Page 3 of 4 FirstFirst 1234 LastLast
Results 201 to 300 of 325
  1. #201
    Aug 2013
    Last part of my build. How do you guys get the cable housing for the dropper through the bend above the BB?
  2. #202
    Quote Originally Posted by rorhound View Post
    I have a Fall Line on my Patrol, so I threaded the cable through the frame first, making the housing slide through slick as shit
  3. #203
    Oct 2016
    Does anybody of you need a brand new Float X 230 x 65 mm for the 2017 Patrol?
    Shipping from Germany.
  4. #204
    Reputation: bullit43's Avatar
    Dec 2010
    Patrol frame uses 216mm eye to eye
  5. #205
    Quote Originally Posted by bullit43 View Post
    The 2017 one does not. It uses a 230x65 shock.
  6. #206
    Dec 2010
    Quote Originally Posted by Rick Draper View Post
    Metric
  7. #207
    Oct 2016
    Some of the frames do even have metric bushings - which are not available for aftermarket right now. Bike industry seems to be more about marketing than realizing products... 😏
  8. #208
    Has anyone tried fitting Hope brakes with their braided hoses in the Carbon Patrol? I'm worried that the hose diameter would be too large for the TITS on the frame.
    Thanks,
    Eric
  9. #209
    The Crow
    Reputation: Iwan's Avatar
    Transition Patrol Carbon custom build
    Have a look at this custom build from South Africa
    https://www.bikehub.co.za/features/_...om-build-r6226
    There's a feeling I get
    When I look to the West
    And my spirit is crying for leaving
  10. #210
    Feb 2016
    I've been riding my 2017 metric patrol for a little while now and have to say it's great. I just fitted a rockguardz carbon protector ( they are still moulded for the 2016 but fits ok) I'm hoping fox do the X2 in metric sizing soon.
  11. #211
    bad reputation
    Reputation: turfnsurf's Avatar
    Nov 2007
    Quote Originally Posted by Sam Adam View Post
    One week on my 2016 build. Threw an X2 on it Friday night and tested it out yesterday and it's a definite improvement. Gonna add a spacer today and see how that feels.
  12. #212
    Feb 2016
    Nice, looking good !! Plus as bad as it's sounds the rockshock doesn't look right as everything else is fox lol. Once I've done that I'm going to give some nextie carbon rims a blast.
  13. #213
    Feb 2016
    Well like a couple of you I am waiting for the metric X2 to be released. I stubble over this recently and followed it up at the source. They are currently being used for by teams.Apparently the upgrade will be available in May !!!
  14. #214
    ^ Metric X2's are available already in some countries. Should be out later this month in the U.K.
  15. #215
    Apr 2014
    Hello,
    A question to 2017 Patrol owners:
    What is your weight and super deluxe inflation pressure?
    I weight 170lbs w/ riding gear but somehow get 35% sag on 140psi
    I know its usually the psi equivalent of the weight (My Scout was 170psi for example) or has this got something to do with the super deluxe?
    I personally prefer a slightly stiffer setup but then I'm getting less than the recommended sag
    Appreciate your input
  16. #216
    I'm very nearly the same as you. Sucks, because with the shock down on psi to get the right sag, and right riding characteristics, I bottom out fairly frequently which my rear rim does not like one bit.
    Cannot wait until DVO releases the Topaz in metric so I can pair it with the Diamond up front
  17. #217
    Jun 2014
    I'm 190lb before gear and I run 140psi on the Super Deluxe to get 35% sag. Seems way low but it works well. I feel like it could use another bottom-out spacer or something, if that's even an option for these shocks.
    Edit: Remember, there is more piston area on this shock than with the Monarch. There is no inner "sleeve", so the piston face is going all the way to the outer wall of the shock. Same force, more area, less pounds per square inch.
  18. #218
    Feb 2013
    I currently have a fox 36 160mm on my patrol just wondering how you guys like running 170mm ? I might be switching over to a mrp ribbon and if i do i plan on going 170mm... any complaints? Has anyone run both? I wouldn't mind the extra 10mm of height I'm thinking it would make the front end ride a little higher in the travel...
  19. #219
    Quote Originally Posted by Njhardrock View Post
    Here is my bike with a 170mm Lyrik. I have since switch to a 160mm 36. For me and my trails the extra 10mm felt like I was wandering the front end to much on the climbs. 160mm will pull you more forward on the bike keeping that front wheel down. The 170mm will feel like your sitting on the back wheel more. Both has its plus and minus.
