Nabbed a Blue/Black Scout frame off pinkbike, super excited! It is in the mail now and I am starting to look at components. I have never built up a bike before so have some questions.
-What specifications do I need to look for when ordering a fork? I want a 150mm Pike RCT3 solo air to start with and may change to 140mm later. What matters when looking at those as far as offset, steer tube, etc. Would this one work? 2015 Rock Shox Pike RCT3 Soloair 150 Black Taper 15mm 27 5 650B Fork | eBay
-For the dropper post, I know I need a ~31.6, and being 5'8 on a medium I am guessing 125mm. What is this other measurement I am seeing? the total length? What will fit on the scout?
Also, I am guessing the seatclamps are sold in actual size right? As in, the scout uses 34.9 clamp for the 31.6 post.
Lastly, what products/companies have you seen personally that closely match the same cyan blue the scout has? For instance I am looking at these 2 seatpost clamps and not sure which will be closer in person,
Anyone have experience or other recommendations? Also for blue grips, thoughts on ODI's light blue?
Thanks in advance
Thanks in advance
