Results 1 to 2 of 2
    Hard as nails
    Reputation: Dirtman's Avatar
    Bushing swap question...
    I am swapping out a 2006 DHX air for the Rovox pro 2012 on my 06 transition Dirtbag. Does anyone know if I can use the same bushings from the DHX? I believe the Revox pro eyelet diameter is 15mm, and think the Fox DHX air eyelet is the same. I just want to make certain. If I can save some money but using the current bushing, I definitely would like to.
    Attached Thumbnails Attached Thumbnails Bushing swap question...-man2-590x274.jpg
    [SIZE="4"]Thank God men cannot fly, and lay waste the sky as well as the earth.
    Henry David Thoreau[/SIZE]
    http://vimeo.com/6232260
    Hey little late reply but the answer is no, Manitou hardware is smaller in diameter I.D.
    Fox, Progressive, Elka some others use the same hardware, Manitou and Rockshock are specific to each.
    The Dropnzone
    Bellingham,Wa
    www.dropnzone.com
    1-888-95 Pin it
Hot Deals
Contests
Latest Mountain Bike Articles