    As far as your front end riding higher in the travel you may want to stiffen up your fork settings to allow it to ride higher but you would most likely be sacrificing suppleness and small bump.
  20. #220
    Feb 2016
    What sort of differences have you guys noticed when changed out your rear shock for an X2?
  21. #221
    Feb 2013
    Quote Originally Posted by vsong View Post
    Thanks... yea I have a tuned the fork with 2 spacers and every setting imaginable... i feel like the 160 wanders on climbs anyway so why not try and let this bike be good at what it does... go down....thanks for your feedback it's much appreciated
  22. #222
    Feb 2013
    I have a x2 on my patrol... definitely a improvement over the same stock shock
  23. #223
    Feb 2016
    What sort of improvements? Did the pedalling improve and climbing with increased descending ability ?
  24. #224
    Feb 2013
    It bobs less... the ramp up can be made slightly more progressive... I barely use my climb switch... i still wish i went coil but it's definitely better
  25. #225
    Feb 2013
    Anyone else on the 170mm vs 160mm fork debate?
  26. #226
    Reputation: Calhoun's Avatar
    Nov 2008
    What's the debate? You like travel, get it.
    No negative effect on climbing.
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
  27. #227
    Feb 2016
    Awesome morning yesterday on dusty trails. Can't wait to wack a metric X2 on this bad boy. Uplift day this Sunday for a real test as well.
  28. #228
    Reputation: MikeBurnsie's Avatar
    Jan 2011
    Finally finished my build. Taking it out this afternoon to tune it in.
    2016 Transition Patrol
    2011 Stump Jumper
    2018 NukeProof Scout
  29. #229
    Nov 2008
    Spending more time on the Patrol lately and loving it. Bike is great in the chunk and have yet to feel like I'm being held back. Just picked up the Float X2 and feel like I'm 80% dialed with my settings.
    -cabra cadabra
  30. #230
    Feb 2016
    Does anyone on here own an XL they can post a picture of I'm considering sizing up
  31. #231
    Sam Adam,
    See post #155. I've made a few changes but the frame is an XL.
    Eric
  32. #232
    May 2017
    Hi guys, how would this bike be for trail/enduro? I need a bike good for technical rocky stuff but that can still decend and climb. (Looking at used 2015 Patrol 3)
  33. #233
    Feb 2013
    So after having my patrol for about a year now and riding several other horst link bikes i gotta say... my patrol rides harsh in the rear....I've upgraded to a float x2 and i still cannot make this bike feel good... i don't understand it honestly... whenever i can get my sag to 35-40% it feels ok but then i gobble up the travel and it still doesn't seem great uptop.. I am honestly just to the point of saying maybe this frame isn't for me because i have hopped on several bikes without tuning the suspension that made me smile more and beat me up less... i am a light rider... but now i have all the spacers installed in my x2 i get the sag 35ish and its just ruff..but then I don't bottom out i have even contacted avalanche and they seem to think they can tune the shock .... it's like I can't have plush and not bottoming out... please any suggestions?
  34. #234
    May 2017
    Get a Quarq Shockwiz. (Or rent one for the day from your LBS they are a little pricey) They are little computers that set your suspension to the perfect settings for you (rebound sag and the works). You can choice between a bunch of different options to. They are great.
  35. #235
    exciting times for you, new bike on the way!
  36. #236
    Feb 2016
    To be honest I can really see much I would buy over the Patrol at the moment. I'm really close to changing it for an Evil calling but to be fair I'm not sure I'm going to gain that much in additional pedalling efficiency or climbing. I'm thinking of getting carbon wheels and a metric X2. For a 160 bike the patrol is a very good all rounder. I do regret getting rid of my yeti 5.5 though
  37. #237
    Feb 2013
    Thanks... but what is this shock tuner going to do for me at this point? I've literally dialed in every setting and changed spacers 4 times... i know this is a low leverage bike but im starting to think it's just not the bike for me...I've had a heckler that beat me up less then this bike....I've tried to tune the monarch and the x2 for months now.... and honestly it's effecting my confidence on jumps because this bike just pogo's me... i just demo'd another brand horst link and felt more comfortable on a bike i was on for 10 minutes... this bike rails berms and is poppy ill give it that but i feel i loose plush for poppy... Totally frustrating and disappointing after i year of owning this bike to constantly have to mess with aomthing and it never feels right
  38. #238
    Feb 2010
    My experience is with completely different bikes and I'm also heavy rider, but for me lots of spacers turned my bike into hardtail. Now I try to use as few spacers as possible, use higher pressure to control the bottom out and reduce HSC to get back the sensitivity over smaller stuff. You must get the LSR and HSR balance right to avoid pogoing and packing.
