Official TR450 Thread!
Printable View
  • 09-25-2012
    Rican0624
    What are you guys setting your suspension at?
  • 09-30-2012
    toodles
    Just setting up my new TR450 now. I'm at 87kg/192lbs and I'm deciding between a 400lb spring with 180psi in the RC4 and a 450lb running about 150psi. The softer spring feels super supple, but the bike wallows a bit in hard g-out corners. Could probably correct with more LSC but need more time to sort it out. The harder spring feels good for corners and jumps but doesn't track as well. Guess just more experimentation is needed.
  • 10-03-2012
    jasevr4
    Don't you blow through travel super fast on a 450lb spring? I'm 71kg/156lb with helmet, clothed, pack, etc and run a 400lb spring. Granted I reckon a 375lb would be closer to what I need, but at 87kg I would have thought you'd be bottoming it all day long?
  • 10-03-2012
    toodles
    Weird thing is, I'm back running the 400 again at the moment. Gets the right sag and lets the HSC do its work. How much sag are you getting on a 400 if you're only 71kg?
  • 10-03-2012
    Will Murderface
    I weigh the exact same as you do, and eventually went with the 450lb spring and 150 psi, and I prefer it because it seemed a little wallowly in the mid-stroke with the 400lb. I'm getting ~33% sag with only a few turns of preload, which is generally my preference - versus a ton of preload. Seems to have more pop and I can still man-smash it through the chunder. All that said, given that the RC4 seems like a "progressive" shock (i.e. I have the bottom out adjustment all the way out), I've been thinking real hard about a CCDB.
  • 10-03-2012
    bitewerks
    Here's a link to an article that has a couple photos of a rode-hard-and-hung-up-wet TR450 with worn away Transition stickers. Pretty awesome.
    North America's Highest Descent? - Pinkbike
  • 10-03-2012
    toodles
    Yep, I've been trying the 450 with about 150psi in the reservoir as well. I'm back on the 400 running 180psi, but I increased the HSC to about 9 clicks out of 12 which stops the bike "wallowing" in corners as much. I'll do some back-to-back runs with both setups and decide which works best I think. Just waiting till I'm out at a track that provides a bit of everything so I can try it out. The spring calculators on the web all provide different recommendations.
    Mojo - 426
    Fox - 350
    TF Tuned - 360 - 380
  • 10-28-2012
    fuenstock
    Can someone tell me what the diffrence between the v2.5 and v3 tr450 frame is? Great looking bikes..
  • 11-15-2012
    paraskevas
    3 Attachment(s)
    my gun
    true dirt weapon
  • 11-15-2012
    8664
    very nice!
  • 11-29-2012
    Karve
    To add to this can anyone outline the upgrades from 1 to 2 and from 2 to 3? Any help appreciated dudes.
  • 12-01-2012
    toodles
    I might be wrong but - I think from 1 to 2 they got lighter, 2 to 2.5 the got new HT (?), 2 to 3 they got CS adjustability & 0.25" longer front end. In 2013 they get Enduro Max-E bearings and different HT bearing spec
  • 12-05-2012
    dfinn
    My TR450 made it through ~30 days in the whistler bike park without needing any maintenance at all (to the frame itself, wheels and drivetrain are a different story). I was pretty psyched on the abuse this bike took and it just kept coming back and asking for more.
    https://vimeo.com/53196337
  • 12-21-2012
    Villas
    my new TR450 for 2013... wow im in love !!!!
    more pics here: 2013 Transition TR450 - Villas's Bike Check - Vital MTB
  • 12-26-2012
    graviT_railer
    Sweet rig fella :thumbsup:
    Did you go for build option two and just swap out the build option bars and shock for the CCDB and Renthals at extra cost or was it a complete frame up build?
    I ask because most of your spec is per the build two option.
    Sorry if it seems like a dumd a** question, but I'm currently in the process of researching all DH bike options.
  • 01-30-2013
    fuenstock
    Built this up today. Excited to put it to good use!
  • 01-31-2013
    rideut
    Nice! What brand rear fender is that?
  • 01-31-2013
    fuenstock
    I bought a cheap $10 fender and trimmed it myself to fit the tr450.
  • 03-02-2013
    Will Murderface
    My 2010 machine :
  • 03-09-2013
    aedubber
    I think I might be joining the club with a 2013 frame guys. Going to build it ground up. Very nice looking sleds on here ! ... how is that CCDB holding up? Im assuming its not a problem to run one on these frames?
  • 04-10-2013
    Mud Pig
    Here's my TR450
  • 04-10-2013
    eurospek
    Sweet TR450 replica.
  • 04-15-2013
    9nine9
    Attachment 790962Attachment 790961
    My 2013- just put it together last nite....
  • 07-28-2013
    Jackmerius
    Hey Transition folks,
    Do the new TR450s come with a replaceable dropout, or do you know if they will fit a 650b wheel?
    I emailed them, and am waiting to hear back, and I can't tell from all the photos I've seen about the rear dropouts.
  • 07-28-2013
    potterymouth
    BTW, The guys over at Airborne seem a bit defensive when one mentions that their new bike looks like a TR 450.
  • 07-29-2013
    Kerberos
    Check this thread/posting: http://forums.mtbr.com/transition-bi...l#post10543578
  • 07-29-2013
    Jackmerius
    Originally Posted by Kerberos View Post
    Ah Ha.
  • 07-30-2013
    jasevr4
  • 08-14-2013
    Kerberos
    Recently on Rothorn, Lenzerheide, Switzerland:
    <a href="http://fotos.mtb-news.de/p/1443818" title="lenzerheide 20130801 I"><img src="http://fstatic2.mtb-news.de/f/p1/3n/p13no7n70s6z/large_lenzerheide_010813_043_Marcus1.jpg?0" class="fotoalbumLikeable" data-photo-id="1443818" /></a>
    <a href="http://fotos.mtb-news.de/p/1443824" title="lenzerheide 20130801 IV"><img src="http://fstatic0.mtb-news.de/f/6b/fv/6bfvy0zi4kzc/medium_DSC_0677.jpg?1" class="fotoalbumLikeable" data-photo-id="1443824" /></a>
  • 02-19-2014
    Dakay
  • 02-19-2014
    Will Murderface
    Love the color.
  • 02-24-2014
    tsefreeflow
    Hey guys quick question, I got TBC Revolution 32 150 Wheels and I want to go tubeless like all my Speshy bikes. I have been searching but there are a ton of discussions of downhilling on tubeless but not specifically the Revolution wheelset. This is on a 2013 TR450 1 that is getting a new set of the build 2 wheelset. Will tape and stan's on Speshy Butcher DH Tires be fine or do I need the rim strips, or just go friggin tubes lol? also I am assuming a Butcher 2.5 tire will work front and back on this bike correct? Any experience with any of this out there?
  • 03-13-2014
    tsefreeflow
    Nothing special (well to me she is ha :thumbsup:), just figured I would share:
    Attachment 876661
  • 03-14-2014
    paraskevas
