Results 1 to 7 of 7
Thread: Double has play
    Ride Hard. Go Fast.
    Reputation: OldschoolBMXer's Avatar
    Double has play
    Hey double riders. I've had my double just a few months and ride it sparingly but noticed a play has developed somewhere in the rear, either the links (which I've checked and they are tight) or it's the shock (RP2). It's noticeable when i pick the bike up by the seat or rear wheel or the seatpost or by the rear triangle. Has anyone experienced this and know a way to troubleshoot what this is?
    Thanks much.
    JMH
    JMH is offline
    Sugary Exoskeleton
    Reputation: JMH's Avatar
    Feb 2005
    Quote Originally Posted by OldschoolBMXer View Post
    Thanks much.
    If you checked all your pivot points i am going to guess it's your shock mounting hardware? The aluminum spacers and shock bushings are a wear item, they might be tired.
    JMH
    dog
    dog is offline
    sit! stay!
    Reputation: dog's Avatar
    if it ends up being shock bushings.... check these out...
    RWC SHOCK EYE NEEDLE BEARING KITS
    i need to develop my crashing skills...
    Reputation: pebbles's Avatar
    Jan 2009
    I had the same problem. It's the mount bolt on the rocker. Transition says you have to really tighten it. I rounded a couple bolts, and then applied a generous cote of blue loctite. Problem solved. Tr said the little dot of loctite on the bolt isn't enough in some cases.
    rocker bolt 90% of the time, since it doesnt sound like it has been ridden enough for the mounting hardware to be worn...crank it down and you should be golden.
    The Dropnzone
    Bellingham,Wa
    www.dropnzone.com
    1-888-95 Pin it
    Another in agreement - my BR does the same thing, gotta crank that 6mm shock bolt down super tight.
    Jan 2009
    Anybody try those bearings mentioned above? I might give'em a try.
  1. First Build - Double Sled Design - Double XP-G R5 + Regina
    By tv-kid in forum Lights DIY - Do It Yourself
    Last Post: 11-24-2011, 11:16 PM
  2. W.I. Double/double crank. What are your thoughts?
    By photorider in forum Singlespeed
    Last Post: 03-24-2010, 07:34 PM
  3. Going from triple to double chainring? Do I need a new double derailleur?
    By mikerod87 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-24-2010, 01:26 PM
  4. A double/double Singular Hummingbird.
    By ~martini~ in forum Singlespeed
    Last Post: 10-31-2009, 05:10 AM
  5. White Ind double/double cranks
    By lil hillbilly in forum 29er Bikes
    Last Post: 11-06-2005, 05:34 PM
