• 09-15-2012
    Axe
    Originally Posted by enduro55 View Post
    I just got my new transAM in today and the front derailleur isn't clearing the tire, anyone else had that problem?
    Get the double specific SLX. You are running a bash anyway, right?
  • 09-15-2012
    enduro55
    Yeah, I'm running the bash with the 2x10. My only problem is right now I'm living in New Mexico and none of the bike shops where I'm at carry any 2x10 stuff. What is the "double specific' SLX? Is that different than just the standard SLX? I appreciate the help man
  • 09-17-2012
    Glynis27
    The double specific 9 speed front derailleur is the M665 and M667. The cage is smaller and won't interfere with the frame and tire. I use one myself. No experience with 10 speed, but that part is M675 and M676.
  • 09-18-2012
    marino454
    Does this mean that one would have trouble running a triple in the front on the TransAm?
  • 09-18-2012
    enduro55
    Awesome, thanks for the help
  • 09-18-2012
    eurospek
    A triple? You're on the wrong frame then. :D
  • 09-18-2012
    marino454
    Thanks for the insight bud. Hopefully you can help me with another question I have as well...I'm wondering what would I need to do to swap my old Quadra5 over to my TA?
    This is my first build and I'm still trying to figure out my setup. You've definitely made me feel comfortable asking questions on the forum....
  • 09-18-2012
    eurospek
    I don't even know what that is.
    But the TransAM begs for a 1x9 or 1x10 with bashguard set up. I ran 2x9 on my old TransAM and never really used the big ring. This season I am 1x9 on all my bikes and I'm just lost at why people need 3x9 or even 3x10 for bikes in the All-Mountain segment. 1x9 and 1x10 will be plenty fine.
  • 09-18-2012
    marino454
    It's this hot piece of equipment:
    ...and I was kidding.
    I appreciate your comments. At the end of the day I'm likely going to go 2x10 for this build and if i don't find the big ring necessary, I'll do 1 with a bash.
  • 09-24-2012
    Tints
  • 09-24-2012
    Axe
    Granny is plenty useful on the local fireroad grinds. You know, to get to good runs downhill.
    Big ring is evil and very dangerous for any spirited riding: http://forums.mtbr.com/california-no...ng-641287.html (required viewing if you still run it on your AM bike)
  • 10-13-2012
    5power
    DOpe bike whats the weight? just curious I'm building something similar.
    Originally Posted by mseest View Post
    TransAM 2012 blue
    Fox Float RLC 2011 140mm
    Hope Pro 2 / Mavic 819
    Shimano XTR 970 Cranks
    Thomson seatpost/stem
    Funn DH Bars [760mm]
    Shimano SLX BR-M666 brakes
    Maxxis Ardent
  • 10-16-2012
    eightyfive
    Hi, does the DT swiss RWS x12 thru axle compatible with 2012 TransAM 12x142 dropout?
  • 10-16-2012
    Axe
    AFAIK RWS is X-12 (Syntace) and Trans-AM is e-thru (Shimano).
    I have tried to run 10x135 RWS on my TransAm (pre-12mm), it was a tad short, switched that wheel to 10mm bolt-on.
  • 10-16-2012
    eightyfive
    i see... Thanks for sharing
  • 10-16-2012
    in the trees
    Yes, this is true. Same concept, but slightly different standards (axle interfaces). Choose a Shimano or Transition option and you'll be all set.
  • 11-06-2012
    sroman
    2009 ta
    my beast is now black
  • 11-23-2012
    sraak
    I've had this bike for two years now and I just put some new wheels on it. It's a large, single speed and weighs in at 25.5lbs.
    I love everything about this bike. Though I'm considering putting on a better quality rear cog.
    Stock Parts:
    Large Transam Frame
    Sektor RL Fork
    Elixer CR Brakes
    Torsion Bar
    AKA Stem
    Stylo Crankset
    Upgraded Parts:
    Haven Carbon Seat Post
    Chromag 32T Chainring
    LB Carbon Tubeless Rims (23mm inner width)
    DT 240S Rear Hub 10mm
    Hope Pro Font Hub 20mm
    Mountain King II 2.4 Protection Tires
  • 12-01-2012
    CharacterZero
    Large Frame for sale?
    I've a buddy looking to pick one up.:thumbsup:
  • 12-07-2012
    delihustler
    I have a 2011 TA and would love to know, will a 27.5" wheel fit in the back? I want some new forks for it, which also means a new front wheel at least.
  • 12-07-2012
    Banjopickin
    Thinking about building up a Trans Am SS. I want to run a rigid fork, probably suspension corrected 80mm carbon or steel. Would this work? Seems like most folks' SS's are running 140mm+.
  • 01-13-2013
    malen
    Just finished my TranAM build. only took a year.
  • 01-14-2013
    tangaroo
    Better late than never :thumbsup:
  • 01-14-2013
    RollingRevolution
    Just finished this build. This is my first foray into the Transition brand and I think I am sold. Great bike. Simple. Fun.
    Frame - Transition TransAM Medium Red
    Headset - Transition
    Fork - DT Swiss XMM 150
    Brakes - Shimano XT + Avid G3 180/160
    Handlebar - Syntace Vector 318 Carbon
    Stem - Syntace F109 70mm
    Grips - ODI TLD
    Pedals - Shimano DX
    Chainset - Shimano SLX 32t + BBG Bash
    Rear cog - 16t
    Seat/seatpost - WTB Devo on Thomson
    Wheels - Mavis Crossmax ST
    Tires - Fr: Maxxis ADvantage LUST Rr: High Roller LUST
  • 01-14-2013
    Axe
    Such a solid build and 2.1" tires?
    ...helping you out with posting images.
