Results 1 to 2 of 2
    May 2015
    Drilling Bandit29 frame for Reverb Stealth - Best spot?
    Hey!
    I have seen that some guys drilled their frames to install a Reverb Stealth.
    My Bandit29 frame (2013) wants a Stealth, too, and I am wondering where to drill the frame. Could you please help me with this?
    Do you think the hole for the direct mount front derailleur is a good idea or would it work to use one of the water bottle cage holes at the bottom side of the down tube? I only use the ones on the top side.
    I have seen that there is a manual for Liteville frames, could this work with my Bandit frame, too?
    Thanks a lot for your help!
    Cheers,
    Flummi
    Reputation: targnik's Avatar
    Jan 2014
    Got a Bandit myself, running a non-stealth reverb.
    A mate was thinking of running a stealth dropper on his 2013 Bandit i.e. drilling a hole in it.
    But now he has decided it's not good for the frame.
    He's an engineer & I would have been curious to see the final outcome.
    Sent from my kltedv using Tapatalk
    "Mountain biking: the under-rated and drug-free antidepressant"
  1. Replies: 63
    Last Post: 03-08-2018, 01:33 PM
  2. drilling frame for stealth post
    By boostin in forum Frame Building
    Last Post: 10-08-2015, 08:21 AM
  3. Replies: 68
    Last Post: 09-06-2015, 08:35 AM
  4. Dead spot at the top of a 2 month old Reverb Stealth?
    By freeclimbmtb in forum Components
    Last Post: 08-26-2015, 08:51 AM
  5. Anyone out there drill their frame to use a Reverb Stealth?
    By reformed roadie in forum All Mountain
    Last Post: 01-25-2013, 08:38 AM
