plague all the guys I know who've owned CC shocks. Its like 50/50 chance.
    good one, thanks for info. Yes I'm not too concerned on efficiency going up just as long as I can get up Big thing will be how well it tracks and performs going down on the rough stuff, but also want to keep the lively poppy feeling of the bike.
    Hoping to test a Ohlins TTX in the next few weeks and will be able to swap it out for the air shock so should give me the perfect test.
    Nov 2013
    I'm confident you won't want to go back to air. I actually tried the Fox Van fox on my bike before sending it off to Avalanche and it rode like poo. It was like riding on a soggy noodle-no support. Then, I went back to the Monarch while the Van was sent to Avy. Once I got the tuned shock back from Avy, it has been phenomenal! You start to realize how over dampened the Monarch is and how dull air feels. Make sure to report back!
    should be fun finding out , will report back. I'm looking forward to seeing difference. Thanks for feedback.
    Mar 2013
    I ride a wide variety of trails, from muddy greasy rockgardens to fast flowy trails, steep rough stuff, here in north Spain we have cold rainy winters and mellow dry summers, so trail conditions change all over the year, now still cold and wet, and traction is just superb...I used the base settings for DB air on the patrol, added some HSC for start and after first ride had to close HSR because it was to poppy, so that won't be an issue for you, pedal efficiency is fine, I don't do out the saddle climbs and I don't need the CS, it tracks the terrain pretty well without almost any pedalbob
    Mar 2016
    Looks very similar to mine.
  67. #67
    How does that thing ride with the CC cool? Pros/cons?
  68. #68
    Mar 2013
    Pros....all of them, cons....wheigt, no joke, don't have lot of time with it, but I can tell that traction with this is superb, sensitivity off the top through the travel, feels bottomless, plus all extra benefits of the CC, as said, only one con, wheigt, but if you're like me that wheigt is important but not to the extreme...you are good to go
  69. #69
    Very nice! Did you have any saddle time with the Monarch Plus for comparison sake?
  70. #70
    Mar 2013
    Not on this bike, I have a monarch plus debonair on my '12 stumpjumper, and is like day and night, not saying the the monarch is shit, but sensitivity, traction, plushness...it's in another level...
  71. #71
    [QUOTE=el_guillyt;12575753]Not on this bike, I have a monarch plus debonair on my '12 stumpjumper, and is like day and night, not saying the the monarch is shit, but i hear y'all. What fork you running?
  72. #72
    Sorry for the previous post my phone doesn't show anything that I'm typing so it's hard to get it correct. What Ford are you running on that set up? Also what travel? Thanks.
  73. #73
    Mar 2013
    I'm running a revelation dual air on the stumpy, and dvo diamond on the patrol
  74. #74
    Quote Originally Posted by mint355 View Post
    Hey mint
    żAny comment about the fox float x2? Nice?
  75. #75
    Mar 2012
    Quote Originally Posted by AdrianoMTB View Post
    Hey mint
    It was okay... Sold it for a dhx2. The coil is badass!!!
  76. #76
    May 2016
    My New Transition Patrol
    Got my new Patrol Alloy so stoked on this bike, rides amazing.Patrol build thread-img_2284.jpg
  77. #77
    Sep 2004
    Can anyone recommend a good paint colour match for the patrol orange frame. I am in the uk. Looking for some paint to touch a frame up.
  78. #78
    Well here is mine!
  79. #79
    Sconkers
    Yeah be interested to know about the 170mm fork. Did you ever find out if it worked?
  80. #80
    Ford ST ELECTRIC ORANGE Touch Up Paint is a very close match, I got a bottle of e-bay and its very usefulll.
  81. #81
    Oct 2011
    Finally the bike is complete. X2 cs installed two days ago, took it out yesterday and it felt amazing. Still dialing it in a bit, but a huge upgrade so far.
    Build highlights:
    Fork: Lyrik 170mm
    Shock: Float X2 climb switch
    Wheels: Flows Hope 4
    Tires: DHF 2.5/ DHR II 2.3
    Handlebars: Enve hi rise
    Cassette: X01 11sp
  82. #82
    Here´s mine....
    Basically the best enduro bike out there nowadays.....
    pd: With coil.. it´s blow away each bike of the market...
    Patrol build thread-img_20160521_191328.jpgPatrol build thread-img_20160521_191338.jpgPatrol build thread-img_20160521_191349.jpg
  83. #83
    I agree and also about the coil I've also gone stealth and broke out the gaffer tape. Here's mine.
  84. #84
    Mar 2016
    Awesome Nibby!! Where did you get that shock, and how it works with the Patrol?
