Results 1 to 7 of 7
    Dec 2012
    Carbon Covert BB help / X0 Bb30 cranks
    PLEASE can someone help me out??
    I have a covert carbon coming end of jan which needs a PF30 bottom bracket, Lars at Transition said this:
    "I'm 99% certain that the SRAM XO BB30 and PF30 applications are fully compatible...
    I hope this helps!"
    Appears it needs to be 73mm though!?
    I can't seem to find or buy a 73mm SRAM PF30 bottom bracket anyone out there assist me???
    It's to run X0 cranks BB30 version
    I brought a SRAM PF30 bb but it came and it comes up as 68mm and was OEM (no packet or instructions)
    All the places I look it says ROAD needs to be 68mm MTB needs to be 73mm, problem is none of the shops n sites list a specific 68 or 73!
    Anyone?? A link to one would be nice
    Anyone fitted BB30 X0 cranks to a carbon covert? What BB did u use???
    Cheers guys and gals
    Dom
    Reputation: Xave's Avatar
    Is it not a case of just adding a spacer or 2 that the BB normally comes with?
    It's carbon dontcha know.
    Reputation: 6thElement's Avatar
    The SRAM PFBB30 works with 68 or 73mm. I used one with an X.0 BB30 cranket on my niner. From memory you install the BB, then you use the black 1cm'ish spacer on the driveside of the crank spindle. No other spacers.
    Universal Cycles -- Truvativ PressFit 30 Bottom Brackets
    Rolling on 29", 650b, 8.3" and 23mm
    Is it possible to use the shimano Pf30 bottom bracket with a sram xx1 crankset?
    Jan 2009
    Quote Originally Posted by yoyoz View Post
    Shimano does not directly support PF30 bottom bracket shells. They have their own "BB92" and other width shells which will only work with their cranks. But for Shimano cranks and a PF30 bottom bracket you would need to use one of the many adapters out there. This is an easy solution...
    Wheels Mfg PF30 Adapter For Shimano With PF30 Bottom Bracket - Competitive Cyclist
    Thank you so much!
    And what about Q factor for sram xx1 crankset?
    Which is ok?
Hot Deals
Contests
Latest Mountain Bike Articles