  39. #239
    Feb 2013
    Appreciate the feedback... i was thinking the same thing so i dialed it back to 1 spacer at a point in the float x2 set the sag... felt better then i bottomed on big hits and drops...so i felt like ok let me try and go the opposite way more spacers.... right now im running low pressure all
    The spacers i can ... feels ok... got low speed rebound slow high speed open pretty much.... going to ride right now and see what happens when i hit some drops ...i feel like my body weight and the fact im light on my feet as a rider is making this tuff for me... it's not like i am hating on the bike because theres a ton i love about this frame and company... but you build a bike to have fun not screw with it constantly... thanks again for the feedback I really do appreciate it!!
  40. #240
    Feb 2016
    This is probably going to sound condescending but don't take it that way, have you thought at calling the techs at Mojo. I did recently regarding some tips on my forks. I've got to say they were really helpful and it helped me transform my forks. Worth a call .
  41. #241
    Feb 2010
    Hmm. I would suggest you to try to speed up the low speed rebound - if it is slow the shock is packing up and feels harsh. Then, as you open the low speed rebound compensate by closing the high speed rebound otherwise the shock is going to kick you out of saddle during bigger compressions.
  42. #242
    Reputation: cheezwhip's Avatar
    Where are you UK guys getting your Metric X2's?
    ¡Geaux Tigers! - ¡Visca el Barça!
    "Finer than frog hair!" - Lumberjack
  43. #243
    Feb 2016
    Patrol build thread
    They aren't out in the UK yet. The pictures you are seeing are team custom made shocks. The production models aren't actually released yet in the UK
  44. #244
    Quote Originally Posted by cheezwhip View Post
    Germany.
  45. #245
    May 2017
    Hey guys!
    Some super nice builds in this thread.
    I just ordered my Patrol frame today which will take about two weeks to get here (live in Australia and supplier had none in stock in my size so gotta get one from the states).
    Anyway will post pics as I build it up. Quick run down on spec will be 160mm lyrik, xt/xtr gearing, nextie Carbon wheel set and bikeyoke/KS dropper.
    Just wondering what sort of frame protection you guys are using and what bits need it the most!
    Thanks in advance!
  46. #246
    Reputation: bikeboardorblade's Avatar
    Lately I've been going to places that do car tint and been getting scraps of 3M Clear bra. It might take a bit longer as it isn't already cut for size, but for free fifty I'm happy with it.
    Sent from my XT1650 using Tapatalk
  47. #247
    May 2014
    Going to have a build coming up. Transfering parts from my N3 over to a used Patrol Carbon frame in blue. Going to get some custom pink decals so, it will be the same colours as my old Nomad 38mm carbon rims, saint brakes, 160 Pikes, X01 running gear, enve stem and bars, 150 KS lev. Should be awesome Looking forward to the longer reach.
    Also looking into long shocking it........I have my flame suit on.
  48. #248
    May 2014
    Hey guys, getting the parts lined up for my new Carbon patrol build, quick questions, what rear brake mount do I need for a Shimano Saint Caliper with a 203 rotor? I've ordered one of these, but not sure if it's correct.
    Thanks from Australia
  49. #249
    Jan 2016
    Here's my 2016 Patrol Build 3 with few ANVL upgrades, SRAM X1 cassette/chain and relaced wheels with Stan's FLOW Mk3 rims because I manage to kill the front stock WTB i25 rim coming in too fast in a burm right after a jump...
    Now their's already two good dents in the rear FLOW Mk3 after beeing enthusiastic with lower pressure (25/28psi F/R). It seems like Minions 2.3 isn't a good match for the 30mm rims... :/
    I've run 27/30psi F/R since I've managed to re-mount the DHR2 tubeless despite the dents and a cutted sidewall repaired with tire patchs and strings... that evil machine rips wheels & tires!
    So I couldn't resist for a new CRC ARC30/Hope Pro 4 wheelset on sale to mount WT Minions on them! I want my lower pressure back and hopefully, no more dents...
