Results 1 to 20 of 20
    Nov 2007
    Messed up dish on Revolution rims
    A buddy of mine recently purchased a set of Revolution wheels from Transition and when he got them and put the rear one on he noticed it was too far over to the right of the chainstay and not centered like it should be. So, he gets ahold of Mike and he tells him to send the wheel back so he can warranty it. My buddy sends the wheel back and when he gets the new rear wheel, same sh*t. Anybody ever seen this happen from them? I've ordered 3 different Revolution wheelsets from them and never seen this happen before. Not to bash but, Transition was awful slow at the whole communication thing. All in all it took roughly a month between getting the wheelset and sending the back one in and receiving the new one.
    what frame was he installing the wheel on?
    The Dropnzone
    Bellingham,Wa
    www.dropnzone.com
    1-888-95 Pin it
    Nov 2007
    Quote Originally Posted by Chad_Money
    He installed them on a 08 Spesh Big Hit
    I notice you are from Drop N Zone, I have ordered 3 sets of the same rims from you guys without a problem. I love dealing with you guys
    beautiful jackass
    Reputation: one incredible donkey's Avatar
    I didn't have any trouble with mine.
    Nov 2007
    Quote Originally Posted by one incredible donkey
    Like I said, I never have either so I am wondering why he got 2 bad rear ones.
    Reputation: terrible1one3's Avatar
    Nov 2007
    Quote Originally Posted by terrible1one3
    Thanks for that link. I have never heard of that before.
    Np... I randomly went over it a few months ago going through that thread and luckily could find it again when I searched it with google. I am not sure if this applies to you or not but I figured it could possibly help.
    err, 27.5+
    Reputation: AL29er's Avatar
    Quote Originally Posted by BWVDubya
    Yep, frames do sometimes have alignment issues. Usually the original owner doesn't even know as the builder just dished the wheel to line up. Only real issue is that it makes it hard to swap wheels back and forth since they have to be dished for the frame. I had a SC Bullit with a swingarm that required about 5mm of dish to one side.
    Quote Originally Posted by saturnine
    that's the stupidest idea this side of pinkbike.
    Nov 2007
    Quote Originally Posted by AL29er
    Thanks for that tid bit. Learn something new everyday
    Tell your buddy to get a Dirtbag so his wheel will fit
    The Dropnzone
    Bellingham,Wa
    www.dropnzone.com
    1-888-95 Pin it
    Nov 2007
    Lol. That's what I'm sayin. I just ordered my Dirtbag from you guys. Will be here Wednesday
    user-created
    Reputation: singletrack's Avatar
    Just to stir the pot:
    I'm guessing no one actually checked the dish of the wheel, right?
    Even if the dish was off, why wouldn't you just adjust it?
    does the big hit have an asymetrical rear end like the demo 8? If so you always need to dish the wheel to the left. I believe it around 7 or 8 offset but cant remember. Its not the wheels issue, its the frame.
    Nov 2007
    I'm not sure about the rear end. I'm pretty sure it is though
    Reputation: A girl from Seattle's Avatar
    See the following from Leelikesbikes:
    "Specialized has been rocking the asymmetrical rear ends on BigHits, Demo 8s and later P.bikes. Compared with a standard-dish wheel, the stock rims are offset six millimeters to the brake side.
    Advantages:
    - You get a “zero-dish” rear wheel. In a standard wheel, the spokes are shorter on the drive side, which makes an uneven and relatively weak triangle. In a zero-dish wheel, the spokes are the same length on both sides. This creates an even, relatively stronger triangle. Isosceles, baby!
    - The other benefit, according to Dr. Brandon Sloan at Specialized, is a better chain line. The cranks on bigger bikes tend to run wide, so moving the cogset outboard helps the chainline.
    Considerations:
    - You can ride a standard wheel in one of these bikes — they have plenty of tire clearance — but it won’t track directly behind your front wheel. I’ve done this out of temporary laziness; it’s funny how you can get used to anything.
    - If you install a new wheel, definitely re-dish it six millimeters to the brake side."
    Have your buddy take the wheel in with the bike to get it redished, it will only cost around $20 or so. I've done this with 2 Demos with good results.
    "Careful. We don't want to learn from this." -- Calvin & Hobbes
    Nov 2007
    That is great info. Thanks a ton. You all have been most helpful
    6mm is quite a bit of adjustment to dish without relacing half of the wheel. I wouldn't recommend it, your spoke tension will be pretty wacked out.
    user-created
    Quote Originally Posted by NWfreeride
    Yeah, but this is a Specialized. And like all Specialized products it's not important to make it work right, just so long as it won't work at all with anything non-Spec.