  85. #85
    Got it from a local tuner Mike, he sent me one to test for a few days and well that was enough!! It allowed me to test back to back with the air and for the type of riding I like doing it was and is fantastic. The best thing I can say about it is that you just don't get any dramas, sort of does everything very very well without you thinking "wow" if that makes sense.
    I seem to be pulled towards the rougher types of trail and after three runs with the air on a particular tough one I was knackered, come back to it with the Coil and could have kept going and going, was less fatigued.
    Doesn't climb as well as the air but tbh it is still pretty good and nowhere near enough for me to want to switch back.
    For the less rough trails the air is still pretty good and tbh the air is still good enough for the rough stuff but the coil just allows me to push it a bit more with less fatigue.
    If that makes sense??
  86. #86
    Jun 2010
    Just curious..
    Has anyone who has done a custom build used a 51mm offset fork on their Patrol?
    If so, any chance you did a comparo with a "normal offset" fork?
    Wondering about that.
  87. #87
    Mar 2016
    Nibby, it makes very sense! But here in Portugal, we spent a lot of time climbing.... :/ I have never seen ohlins material for sale here.... I have very curiosity about the STX 22...
  88. #88
    Reputation: Luigiugueto's Avatar
    Oct 2007
    One question: How do you guys remove/change the decals???
  89. #89
    Oct 2011
    Quote Originally Posted by Luigiugueto View Post
    I trace the existing decal with a pencil then peel it off with my fingernails. Match new decals with pencil outline and voila.
  90. #90
    Jun 2012
    So I am very pumped to say I should have my new carbon patrol this week, maybe..... Shipping depending.
    Level 2 build. Plan on my choice of bars and stem but curious what shock of choice. I plan to set up the monarch plus on the firmer side with token. I am familiar with the monarch plus, but would like to look at having a coil shock to try. And use for the more aggressive places. Any suggestions best option yet, Is it specific sizing or are you all making somethine else fit. Any fox/CC/rockshox suggestions on fork shock combo?
    Thanks I'll do my best to keep reading and searching and catch up. Selling off my stumpjumper for this puppy so hope its as fun as I expect
  91. #91
    Oct 2007
    I thought they were under clearcoat or something. Is it really that simple?
  92. #92
    Oct 2011
    Whoops! Thought I read you wanted fork decals. Hahaha. Yeah, I think folks are putting decals over existing ones
  93. #93
    Reputation: jmountain's Avatar
    Where are you guys getting the decals from? I did find a couple searching on Google, just wondering if they are the same place.
    Sent from my LG-D850 using Tapatalk
    "Let the wheels spin."
  94. #94
    Nov 2015
    Has anyone tried to put Maxxis Rekon+ and ikon+?
    Do you think they will fit??
  95. #95
    May 2013
    Quote Originally Posted by jmountain View Post
    Got mine from there, pretty responsive. An a little bigger than the originals, to cover it perfectly.
    http://nldesigns.eu/index.html
    Regards
  96. #96
    There's my rig.
    Been riding it since April and loving it more everyday.
    I have been seeking an alternative shock, but keep having some fitment issues.
    DBAir CS won't fit, either X-Fusion Vector.. Do you have any suggestions.?
    Push would have the medicine, but you should really have deep pockets.
  97. #97
    Regards
    Thanks, I had not found them so far in my search.
  98. #98
    Jun 2014
    Just fitted up an RC4 coil with a 400# Ti spring (bang-on 35% sag for a 185# rider btw). Screw the air shock. Almost the same climbing performance and TONS better descending performance. Measured about 1/2lb - 3/4lb of weight gain for it. Worth every bit.
    Now if I could get this Fox 36 Float feeling like something besides a goddamn 2x4, I'd be golden.
  99. #99
    Reputation: Jeremy R's Avatar
    Any Fox X2 float users want to share their settings on the Patrol? Thx.
    Sent from my Nexus 6P using Tapatalk
    SEI Racing
  100. #100
    Mar 2016
    Quadro, The CCDB fits the patrol Frame...
    http://p.vitalmtb.com/photos/users/2...jpg?1424210760
  1. ASR-7 Build Thread
    By belljeffw in forum Yeti
    Last Post: 3 Weeks Ago, 02:09 AM
  2. SB 95 Build Thread?
    By yorkn in forum Yeti
    Last Post: 04-25-2017, 08:53 AM
  3. G-reg Build Thread
    By G-reg in forum Frame Building
    Last Post: 08-03-2015, 05:59 AM
  4. Les 275 build thread
    By mtbmitch2 in forum Pivot Cycles
    Last Post: 02-14-2014, 04:01 PM
  5. First SS build thread
    By Fakie1999 in forum Singlespeed
    Last Post: 07-30-2011, 04:30 PM
Members who have read this thread: 225
