Results 1 to 7 of 7
    Reputation: enduroXtreme's Avatar
    Dec 2009
    float 180 reduced to 160 mm will work on covert?
    hey all,
    just got my 2012 brand new white covert,
    for the build i have a super great deal on a float 180 mm factory!
    if i lower the fork to 160 mm, will it work or fu*k up the handeling?
    Happy trails!
    read online books -Publish and read books online for free with publisheep.com
    Reputation: in the trees's Avatar
    Mar 2005
    According to the Fox Tech drawings for the 180 fork, the A-to-C is 565mm. The fork will slacken the HA a bit and alter the handling accordingly. I think you'll be fine....but what do I know.
    Hell! I have a 565mm A-to-C fork (Vengeance) currently on my Bandit and really like it!
    Dec 2009
    if the a2c is 565 and the float 160s a2c is 545 a 20 mm reduction in travel will give the exact a2c of the float 160?
    btw...i see some covert builds running x-fusion vengence that has the same a2c of the float 180,
    enduroXtreme, if you get this fork - just try it on your covert.
    If you like to play on downhill more than uphill sections, you may actually like it
    I have put Totem (180mm with 565mm a2c) and felt in love with the new geo so much, that I just lowered the Totem to 170mm (565mm) and ordered offset shock mount hardware.
    This bike is sooo much fun
    Dec 2009
    thanks luke thats an interesting covert... but im more of an enduro rider so i try to blast on the uphill as much as the downhill. thats one of the main resons i switched from a nomad to covert.
    in this case, lowering the Fox to 160mm will keep the perfect balance
    Dec 2009
    Anybody else? I want to be sure i wont be doing a mistake...
