Results 1 to 5 of 5
    Reputation: GTIgor's Avatar
    Nov 2007
    misaligned lower shock mounts
    Hello!
    Owner of a Scout for more than a year.
    The bike started squeaking so I decided to service the suspension bearings and pivots. All worked great but during assembling the frame I noticed that the rear shock mounts are milaligned a little - when the shock is fitted to the lower tube of the front triangle it does not fit the upper mount in the link - it is offset to the non-drive side by 1-2mm.
    Not much though but the washer ring which sits on the shock upper bushing has noticable wear on both sides, it is even a bit thinner then the other one.
    Is it a big deal? How does transition react to things like that.
    The suspension works ok, I cannot feel any stiction or resistance but I am afraid there is additional bending stress on the shock and frame possibly.
    I am aware that this as a common thing with bikes but still...
    PS I can post some photos if needed.
    Contact TBC or where you bought frame/bike from, that could be subject for warranty.
    I had the same on a alu 2015 Patrol.
    You will see some shock wear after some time.
    Nov 2007
    Quote Originally Posted by Schreddan View Post
    Already made an inquiry - will see what the response is.
    Shock wear and bending momentum is exactly what bothers me. Did not look inside the shock though...
    Great!
    TBC will work that out fine, I think!
    On my shock I noticed wear and also thin vertical scratches on the damper shaft.
    Similar to these:
    http://forums.mtbr.com/attachments/s...423_182739.jpg
    Reputation: tungsten's Avatar
    Wow. Having some issues with quality control. That should have never left the plant.
  1. IS disc brake mounts vs Post mounts
    By laxdad in forum Fat bikes
    Last Post: 11-15-2016, 07:18 AM
  2. Misaligned rear triangle on '11 Sultan
    By langen in forum Turner
    Last Post: 05-31-2012, 06:31 PM
  3. Misaligned Aluminum Horst Link Frame… how to fix?
    By sealcove in forum Frame Building
    Last Post: 08-27-2011, 08:20 PM
  4. Replies: 6
    Last Post: 04-27-2011, 12:06 AM
  5. Misaligned back end on the Mojo SL
    By mojiks in forum Ibis
    Last Post: 03-24-2011, 04:26 AM
