Results 1 to 7 of 7
    Bottlerocket Spring Rates
    Just bought an '07 Botttlerocket and my first bike with a coil. Shock is a DHX 5.0 and has a 400 lb spring. I am 185 lbs and thinking I need to bump up the spring rate... recommendations?
    Also thinking I set SAG based on spring rate, prior to fine tuning with air?
    Thanks for the help, much appreciated.
    i'm at the same weight and run a 450lb spring on an 08 BR. Seems pretty good to me. Maybe a little on the firm side.
    yes, sag is based on the spring rate.
    I'm curious though, why do you think it needs to be bumped up.
    -joel
    Thanks for the info Joel. I am getting to much SAG with the 400 and feel like I am trying to compensate with too much air. Plus, I am using most of the travel on smaller drops and jumps.
    Reputation: dklopp's Avatar
    I weigh 160lbs and run a 500lb spring (probably 15% sag for me...definitely not very much). I do like my suspension pretty stiff because a) I ride hard, and b) I love being able to pump through smooth, flowy trails.
    There is generally a very wide tolerance amongst steel springs (I forget what it is exactly, I want to say +/- 25 lbs). In my experience, a 50lb jump doesn't result in enough ride difference to justify it - which might be related to the tolerance issue noted.
    I recommend you bump up 100 lbs. If you decide it is too much, then at least you know what your sweet spot will be.
    Awesome info dk and confirms I need to start with a 500. Where does a guy order springs online?
    Fox Shox Spring Dhx/Van 2.0-2.5 Stroke > Components > Forks > Springs | Jenson USA Online Bike Shop
    I think all BottleRockets use a 7.875x2.25 shock (the new V5 and V6 might be different, but I doubt it). This means you need a 2.25 inch stroke Fox spring (you can go slightly longer as well, but probably no more than a 2.5 in stroke spring).
    The above website says the 500lb Fox will be available on Oct 3.
    You could also try to get a spring from another brand, but I can't guarantee it will fit.
    You Rock! Thanks again for the info and links. A new learning experience for me.
