Results 1 to 13 of 13
    Feb 2016
    Joytech Hubs and TRS Rims
    I can't find any information on the Joytech hubs and the E*thirteen TRS Rims. Only info on TRS+ rims. Anyone know anything about these?
    Feb 2010
    Joytech is better known as Novatec.
    ejj
    ejj is offline
    TRS Rims are likely OEM only, kinda like the AR rims vs ARC rims on the Santa Cruz bikes. So, check out the TRS+ rims, and figure these are the same or similar extrusion with cheaper finishing and welding. Just a guess.
    Feb 2010
    Often the OEM rims are pinned or sleeved and not welded.
    Feb 2016
    This is the response from Transition
    The TRS rims are an OEM version of the same rim... same extrusion (which has been updated for 2018) but sleeved joint instead of a welded joint. They are extremely similar rims.
    Novatech/Joytech are the same company. It should be updated to show them as Novatech hubs once the website is launched and they are 10.9 degree engagement from a 5 pawl system with all 5 pawls engaging at once.
    Reputation: noose's Avatar
    What is the inner rim width on the 2018 TRS(+?) equipped bikes?
    2015 Giant Trance 3
    X-Fusion Sweep RL2 160mm fork
    Straitline Defacto pedals
    Renthal Fatbar with TV 40mm stem
    Ergon Grips
    sbd
    sbd is offline
    Quote Originally Posted by noose View Post
    According e13 they are 28mm internal. About 1910 grams or the non OEM version
    Quote Originally Posted by sbd View Post
    Thanks. That's good enough width to try out 2.8 plus tires if I am feeling it down the road. Can never have too much grip!
    2015 Giant Trance 3
    Ergon Grips
    Sep 2017
    I've ordered a new smuggler, and my LBS confirmed that the front would fit a 2.6" and the rear would fit a 2.4". I may go up in width from the stock 2.3". I'm looking forward to the bike.
    Nov 2017
    Resurecting this thread to say that I weighed the wheels that came stock with my GX Patrol and they came up at 2030 grams...
    kgm
    kgm is offline
    I torched 2 of my TRS rims on my 2018 Smuggler in 2 rides. Built up a new wheel but E13 was awesome enough to replace them under warranty with TRS+ rims! Might not be good for rocky terrain but they rode well enough otherwise.
    Sep 2017
    Well thatís a bummer
    kgm
    kgm is offline
    Yeah the sidewall / rim bead is too tall IMO. It dents outwards, but I also ride the smuggler pretty hard for what it is. I replaced it with a Spank 395 575gram rim.
  1. Joytech Hubs
    By anthdan in forum Transition Bikes
    Last Post: 09-11-2017, 12:47 AM
  2. How do i service this pivit/joytech? ss hub?
    By opnykanen in forum Singlespeed
    Last Post: 09-28-2015, 05:18 AM
  3. Converting Joytech QR hubs to Bolt on
    By tdamlo in forum Wheels and Tires
    Last Post: 02-17-2015, 05:24 PM
  4. Quando/Joytech Hubs
    By smccloud in forum Wheels and Tires
    Last Post: 11-19-2014, 12:40 PM
  5. Replacing rear hub bearings (joytech)
    By arisaast in forum Beginner's Corner
    Last Post: 06-27-2013, 01:58 AM
Members who have read this thread: 13
