Results 1 to 23 of 23
    Sep 2004
    Patrol 2018 Paint job
    Are the paint jobs on Transitions historically bad? I am still in the process of building my 2018 Patrol & already have paint chips & not even been ridden in anger yet. I know they are only superficial but still a bit poor I think. I would have gone with the other colour if I'd known it was this matte/satin type paint job.
    Reputation: skiahh's Avatar
    Have you called Transition?
    Sep 2004
    Hi
    I cant really call them as I am in the UK. I have emailed them though & currently await a response.
    Nov 2006
    "Are the paint jobs on Transitions historically bad?"
    In my experience, yes. I've had a Smuggler and a Scout, both black and among the least durable finishes I've had on a bike.
    Reputation: 1996cc's Avatar
    My Ponderosa Green patrol had a chip on the linkage when I got it from the dealer. Also noticed that they masked it off horribly at the factory, and there is some green overspray in the black sections. My frame is all glossy though, not matte finish. I can be super anal retentive in stuff like this, but I just shrugged it off cause itíll get scratched, etc. just adds character I guess.
    2018 Transition Patrol
    May 2013
    I guess everything needs it's time - it took years for TR to add downtube protectors and >1$ bearings to their frames; maybe in 5y+ they will improve the painting.
    Don't get me wrong, I love their bikes, but in some areas ( the non "giddy up, SBG..." things) they are too careless imho.
    Nov 2006
    I just think they cut corners/cost on the finishes vs critical mechanical components... not necessarily a problem but I don't really mind if my bikes stay looking like new.
    I kinda wish they'd just cut cost in the form of all the stripey graphics and go with a less busy slightly higher quality finish.
    Jun 2010
    Quote Originally Posted by Ganderson View Post
    Agreed on the " less busy, slightly higher quality finish "
    Just went out for a pre ride chain lube and noticed that I'm missing all sorts of paint after about 5-7 rides on my new Sentinel. I'm not entirely shocked because my past couple of Scouts chipped easily as well. This new Sentinel might be the worst yet though based on what I'm seeing after just a few rides.
    Apr 2015
    Could you please post some photos?
    Reputation: David R's Avatar
    Can't beat a raw finish on an aluminium frame, really wishing I'd chosen that option for my current Knolly.
    May 2013
    Which mech. components do you mean?
    There were a lot of Patrols with misaligned shock mount (mine was also affected), not properly reamed/faced (how do u say?) seat tubes, bone-dry bearings (was almost epidemic @the carbon model), etc.... Since other frames also break I won't mention all the broken seat/chain stays.
    The 2016 Patrol frame was 1800Ä, the new one is 2100Ä - for alloy, mind you. Cut costs?
    Even if you can fix a lot of these and other things on your own (grease bearings, ream seat tube, tape frame etc), I ask myself if they have an ape employed which applies the "QC" sticker on the bottom bracket.
    Nov 2006
    Quote Originally Posted by aenduro View Post
    Well then I stand corrected. Iíve personally not had mechanical quality issues on either of my Transitions and I havenít seen a lot of complaints.
    Asian Mfg. is tricky. Even if you partner with a top notch factory you basically have to personally supervise every production run all the way through to final QC. I actually have first hand experience playing this role for a previous employer (not bikes). Itís incredible the mistakes they will make, apologize for, correct, then revert right back to on the next run, haha.
    Sent from my iPhone using Tapatalk Pro
    The only functional problem I've had with two Transition bikes was a broken brake tab on the rear triangle, which they replaced the day I notified them.
    The finish, though, sucks on all of them. It's very fragile, chips easily, and scratches easily. My Patrol Carbon got 3 or 4 chips on the first ride, big ones too. I've ridden other bikes in the same areas multiple times and not had a single riding induced chip. It seems like you could look at them wrong and the paint comes off.
    Sep 2004
    not much of an update from Transition, just pretty much advised to suck it & see. If it get's ridiculously bad I will be back in touch with them but I was very disappointed in all honesty especially as I havent even rode it yet.
    Reputation: Macharza's Avatar
    Jun 2013
    I put 3M armour tape almost to the every place
    Apr 2015
    To be honest it doesn't look that bad or at least bad enough to require a warranty replacement but for sure it is really disappointing.
    I don't know what other companies would do but I know that Trek for example have replaced some frames but it was about paint bubbling rather than paint chips.
    Since I am highly interested in the 2018 Patrol can you post some photos to see how the bike looks in that color and also some first impressions.
    Sep 2004
    will post some ride impressions & pics when fully built up.
    My Sentinel is losing a bit of paint forward of the chain guard from a bit of slap after a couple of rides. Other than that no different than my Smuggler or past Konas. I'm fully expecting some chipping. But I give the the bikes a good thrashing on the North Shore in terrible conditions (for paint). So meh for me. Anyway the most durable paint I recall was my Nomad 3 which looked like bloody gel coat. However, as it aged and flexed guess what? It **looked** like it had cracks everywhere!
    How's the paint on the pivot where the gear cable rubs? The Sentinel in the PB review had rub marks there already.
    Mine has no rubbing there. I don't even see how the cable could rub because it's pretty well fixed in place. Maybe that was some sort or prototype thing that got fixed?
    Feb 2006
    For what its worth, my 2010 TransAm's paintjob is awful. I've but in quite a few years of use on it... but it really seems to chip extremely easy. I have a 2017 Patrol that I'm keeping an eye on, it doesn't seem as bad so far...
    Sep 2004
    quick update, transition have agreed to change the rocker & chainstay. top customer service on their part I would say. I await the parts arriving. all fully built up now so will post a pic. still not ridden in anger yet tho
  1. Replies: 34
    Last Post: 4 Days Ago, 05:38 PM
  2. Replies: 60
    Last Post: 02-02-2013, 01:05 AM
  3. Need a job? The Job Board
    By fatcat in forum California - Socal
    Last Post: 12-23-2011, 02:04 AM
  4. Custom paint job
    By Muttonchops in forum Knolly
    Last Post: 03-30-2011, 02:27 PM
  5. Cost & Recommendation for a custom paint job
    By JimmyNeutron10101 in forum Bike and Frame discussion
    Last Post: 01-15-2011, 04:26 PM
Members who have read this thread: 183