    Patrol build thread-p5pb13946684.jpgPatrol build thread-p5pb13946682.jpgPatrol build thread-p5pb13946681.jpg
    2016 Transition Patrol 3 (Satan's AM ride)
    2016 RSD Mayor (winter Fatbike)
    2016 RSD Mayor (29+, summer setup)
    2016 RSD Catalyst (700+, gravel & commuter)
    2013 Felt Breed (SSCX, winter commuter)
    2010 NS Bike Metropolis (DJ, bmx, pump track)
  50. #250
    May 2017
    Finished my build of my 2017 patrol carbon. Took it for a quick ride last night on some local trails and was quite impressed even without having the suspension set up properly.
    Specs for the build are
    Frame: 17 Patrol Carbon in XL with rockshox super deluxe rc3
    Fork: 17 Rockshox Lyrik RCT3 160mm
    Wheels: Nextie 35mm carbon rims laced to DT swiss 350 hubs
    Tyres: Magic Mary Front/Ardent Rear.
    Gearing: Shimano XT cranks in 170mm, XT chain and XT cranks. XTR Shifter and Derailleur.
    Brakes: Shimano XT 203/180 rotors
    Seat post: Bikeyoke Revive 160mm drop
    seat: Fabric scoop shallow carbon
    Bar/Stem: Deity TMO bars in 760mm/ Deity Copperhead Stem 35mm (redmonkey Silicone lock grips)
    Pedals: HT T1
    eventually plan on putting some Saint Callipers on with the XT levers and upgrading the cranks to Raceface next G4's But the XT's will do for now.
    Tipped the scales at 13.6KG's with pedals, Which isn't to bad for an XL frame.
    Keen to get out there on it more now!!
  51. #251
    May 2014
    First ride on the Patrol yesterday, coming from a N3.
    Felt ok, havent touched the shock settings yet. Def a bit more active under pedalling then the Nomad, but maybe a couple of clicks of LSC will help that. But the trade off is the patrol felt better/softer when pedalling over roots etc.
    Some pretty loud chainslap in the rough stuff, had read it's meant to be very quiet, I better double check everything is done up tight! Also did some custom cable routing as I'm not a fan of the brake cable exiting the front of the bike the same side as the lever (im in Australia).
    Looking forward to getting it setup, any tips on setup with the DHx2? Bottomed it out pretty hard a couple of times, might need some more HSC.
  52. #252
    Fit a stiffer spring
  53. #253
    May 2014
    Quote Originally Posted by POAH View Post
  54. #254
    May 2017
    Quote Originally Posted by B Rabbit View Post
    Happy to join the Transition family Click image for larger version.
    Surprised your feeling movement in the suspension while pedaling... Im almost 200 pounds and dont get any bob. It's probably just your settings. And for the noise wrap a layer of electrical tape or 3m velcro over the chain stay protector. This seemed to help me BUT I realized a lot of the noise actually comes from the internal cable routing.
    Enjoy the bike!
  55. #255
    May 2014
    Quote Originally Posted by SnoowMTB View Post
    Enjoy the bike!
    Thanks had a look at the DHx2 settings and since I hadnt changed anything since the Nomad I was def off with the settings. The Nomad recommended settings were around 11-13 clicks for the rebound and compression, when I looked up the chart for the Patrols travel most of the settings are in the 16 range, probably explains it
    But I'm actually giving an X2 a go for the weekend, any tips on setup? I've got 150psi in for my weight of 75kgs/165lbs, around 33% sag. As per the fox chart I've set the shock to 16-20 clicks, is this the range other people have landed at for a similar weight? I've only got the weekend with the shock and want to get as dialed as possible, as quick as possible to see if I want to go down that route as opposed to the coil
    May 2017
    Nice! I've never ridden an X2 so I cant help ya You raelly cant go wrong either way though.
  57. #257
    Feb 2016
    Yes that is what you will need. 2 of them if you need one for your fork as well. (at least thats what my pike used)
  58. #258
    Reputation: bajaguy's Avatar
    I heft hut
  59. #259
    Aug 2013
    Look at the Fox chart and notice it goes from 150mm travel to 160mm travel. The difference between those two is 6 clicks (I think it's 6 clicks not having the book in front of me). The patrol is 155mm so my starting point was 3 clicks less than 160mm and/or 3 clicks more than the 150mm travel recommendation. I've fine tuned from there but it felt way better to begin with.
