Page 30 of 41 FirstFirst ... 20 26 27 28 29 30 31 32 33 34 40 ... LastLast
Results 726 to 750 of 1021
  1. #726
    Dec 2009
    Quote Originally Posted by bad news
    Or spend time riding big bikes, after which the transam at 160mm will feel like an XC rig
    Too right, I'm still digging it at 160mm, got the forks a bit firmer than recommended(less sag) just to keep the the front end up under braking and in the corners(better geometry in my book). It's a bit of a harsher ride but it's a hard tail, what do you expect. The HA at 160 is perfect for lite DH duties, I'm guessing all the crew running their 160mm forks at 150/140mm have to ride up hill too
  2. #727
    Reputation: eurospek's Avatar
    It's just a matter of getting used to all the plushness (steel frame + Fox 36 + big volume tires, low pressures). Season just started and last season all I rode was a 100mm XC hardtail. Give me a break here. I have so much more confidence though on the TransAM. Just point and shoot.
    konahonzo
  3. #728
    Axe
    Axe is offline
    Custom User Title
    Reputation: Axe's Avatar
    Quote Originally Posted by supertucanos
    Ain't that the truth.
  4. #729
    Trans am full saint build...
    Heres a sweet one....
    Attached Thumbnails Attached Thumbnails It has arrived - TransAM (pics)-p1090998.jpg
  5. #730
    Te mortuo heres tibi sim?
    Just a touch early with the timer on some of these today, and one courtesy Mrs. Scrub, before we split off onto different trails. Bent the **** out of my bash ring today. A cheapy/thin BBG unit. time to put the beefier Gamut back on. Oops.
  6. #731
    Once again, beautiful outdoors and trails scrublover. Where is this?
  7. #732
    Quote Originally Posted by horriefic
    Western Connecticut.
  8. #733
    Nice pics scrub.
    konahonzo
  9. #734
    RIP Friendgirl
    Reputation: Bordershy's Avatar
    Wow.Not much room to upgrade that ride.A chainguide would round things out though.
    SPD pedals are an absolute menace to the well-being of the world, and ought be banned immediately.
  10. #735
    Quote Originally Posted by eurospek
    Dropping to 140mm is a last resort lol. I'm lowering the bars 10mm first and trying 160mm again. That might be the deal breaker. If not then 150mm and sticking with it.
    So took a first ride today after dropping the bars 10mm, still have two 5mm spacers under the stem. Still at 160mm travel. And switched back to a 50mm stem as well. And the ride was A LOT better. I liked it a lot.
    But my fun was cut short with a front contaminated brake pad rendering it completely useless, little to no braking power, and since the trails were super wet and muddy, I took it easy.
    Plan on going at it tomorrow as soon as I get new pads from REI in the morning.
    So for now, the fork's staying at 160mm, let me break it in first.
    konahonzo
  11. #736
    The Tyranical Teabagger
    Reputation: cyrjm's Avatar
    Got the last piece of the puzzle this week....Stan's Flow wheelset. I'm going to run the DT Swiss 10mm thru bolt on Stan's 3.30 HD hubs with their 10mm endcaps. Anyone else running this? And if you are do you have any play in the hub? I've tourqued the thru bolt down pretty snug and I'm guessing it's play with Stan's endcaps?
    I like bikes.
    2012 Transition TransAm 29er
    2010 Rigid Salsa Selma SS
    2015 Transition Smuggler
    2015 Cannondale Scalpel
  12. #737
    think
    Glad to hear it. I try not to make **** up
  13. #738
    Reputation: Luigiugueto's Avatar
    Oct 2007
    Has anyone run a different seat collar than the one Transition supplies? Ive been having trouble with mine!! cant seem to find 32.8mm the closest ive found is salsa's 32mm seat collars...
  14. #739
    Quote Originally Posted by Luigiugueto
    DKG makes a 33.0 QR and bolt-on clamp. I had the QR one and it took a lot of clamping force (i.e. digging into the paint) for the seat not to slip. Another member had good experience with the bolt-on version. I'm back to the stocker and will get another one if need be.
    konahonzo
  15. #740
    think
    I'm running a 32mm Salsa clamp. It's a bit tight to install, but it works fine once on and holds the seat in place.
    One thing I would suggest if you go this route is to replace the bolt that connects the lever to the...uhhh...barrel I guess you'd call it. (It's the only bolt on the damn thing, you should be able to figure it out ) Due to the clamp being a bit stretched to fit onto the seat tube, with the stock bolt you will only get a few threads and could strip them.
  16. #741
    Jan 2011
    Hello. From Barcelona (Spain). Here are some pics of my Trans am.
    Attached Thumbnails Attached Thumbnails It has arrived - TransAM (pics)-transition-1.jpg
  17. #742
    Oct 2007
    crappy-phone-pic-teaser of my new headbadge, the thing that sets it apart from the rest :d
    the bike has evolved, currently a 1x9 and waiting on a few parts.. will post pics then!
  18. #743
    Reputation: deadbeat son's Avatar
    Long time no see Euro, sweet bike! Funny running into you here; no photos of it on the Saabaru?
  19. #744
    Quote Originally Posted by deadbeat son
    Hey what's up man. I didn't know you had a TransAM.
    Here's it on the Saabaru.
    konahonzo
  20. #745
    I don't have a TA, my current HT is an old Rock Lobster. I've been thinking of picking one up, but I think I'd prefer a lighter frame set up for a shorter travel fork. Also thinking of adding a Bandit to the stable when they're finally available.
    Nice shot on the 9-2x! Still running the stock 16s?
    Added you to the friends list over on PB too...
  21. #746
    I sure am.
    konahonzo
  22. #747
    Oct 2007
    Dumb post, sorry.. too lazy to look. Thanks Eurospek!
  23. #748
    What was the seat tube and seatcollar size for the transam?? cant seem to remember....
    30.0mm Seatpost/32.8mm Clamp
    konahonzo
  24. #749
    Finally! Finished my TransAm up yesterday and rode it today at our local ( and brand new ) jump line. Specs:
    Sektor Solor Air fork
    Stan's Flow wheels w/hd hubs
    Easton Carbon Haven bars
    Race Face Respond stem
    Race Face grips
    Stolen bar end caps
    SLX brakes with 180 XT Rotors
    SLX rear shifter
    XT Shadow 10 speed rear der.
    XT Cassette
    XT Chain
    Thompson post
    Specialized Phenom saddle
    DT Swiss RWS 10mm thrubolt
    Race Face Respond Crank
    Race Face 1x chainring
    e.13 XCX chain guide
    Look pedals
    I like bikes.
  25. #750
    Loving the red and white scheme.
    konahonzo
