Results 1 to 3 of 3
    Oct 2014
    Bandit cable routing problem
    Riding my 14 bandit (650b) the other day I noticed that the rear mech cable outer is getting caught by the big ring on my 2x10 set up and has worn through and slightly into the cable.
    There doesn't seem to be an obvious way of stopping it happening.
    at present the cable runs down the down tube, under the bb shell then into the swing arm (but not through the small holes in the swing arm just behind the lower pivot.
    Is that the correct routing? Anyone else had this issue?
    Oct 2013
    Mine runs over the top of the bb into the swing arm. There's a couple holes in the swing arm you could run a zip tie through to suck the cable to the arm if it still is having problems.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    Oct 2014
    Quote Originally Posted by ThisUsernameIsTaken View Post
    Looks like that's sorted it! Thanks
  1. Air 9 carbon 2013 internal cable routing problem
    By RojoRacing53 in forum Niner Bikes
    Last Post: 01-27-2015, 09:56 PM
  2. 2014 Bandit 27.5 - reverb hose routing
    By Schreddan in forum Transition Bikes
    Last Post: 09-10-2014, 07:40 AM
  3. Reverb Cable Routing on 2013 Bandit 29er
    By jared_j in forum Transition Bikes
    Last Post: 09-04-2013, 07:37 AM
  4. Internal cable routing as it relates to cable housing bend?
    By Drew Diller in forum Frame Building
    Last Post: 10-10-2012, 07:44 AM
  5. Scalpel cable routing problem
    By codytaylor in forum Cannondale
    Last Post: 08-28-2012, 08:15 PM