    That being said, I love the way it feels with the DHX2. Very planted and much more predictable from the stock RS (2016 Patrol). I've paired it with a MRP Ribbon fork and now I have a whole new bike again!
  60. #260
    Feb 2017
    My 2016 Transition Patrol
    Just got a 2016 demo Transition Patrol. Pretty much all stock at this point. Just got back from my 2nd ride and had a ton of pedal strikes and a few bashes on the chain/chainring. Anyone using a bashguard and have a recommendation? I'm looking at the MRP XCg. Thanks!
  61. #261
    May 2017
    Quote Originally Posted by kablamo View Post
    I use the e13 LG1+ ISCG05. It works as a chain guide as well as a bash guard and has saved my ass so many times. Really durable and strong as well. No complaints other than the $160 price tag...
  62. #262
    May 2014
    Quick a pic of where it stands at the moment I missed my old Nomad colours haha
    Only had 1 ride on it so far, got held up the last 2 weekends
    Should get some shuttle action in this weekend.
  63. #263
    Dec 2010
    Set the one up components,cheaper and much less bulky
  64. #264
    Nov 2008
    Pretty cool colors, what is with the cable not routed internally? is that your brake line?
    -cabra cadabra
  65. #265
    May 2014
    Yep, being in Australia the internal routing put the brake cable out on the same side of the lever, pet peeve of mine so I decided to run it externally for now, still need to get some jagwire stick on guides to tidy it up.
    Pretty happy with the colors
  66. #266
    Nov 2008
    Gotcha.
    I also run my brakes moto but the cable exiting from the same side doesn't bother me.
    -cabra cadabra
  67. #267
    Jul 2017
    My first completely new bike this century....
    Finishing up the NLDesigns decals this evening.
    I'm calling it Galactic Grey.
    More photos tomorrow.
  68. #268
    Reputation: Macharza's Avatar
    Jun 2013
    Here's my Patrol. I switched from Scout and move all the parts to this bike.
    Very satisfied
    Attached Thumbnails Attached Thumbnails Patrol build thread-img_20170830_182233.jpg
  69. #269
    Feb 2017
    Do you have enough mileage in on the Patrol to compare the Scout to it? I debated a Scout but never rode one.
  70. #270
    Jun 2013
    If you ride places like me, roots and rocks I prefer Patrol.
    It still climbs well vs. Scout, is playful like Scout, but descent better and the new Deluxe shock is good.
    My opinion, that it save your energy, because you can ride it slower and it still goes over the rocks and roots well.
    But it depends where you mostly ride. At smooth trails, Scout is so good
  71. #271
    Mar 2016
    Quote Originally Posted by Macharza View Post
    Very satisfied
    Just picked up a 2017 Patrol demo bike that looks like this. Lowest part spec (Patrol 4) though, so I'm coming at my build from the opposite end of most of you. ETA Part spec here: https://www.transitionbikes.com/Bikes_Patrol.cfm
    Here's what I'm thinking for upgrades in order of purchase - seem like a good order of operations?
    - Charger Damper, dropped into the Yari stock shock
    - flat pedals, replacing my XT SPDs (going flaaaaat)
    - Dropper, 150mm travel. Any recs? Reverb Stealth?
    - What should be next on my list? Hubs? Rims?
    Very fun ride. I'm coming off Canfield Yelli Screamy (29 HT), so the Patrol is pretty darn plush and fun in comparison. It is very long and low, though, so that takes some getting used to - way more pedal strike than I've ever had, but that's probably rider error.
  72. #272
    Feb 2010
    Quote Originally Posted by meter-man View Post
    Bikeyoke Revive 160mm. There is thread at Components forum.
  73. #273
    Feb 2017
    - Charger Damper, upgrading the Yari stock shock
    You'll get used to the pedal strikes as you adapt your riding stle they become few and far between. I had the same issue adjusting to the geometry. Dropper - I'm partial to the KS Lev.
    Wheeels etc don't bother until you break something!
  74. #274
    Quote Originally Posted by arnea View Post
    Seconded. Get a Revive.
  75. #275
    Jun 2013
    Quote Originally Posted by toodles View Post
    If you can order this Brand-X dropper, it's an excellent choice. Look at the reviews brand-x+dropper+seatpostÂ* | Chain Reaction Cycles
  76. #276
    Stand back
    Reputation: dbabuser's Avatar
    Just starting my build. Hopefully I'll have the wheels done today. Large '17 carbon in blue, with Spank Oozy Trail 345/ DT 240, 160 1yrik, Guide rsc, XT 10 speed drivetrain, Reverb 150, Easton Haven bars/ stem. Still need to get tires...
