Results 1 to 7 of 7
    Feb 2016
    Newb here building up a Scout, have some stupid & trivial questions
    Nabbed a Blue/Black Scout frame off pinkbike, super excited! It is in the mail now and I am starting to look at components. I have never built up a bike before so have some questions.
    -What specifications do I need to look for when ordering a fork? I want a 150mm Pike RCT3 solo air to start with and may change to 140mm later. What matters when looking at those as far as offset, steer tube, etc. Would this one work? 2015 Rock Shox Pike RCT3 Soloair 150 Black Taper 15mm 27 5 650B Fork | eBay
    -For the dropper post, I know I need a ~31.6, and being 5'8 on a medium I am guessing 125mm. What is this other measurement I am seeing? the total length? What will fit on the scout?
    Also, I am guessing the seatclamps are sold in actual size right? As in, the scout uses 34.9 clamp for the 31.6 post.
    Lastly, what products/companies have you seen personally that closely match the same cyan blue the scout has? For instance I am looking at these 2 seatpost clamps and not sure which will be closer in person,
    Anyone have experience or other recommendations? Also for blue grips, thoughts on ODI's light blue?
    Thanks in advance
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    The medium only has 419mm of seat tube so a 150mm dropper may work. My 150mm KS Integra is about 200mm from the collar to the top of the saddle rails. My 150 Reverb is about 215mm. I believe that 42mm is the standard offset for 27.5 Pikes.
    I got some bad ideas in my head.
    Yes that fork will work. Tapered steer tube is what you need.
    I had a Rockshox Reverb Stealth 125mm on my large Scout and at 5'11" could have gone with the 150mm easily. So something in the 125mm range would probably be good. When you see 125mm or 150mm that's how much the post drops, not overal length. The total length can be in the 380mm to 420mm range. You'll have to choose what brand dropper you want, and if you want internal or external routing.
    Seat clamp looks like you have it figured out.
    It will be hard to match the blue completely, but most blue is close enough. This was mine before I sold it.
    Such a fun bike......enjoy!
    Newb here building up a Scout, have some stupid & trivial questions-image.jpg
    Feb 2016
    Nice looking bike! Thank you both for the advice. I think I'll go with a 150mm KS Lev Integra then. Appreciate it guys!
    Feb 2016
    One more thing, I am ordering XT brakes off CRC for a scout. What are brake "spares" and do I need them? Options are "Mount adapter Front Post to IS", "Front Post to Post", and Rear Post to IS". Also, do I have to buy Pads or cables or hoses? Or is that included with the calipers?
    Quote Originally Posted by BobbyLight350z View Post
    Rear brake is 160mm Post Mount. You need post to post.
    Newb here building up a Scout, have some stupid & trivial questions-br268k00.jpg
    If you got that Pike you were talking about it will look the same.
    You just have to make sure you pic the right size for the rotors you will be running.
    The attached images are for 180 rotors.
    Feb 2016
    Super reply, many thanks!
  1. Scout general questions.
    By brent701 in forum Transition Bikes
    Last Post: 06-15-2015, 06:18 PM
  2. Is it worth building a Raleigh Mtn Scout
    By Fargo1 in forum Families and Riding with Kids
    Last Post: 04-13-2015, 08:44 AM
  3. Stupid questions about stupid expensive bike
    By D_K in forum Beginner's Corner
    Last Post: 06-10-2013, 08:19 PM
  4. Newb building an EMD9
    By JookupVandetti in forum 29er Bikes
    Last Post: 05-03-2011, 02:22 PM
  5. Stupid Newb Tubeless Question
    By Chase1996 in forum Wheels and Tires
    Last Post: 03-25-2011, 10:51 AM
