    Covert sizing help please
    Thinking about getting a 2013 covert. Im about 6 ft 175 lbs. i seem to be right inbetween a medi and a large. Any covert owners have Any advice? Thanks!
    Basura Blanca
    I've not been on the new Covert, but at 6 ft and w/ normal proportions, my sz L 2010 Covert fits me just fine. Compared to every other frame I've owned, Transition frames seemed sized on the small side. I imagine that's due to their intended use, but I can't imagine being on a medium, yet many would recommend that's what you should get. I'm running a 70mm stem and have the saddle slammed nearly as far back on the rails as it will go, and it feels spot on. My $0.02,
    - Joe
    krt
    krt is offline
    I'm just under 6 feet (182mm) tall and I also got a large sized 2013 Covert. I'm running it with a 45mm stem and 750mm bars and the size is fine. I'm a little streched out, but that's fine if you plan on climbing a lot. I'd say go with the large frame.
    Good job!
    [QUOTE=krt;10211458]I'm just under 6 feet (182mm) tall and I also got a large sized 2013 Covert. I'm running it with a 45mm stem and 750mm bars and the size is fine. I'm a little streched out, but that's fine if you plan on climbing a lot. I'd say go with the large frame.[/QUOTE
    Thanks for the replies! Going w the large
  1. Covert Sizing 5'7" ?
    By aroche in forum Transition Bikes
    Last Post: 03-13-2013, 09:04 PM
  2. covert 3 sizing
    By wonny in forum Transition Bikes
    Last Post: 11-03-2012, 08:42 PM
  3. Is the Covert for me?
    By chazreign in forum Transition Bikes
    Last Post: 09-12-2012, 08:01 AM
  4. Covert sizing
    By monkeyninja in forum Transition Bikes
    Last Post: 03-23-2012, 08:06 PM
  5. Covert sizing questions....
    By dhshuttlemonkey in forum Transition Bikes
    Last Post: 04-24-2011, 01:59 PM
