Page 17 of 18 FirstFirst ... 7 13 14 15 16 17 18 LastLast
Results 401 to 425 of 434
  1. #401
    What are you guys setting your suspension at?
  2. #402
    Just setting up my new TR450 now. I'm at 87kg/192lbs and I'm deciding between a 400lb spring with 180psi in the RC4 and a 450lb running about 150psi. The softer spring feels super supple, but the bike wallows a bit in hard g-out corners. Could probably correct with more LSC but need more time to sort it out. The harder spring feels good for corners and jumps but doesn't track as well. Guess just more experimentation is needed.
  3. #403
    lives to ride
    Feb 2005
    Quote Originally Posted by toodles View Post
    Don't you blow through travel super fast on a 450lb spring? I'm 71kg/156lb with helmet, clothed, pack, etc and run a 400lb spring. Granted I reckon a 375lb would be closer to what I need, but at 87kg I would have thought you'd be bottoming it all day long?
  4. #404
    Weird thing is, I'm back running the 400 again at the moment. Gets the right sag and lets the HSC do its work. How much sag are you getting on a 400 if you're only 71kg?
  5. #405
    Nov 2008
    I weigh the exact same as you do, and eventually went with the 450lb spring and 150 psi, and I prefer it because it seemed a little wallowly in the mid-stroke with the 400lb. I'm getting ~33% sag with only a few turns of preload, which is generally my preference - versus a ton of preload. Seems to have more pop and I can still man-smash it through the chunder. All that said, given that the RC4 seems like a "progressive" shock (i.e. I have the bottom out adjustment all the way out), I've been thinking real hard about a CCDB.
  6. #406
    Here's a link to an article that has a couple photos of a rode-hard-and-hung-up-wet TR450 with worn away Transition stickers. Pretty awesome.
    North America's Highest Descent? - Pinkbike
  7. #407
    Quote Originally Posted by Will Murderface View Post
    Yep, I've been trying the 450 with about 150psi in the reservoir as well. I'm back on the 400 running 180psi, but I increased the HSC to about 9 clicks out of 12 which stops the bike "wallowing" in corners as much. I'll do some back-to-back runs with both setups and decide which works best I think. Just waiting till I'm out at a track that provides a bit of everything so I can try it out. The spring calculators on the web all provide different recommendations.
    Mojo - 426
    Fox - 350
    TF Tuned - 360 - 380
  8. #408
    Lightly salted
    Reputation: fuenstock's Avatar
    Can someone tell me what the diffrence between the v2.5 and v3 tr450 frame is? Great looking bikes..
  9. #409
    Good job! my gun
    true dirt weapon
  10. #410
    very nice!
    ride.
  11. #411
    Reputation: Karve's Avatar
    Mar 2006
    Quote Originally Posted by fuenstock View Post
    To add to this can anyone outline the upgrades from 1 to 2 and from 2 to 3? Any help appreciated dudes.
    www.essexhertsmtb.co.uk - Mountain Biking near London in the UK
  12. #412
    I might be wrong but - I think from 1 to 2 they got lighter, 2 to 2.5 the got new HT (?), 2 to 3 they got CS adjustability & 0.25" longer front end. In 2013 they get Enduro Max-E bearings and different HT bearing spec
  13. #413
    My TR450 made it through ~30 days in the whistler bike park without needing any maintenance at all (to the frame itself, wheels and drivetrain are a different story). I was pretty psyched on the abuse this bike took and it just kept coming back and asking for more.
  14. #414
    my new TR450 for 2013... wow im in love !!!!
    more pics here: 2013 Transition TR450 - Villas's Bike Check - Vital MTB
  15. #415
    Reputation: graviT_railer's Avatar
    Dec 2012
    Sweet rig fella
    Did you go for build option two and just swap out the build option bars and shock for the CCDB and Renthals at extra cost or was it a complete frame up build?
    I ask because most of your spec is per the build two option.
    Sorry if it seems like a dumd a** question, but I'm currently in the process of researching all DH bike options.
  16. #416
    Lightly salted
    Built this up today. Excited to put it to good use!
  17. #417
    Reputation: rideut's Avatar
    Dec 2008
    Nice! What brand rear fender is that?
  18. #418
    Lightly salted
    Quote Originally Posted by rideut View Post
    I bought a cheap $10 fender and trimmed it myself to fit the tr450.
  19. #419
    Nov 2008
    My 2010 machine :
  20. #420
    RideDirt
    Reputation: aedubber's Avatar
    I think I might be joining the club with a 2013 frame guys. Going to build it ground up. Very nice looking sleds on here ! ... how is that CCDB holding up? Im assuming its not a problem to run one on these frames?
  21. #421
    Reputation: Mud Pig's Avatar
    Here's my TR450
  22. #422
    Reputation: eurospek's Avatar
    Sweet TR450 replica.
    konahonzo
  23. #423
    Feb 2007
    Official TR450 Thread!-2013-tr450-001.jpgOfficial TR450 Thread!-2013-tr450-004.jpg
    My 2013- just put it together last nite....
  24. #424
    Jul 2013
    Hey Transition folks,
    Do the new TR450s come with a replaceable dropout, or do you know if they will fit a 650b wheel?
    I emailed them, and am waiting to hear back, and I can't tell from all the photos I've seen about the rear dropouts.
    BTW, The guys over at Airborne seem a bit defensive when one mentions that their new bike looks like a TR 450.