    Golden Bike Park
    Golden Connector Trails need your support!
  77. #277
    Stand back
    Who made the decals for you? Nice job with the overlay, you can't see any of the black underneath.
    Golden Bike Park
  78. #278
    Jan 2017
    Dear metric frame users,
    Has anyone tried fitting 240x76 coil shock but with some internal 10mm spacer to get it close to 230x65?
    Thinking of throwing in very cheap used Fox Van R 240x76 shock to find out if coil works for me. All my bikes were with air shocks.
    Thanks.
  79. #279
    Now with flavor!!
    Reputation: kidwoo's Avatar
    Quote Originally Posted by prosto_mtb View Post
    Yup. Just did this with a dhx2. Call go ride and ask for Cody. He does rebuilds. I sent him the spacers, a small shaft collar and some plastic washers from ace. The shaft is 8mm, The innner shock tube is (I think) just under an inch. Verify that last bit to be sure when you call. That's if you go dhx2. If you get a Van R, that's different obviously.
    And just FYI: https://www.probikesupply.com/collec...g-not-included
    STRAVA: Enabling dorks everywhere to get trails shut down........ all for the sake of a race on the internet.
  80. #280
    Jun 2013
    Question about the chain line.
    How many spacers you have under the bottom bracket? I'm using Shimano XT bottom bracket and one-ring setup RaceFace Atlas cranks. 11-speed cassette setup
  81. #281
    Thanks.
    Doesn't really work with a Van R as any spacer would likely block or severely restrict the rebound needle port on the shaft. You can do it easily on a DB Coil, DHX2, Ohlins etc
  82. #282
    aaarrrggghh!
    Reputation: Ivan the Terrible's Avatar
    Slightly custom build
    Patrol build thread-img_7677.jpgHere is a pic of my recently build carbon Patrol. I took the parts from my alloy Patrol and slapped them on my new carbon frame. The bike feels about 10% better everywhere compared with the alloy version.
    My only complaint is the noise associated with this bike. I have put mastic tape everywhere the chain may come in contact with the frame but still get some clatter when hitting a series of bumps, like braking bumps. Otherwise, this bike is great.
  83. #283
    Jun 2013
    Read this thread, hope it helps Scout, Patrol ect... Cable Noise Fix!!!!
  84. #284
    aaarrrggghh!
    Thanks for the info but in this case it is not the cables rattling around. I have the dropper post running through foam tubing to quiet that down and the other cables are run through the T.I.T.S setup.
  85. #285
    Feb 2013
    So after about a year riding this bike i have a float x2 on it currently... better but not great... thinking of going coil for next season....
    How do you coil guys like the feel on this bike? Mine is a non metric version..... i would either go fox dhx2 or push 11/6.....
    Option 2 is send the floatx2 I have currently to avalanche and have them revalve it for $250
    Any input would be appreciated from guys who went from. Air to coil on this frame
  86. #286
    so the float x2 is the world's finest downhill air shock. you say it's not great and are looking for improvements. as a Patrol owner with the stock Monarch plus, i'm dying to know- what's not great about it and what would Avy do to improve it?
  87. #287
    Jan 2017
    Sounds like there is something wrong with your setup. Buy ShockWiz. Problem solved.
    How revalving will help with wide range R2C2 shock?
  88. #288
    Sep 2004
    Quote Originally Posted by MikeBurnsie View Post
    do these decals come off or are they lacquered over?
  89. #289
    Quote Originally Posted by mrback View Post
    Mine came off with a bit of acetone really easy.
  90. #290
    Feb 2013
    Nothing wrong with my setup... transition actually doesn't recommend the floatx2 since you can't run 4 spacers anymore in that shock... therefore you can't achieve proper sag without bottom out and vise versa... shoot them a email they will tell you the same thing because thats who told me after i noticed I couldn't get one or the other...
    So back to my original question people who have gone air to coil... as per transition recommendation...
    How does it feel? Thanks
  91. #291
    Jul 2017
    I'll let you know next week
  92. #292
    Jan 2017
    You can always reduce air chamber adding some grease here. But it's up to you, if buying new shock is easier
    Sent from my Nexus 5 using Tapatalk
  93. #293
    Feb 2013
    Awesome thanks man definitely give me a update i would greatly appreciate it!!!!!
