Results 1 to 9 of 9
    How do i get the most travel out of my covert?
    Just bought a 2013 covert 2. Rode it a few times but it just doesnt feel like im using the 6.5 inches of rear wheel travel it has w the fox shock. Air pressure is set good for my body weight. Am i missing something? Anything else i can do? Any advice covert owners?? Thanks!
    Is the little rubber o-ring indicator hitting the bottom or full travel? thats a pretty easy way to tell if you are using all of your travel. Whether it is functioning well for your riding style, weight, terrain, demands etc are another area
    Want a one of a kind bike? Message me for a one of a kind paint job.
    The internet is a tough place to ride
    Feb 2005
    How much sag are you running on the rear shock. Which position do you run the CTD lever in?
    Running sag at about 25 - 30 %. Tried the CTD lever in both trail and decend and it still just felt stiff. ???
    Reputation: nixgame22's Avatar
    The question is, how much travel "are" you getting? Like Ronny said, how far down the body is your o-ring moving? How many hours do you have on the bike? It might still be in the break-in period. I also wouldn't worry so much about getting full travel, rather how well does the bike ride? I would set the sag at 30-33% and ride.
    Maintain internal heights.
    The O ring is getting very close to the bottom, maybe a cm away or so. Only have about 5 hours on the bike so far, but I didnt know that shock needed a break in period (how many hours of break in? will it produce more travel as it breaks in?)
    the bike rides sweet, just thought it would feel a little more plush! Thnx for the advice!
    Just about all air suspension has some stiction when it is new. Give it some time and it will feel better and you can readjust your settings
    The Dropnzone
    Bellingham,Wa
    www.dropnzone.com
    1-888-95 Pin it
    Let some air out until you are using all your travel, just so you know what that end of the spectrum feels like, then add air back in (if needed) until you get to a ride that you like.
    Bend, OR
    Dec 2004
    I'm in Tahoe too and also on a new-to-me 2011 covert which also feels a bit stiff. I saw a post on here from one of the Transition guys saying that it could be the rebound being set too slow. The suspension will "pack down" over a quick sucession of hits and lose some travel. I have yet to try this because I busied the shit out of my ribs at Squaw yesterday!
  1. 29er Travel vs 26er Travel
    By GnarBrahWyo in forum 29er Bikes
    Last Post: 12-16-2012, 07:31 AM
  2. Convert 2012 REBA from 100mm travel to 80mm travel
    By febikes in forum Shocks and Suspension
    Last Post: 02-03-2012, 10:38 PM
  3. Replies: 6
    Last Post: 09-19-2011, 08:41 AM
  4. Long travel or short travel?
    By Loll in forum 29er Bikes
    Last Post: 08-09-2011, 01:44 PM
  5. Replies: 1
    Last Post: 02-09-2011, 08:14 AM
