Results 1 to 30 of 30
    Feb 2013
    Carbon Covert Lemon Lime
    Arrived at my local bike shop today after a long wait, should be being built up this week.
    Kit to be fitted:-
    Fox Float 36 160mm forks, Fox CTD 160mm shock.
    Renthal bars, stem, grips and chainring.
    Shimano Saint crankset, RD and shifter, XT brakes, chain and cassette.
    Mavic Crossmax SX wheels.
    Reverb Stealth.
    SDG Bel Air.
    DMR Brendog pedals.
    E13 Lg1+ chain guide.
    More pics to follow...
    Reputation: Fadgadget's Avatar
    Mar 2013
    Lovely piece of kit.
    And so it starts
    Looking forward to seeing some carbon covert pics!
    awesome!
    Feb 2013
    Frame ready for build..
    Unfortunately a problem with my BB30 Saint cranks and PF30 frame means i've got to wait until Tuesday for a new part so only this fat at the moment..
    Hopefully finished pic on Tuesday
    Awesome frame, man. But... Why put so heavy components such as saint on this carbon beauty?
    Nice dude, is yours a sz S or M or L
    Heard there were some issues with the M and had to wait longer for it
    Mine M is arriving in abt 2 weeks time.
    Ordered it since nov last yr!!
    Feb 2013
    @ draculoff, weights not too bad with the Saint and i'm looking at some alternative parts to try over the next few months to compare.
    Lmc78, it's a Large, hooefully have the finished pictures on tuesday.
    Am looking to build it under 27lbs
    Mar 2013
    Hmmm. I struggled to get my bandit down to 28lbs even with crossmax wheels and lightweight finishing kit.
    Well the med is 6.8lbs...with bos idylle 160mm and ccdb air..seems possible
    Will giv final weight once mine is ready
    Feb 2013
    Finished.
    Looking forward to the first proper ride.
    Wow!! looks awesome. Let us know how it rides
    DBY
    DBY is offline
    That Covert is sweet! The white rims, chain guide, two-tone saddle... and of course the white Fox, really make that bike pop. Beautiful.
    GUIDANCE COUNSELOR
    Reputation: NoahColorado's Avatar
    That looks delicious! Well done!
    NOAH SEARS
    MRP - Brand Manager
    Pivot Cycles - Team Rider
    Reputation: eurospek's Avatar
    Looks absolutely lovely. The yellow works with the white. Nice pedals too.
    Weight?
    konahonzo
    Great bike. The yellow is so outstanding
    i think you will be surprised about the weight.
    The frame is much moreheavier than specd.
    L-frame black: 3.4 kg without shock, means 3.7 with the RP23, that's about 0.5 more!
    Even more weight than the Al-frame
    Feb 2013
    Thanks for all the comments, it took a while but i'm really pleased, first proper ride tomorrow.
    Weight is 15kg / 33lb.
    Quote Originally Posted by simonjj View Post
    Dude, that's crazy. My Honzo weighs under 32 lbs, a 29er, steel frame, heavy build spec. Not what I expected at all for carbon fiber.
    konahonzo
    Would transition build a carbon rear tri for the covert?
    That would lighten the frame further....
    Its quite heavy given the current weight when compared to the rest of its peers like nomad c or ibis mojo
    Reputation: rustybkr's Avatar
    Re: Carbon Covert Lemon Lime
    Looks great, screw the weight...
    Apr 2013
    Absolutely stunning.
    I've just picked up my lime covert too and have started the build process.
    Did you have any issue with your rear shock mounting?
    The rear bushing (or whatever fox's new bushing system is called) seems too wide for the rear bolt, consequently there's loads of play. Am I being stupid?
    Any advice?
    Hi. I had an issue with shock mounting. Plastic bushings were sitting too tight in the shock. So axle were not able to rotate free, as it should. I removed bushings from the shock and slightly processed it with the rasp from outside. When reinstalled, axle were rotating smoothly and buttery.
    So I recommend to check this before you ride, because axle may be clamped with bushings and rub the screw, that's incorrect.
    Any update about the feelings when riding this peace of art ???
    Tester of Gravity
    Jun 2012
    Quote Originally Posted by RLL2011 View Post
    +1 - very interested in finding out more about rider experiences on the carbon frame
    Quote Originally Posted by flowbike View Post
    That is about as heavy as the Blindside was. Wow!
    Feb 2013
    Quote Originally Posted by Sanny View Post
    Any advice?
    Yes, there is a small amount of play and have contacted Transition to see what they suggest, i have found a few posts that mention a fix along the lines that draculoff has suggested.
    Ride wise i love it, i did a couple of laps of the Verderers trail ( Route Viewer : Forest of Dean Verderers Trail | JustGoRide ) on Sunday and the Covert felt so much lighter and flickable than my old Jekyll. I still need to spend a bit of time adjusting the suspension but that's all part of the fun.
    Simon
    Apr 2013
    Thanks Simon.
    I've used some shims to take up the play.
    What torque setting did you use?
    Reputation: sfgiantsfan's Avatar
    Dec 2010
    All I can say is.......WOW
    I'm sick of all the Irish stereotypes, as soon as I finish this beer I"m punching someone
  1. ccdb air on carbon covert
    By Lmc78 in forum Transition Bikes
    Last Post: 06-23-2013, 10:02 PM
  2. carbon covert 110
    Last Post: 04-04-2013, 03:52 PM
  3. Carbon Covert Availabilty
    By sofarider1 in forum Transition Bikes
    Last Post: 03-21-2013, 08:43 PM
  4. Carbon Covert...Discuss
    By stunzeed in forum Transition Bikes
    Last Post: 07-04-2012, 10:59 AM
  5. My 2011 Carbon Stumpy EVO HT is a lemon.
    By slyparkrunning in forum Specialized
    Last Post: 06-29-2011, 06:58 AM
