Results 1 to 3 of 3
    Front Derailleur for a Scout?
    Hi,
    I'm about to build up a bike using a new to me 2015 Scout frame. Anyone know what specific front derailleurs work well on a Scout? I've read the website and realize it needs to be a SRAM S3 LDM or Shimano E2 Type, but when I go to order there are still lots of remaining options to choose from.
    I assume its a bottom pull? And, at least for Shimano I need to know whether its top swing, bottom swing, etc.
    I'm using a 2x10 with 38/24 chain rings and X7 2x10 shifters.
    OTE
    Oct 2007
    E-type bottom pull low swing model should be the correct choice. E.g. SLX FD-M675-E2 looks right. Maybe sideswing models would work as well, but cable routing becames excotic.
    Thanks for the info. I found XT of that description which will hopefully do the trick!
  1. Scout front tire wash-out
    By SCbos in forum Transition Bikes
    Last Post: 05-10-2015, 04:38 AM
  2. Replies: 10
    Last Post: 10-16-2013, 06:17 PM
  3. Replies: 1
    Last Post: 07-11-2013, 06:16 PM
  4. 3x9 front derailleur on a 3x8 setup (to solve rockhopper 29 front shift issues)
    By samandkimberly in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-15-2013, 04:37 AM
  5. will 2x10 shimano m980 xtr front shifter work with sram xx front derailleur?
    By gideon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-01-2012, 06:28 AM
