Float 34 RLC or CTD?
Printable View
  • 04-23-2012
    MudBike
    How are you guys liking the Float 34 RLC? I have placed an order for my Bandit 29 and apparently the Black RLC availability is not good. The LBS is recommending waiting for the Float CTD or getting the currently available Talas. It do not want Talas. CTD is suppose to be available next month. I don't have a problem with waiting if it is worth it. Thoughts?
  • 04-23-2012
    CalvinHobbs
    I too am looking for a 140mm 29er fork pretty soon but I'm gonna wait and see what some of our resident mtbr suspension aficionados think of the new forks before I decide. One always hopes that new innovations bring better performance but that isn't always the case.
    But I have a 120mm Talas fork right now so I can ride today (just did actually); if I didn't have a fork I'd buy what is available today instead of waiting a month or more.
    Edit: Oh... I really don't like my talas at all... sticky, not-plush at all, and I never use the travel adjust and this is on a Rip9. With a slacker head angle on the bandit29 I imagine there is even less reason to have travel adjust.
  • 04-24-2012
    Franz
    This is interesting. Apparently the 34's spring rate is revised for '13:
    '...rider and bike manufacturer feedback suggested the previous spring rate was too progressive so the negative spring is now longer and uses a softer spring rate, thus flattening out the curve deeper into the travel for a more coil-like feel while even reducing the initial breakaway force for improved sensitivity.'
    They give a short ride report on the CTD forks, about 2/3 down. Seems like you lose some fine-tunability over the RLC, and the 'climb' mode they found almost redundant, but 'trail' mode they liked a lot:
    FOX 2013: New CTD Damper, 34 Forks And More - BikeRadar
  • 05-01-2012
    MudBike
    Does anyone know when the new forks will be available?
  • 05-01-2012
    LeeL
    Its good but not earth shatteringly solid like I'd have hoped. It would have been nice to see what could have happened if Fox had spec'ed a 20mm axle. Or perhaps Rock Shox will go with 34mm on the Revelation thus beating Fox to the punch.
    The 2012 Fit cartridge is acceptably damped unlike the POS 2011 FIT cartridge that blew through mid-stroke travel
  • 05-01-2012
    eurospek
    A few weeks out as I was told by Transition. They are heavily backordered ATM.
  • 05-02-2012
    Transition Bikes
    The new CTD fork and improved spring curve are well worth a few weeks wait. I have been riding it and the spring curve improvement is huge. Actually using all 140mm is nice!
    CTD damper versus RLC is not a make or break, but the CTD adjustments are more intuitive to use and actual damper performance is equal/better certainly not worse.
  • 06-11-2012
    eurospek
    Any updates/critiques on the new CTD stuff, especially the 34 forks?
    Overall, still unimpressed with the CTD stuff?
    I have a 2012 Talas 34 FIT RLC and debating if I should ditch it completely for a new 2013 CTD Float 34 or just do the Float cartridge replacement at the end of the season on the Talas.
    The reviews I've been reading haven't been great (Bikeradar.com) and others completely the opposite (from you guys).
  • 12-23-2012
    kragu
    Dusting off a slightly buried thread...
    Thoughts on this topic, now that plenty of people have likely ridden both?
    I potentially have the chance to trade my 2013 32 120 CTD for a 2012 34 140 RLC. This is for my 2 month old RIP, which I'm looking to get a bigger fork on.
  • 12-23-2012
    eurospek
    Do it!!!!
  • 12-23-2012
    kragu
    Originally Posted by eurospek View Post
    Do it!!!!
    Tell me why, Euro! Just stiffness and travel outweighing the benefits of CTD? Or is RLC better?
  • 12-23-2012
    eurospek
    Benefits of CTD? All I've read online (from people and website/mag reviews) are nit picks with the CTD. Not one complete review where it said it's blown FIT RLC outta the water.
  • 12-24-2012
    In-Yo-Grill
    My 2013 140 CTD blows my 2012 FIT 140 out of the WATER!
    There, it's been said. Seriously though I'd have to say I don't notice a huge difference yet but don't have enough rides to make a definitive decision.
  • 12-24-2012
    kragu
    Ha! And what'd you do with your 2012?
  • 12-26-2012
    Transition Bikes
    If I had a place to write a review I would say it blows it out of the water. Not as much because of the CTD part, but because of the improved air spring curve. The CTD forks have way more usable travel than the RLC forks.
  • 12-26-2012
    In-Yo-Grill
    It's on my 2011 Stumpy. It's a great shock, don't get me wrong. What I like about the CTD is that it goes through the travel without me noticing. I'll get through a section of ride and see how much travel I've used without feeling it.
