Hey, I was looking at buying a Transition Trans Am. Not sure on the year of the frame but here are the specs.
2011 Medium Frame in Red
Front-Sun Rim Jumping Flea with 20 mm thru axle
Kenda Nevegal Tires
Rock Shox Lyric w/solo air(170mm shox and I had them put a 10mm spacer to lower it.)
Haynes Stoker Disk Brakes
180mm rotor in front 150mm in rear
Truvativ Stem(60mm with 5 degree)
Truvativ GXP crank
Specialized handle Bars(not sure on rise)
SRAM X7 Derailleur/shifter
Raceface Evolve Seatpost
Scott Seat
MRP bash Guard
Bontrager Duster Rear Rim
SRAM GXP bottom Bracket
34 tooth front Gear
How much would you give for the bike? Any opinions on it would be greatly appreciated and replies are welcome. Thank you for your time.
