Results 1 to 9 of 9
    Feb 2005
    Derby Wheels on a Smuggler
    Anyone done it and have any clearance issues with tires on the 35mm derby rim?
    THE RIDESTOKE COLLECTIVE
    https://ridestoke.com
    Feb 2010
    I'm running the roval carbon fatties on my smuggler and clearance is tight, but adequate. Probably worth noting that I'm running a spesh slaughter tire in the rear which probably helps a little bit. I'd say go for it!
    Jun 2010
    Okay, I've got a Patrol (not a Smuggler, but similar family values.. :^)
    I'm using Ibis 741 rims, 41 external and 35 internal. No problems with any tires that i've used for clearance.
    Right now i'm using DHR2 WT in the back, and it's a good fit, good clearance. I've also used the Hans Damff. No problems.
    The wide rims (Derby are very similar to Ibis) are torsionally very good, and quite durable. I have a history of trashing rims at a rate of a couple pair per year, but the Ibis wheels are now over a year old, so i consider them to be pretty tough.
    Feb 2005
    Thanks for the info!
    Nov 2006
    I've been running 35mm ID Nextie carbon rims on my 2015 Smuggler.
    I recently blew up the rear rim and it is being replaced with a narrower 28mm ID rim.
    Because of the limited tire clearance on the 2015 I don't feel a super-wide 35mm rim is the best option on this frame and the tires that tend to fit.
    I'd recommend narrower.. at least on the rear.
    Feb 2005
    Were you getting rub on the chainstays of your 2015 Smuggler? I have the same bike.
    Nov 2006
    Quote Originally Posted by trailbrain View Post
    No.. For me the larger volume tires that work well with the wide rims would rub the seat stay bridge.
    With the tires that fit the smuggler I've found the sidewalls are too exposed.. It's been tire carnage royale.
    Reputation: pcasso87's Avatar
    Oct 2014
    Im running atomik carbon enduro wheels that are 33mm wide and no issues so far on the original 2.3 minions.
    -2016 Santa Cruz Nomad CC
    -2015 Santa Cruz Tallboy 2 CC
    -2016 Transition Smuggler
    -2015 Orbea Avant M20d
    Reputation: mtbiker040's Avatar
    2015 smuggler with 35mm outer / 30mm inner diameter light bicycle rims
    you have to watch the clearance on the rear but a 2.3 EXO DHRII fits but it's tight!
    '15 Transition Smuggler
  1. Smuggler vs Scout? Can I make a smuggler more nimble?
    By BobbyLight350z in forum Transition Bikes
    Last Post: 02-02-2016, 12:24 PM
  2. Derby or ENVE Carbon Wheels
    By sammieandkrisbey in forum Wheels and Tires
    Last Post: 11-14-2015, 03:32 AM
  3. Derby 29+ wheels for sale, for your fatbike.
    By mikesee in forum Fat bikes
    Last Post: 09-01-2015, 09:54 AM
  4. NOX Farlow or Derby DH 29er wheels
    By M320 in forum Clydesdales/Tall Riders
    Last Post: 08-07-2015, 04:50 AM
  5. NOX Farlow or Derby DH 29er wheels
    By M320 in forum Wheels and Tires
    Last Post: 08-06-2015, 04:13 PM