    As for adding grease... never heard of it being done but it's worth a shot ... just really sucks I can't throw another spacer in there... what kind of grease? Any video or information would be great ... i was even thinking i could use rubber bands around the thing that won't allow you to put more spacers in... has that been done?
  94. #294
    Oct 2011
    2018 XL Ponderosa
    GX Build with:
    Next G4 170 cranks
    RF NW 32 tooth
    Chromag Ranger 40mm Stem
    RF Next 19mm rise handlebar
    VP Harrier pedals
    33lbs with pedals
    Attached Thumbnails Attached Thumbnails Patrol build thread-d867e1b6-44b4-43f2-8e2b-6d7d07414432.jpg
  95. #295
    ride
    Reputation: ignazjr's Avatar
    We got our first 2018 Patrol in (GX Build). Thought some of you would appreciate the pic. This is a super sweet bike!
    Patrol build thread-img_20171025_115954984.jpgPatrol build thread-img_20171026_104744622.jpgPatrol build thread-img_20171026_104904756.jpgPatrol build thread-img_20171026_104837049.jpgPatrol build thread-img_20171026_104826470.jpg
    pulled the shock mount bolt out so you can see the trunion mount.
    Attached Thumbnails Attached Thumbnails Patrol build thread-img_20171026_162238106.jpg
    Redstone Cyclery
    intense*transition*rocky mountain*turner
    web - tweet - FB
    Lyons, CO
  96. #296
    super cool, first one in here. that's the colour i want. how tall are you Smitty? i've got an XL 2016 alloy, love it. more photos and ride impressions when you get a chance.
    i was in a shop yesterday and they were awaiting the first Cdn shipment that day, with most bikes pre-ordered and customers waiting. the stoke was high.
  97. #297
    Oct 2011
    Quote Originally Posted by cunningstunts View Post
    I’m 6’4. Owned 2 2016 Patrols (AL & Carbon). Most comfortable bike I’d ever been on. Switched to a Wreckoning and wanted to come back and try the new geo. Have had a wrist injury for the last 3 months, but took it out a couple of days ago anyway. Wrist is not happy. Anyways, the first thing I noticed was how well it climbs. It’s 33 pounds, but damn, it’s spirited on the ups. Coming from the big hoops with a higher stack, I felt a bit off on the whole ride. Need more time to get reacquainted with the bike. Going for higher rise bars too. Felt plush, but more fiddling with suspension is required. Reach does NOT feel any longer than before, seriously. If you like the previous gen XL, stay on the XL. Easy to manual and get off the ground. Unfortunately I’m taking time off to rest the wrist more...only rode it at 75% so take my impressions under those assumptions.
  98. #298
    sorry to hear about the wrist. must be frustrating with the new bike in the house. Smitty, how would you compare the original Patrol (2 of them, wow) with the Wreckoning? do you give up much if anything to the bigger wheeled bike?
  99. #299
    Oct 2011
    I’ve never felt as comfortable on a bike than I did on the aluminum Patrol. The weight of it over the carbon made all the difference for me in a positive way. Attempted and landed way bigger jumps on it due to the fit. The Wreckoning is just a flat out beast. Big tires just rubble over terrain and it jumped pretty dang well. These big wheeled bikes today give up very little. Both fantastic bikes!
  100. #300
    I have a couple rides now on my new patrol, this bike is awesome! I am coming from a evil insurgent, and the biggest difference is the front wheel is so much more planted and the bike corners so much more naturally. Bike handles awesome, and the factory build kit is very well spec’d. Only changes I made were sc carbon reserve i9 wheels with cushcore and minions f+r, and a 35mm chromag bza stem.
  1. ASR-7 Build Thread
    By belljeffw in forum Yeti
    Last Post: 12-30-2017, 02:09 AM
  2. SB 95 Build Thread?
    By yorkn in forum Yeti
    Last Post: 04-25-2017, 08:53 AM
  3. G-reg Build Thread
    By G-reg in forum Frame Building
    Last Post: 08-03-2015, 05:59 AM
  4. Les 275 build thread
    By mtbmitch2 in forum Pivot Cycles
    Last Post: 02-14-2014, 04:01 PM
  5. First SS build thread
    By Fakie1999 in forum Singlespeed
    Last Post: 07-30-2011, 04:30 PM
Members who have read this thread: 148
