Results 1 to 5 of 5
    Just Ride!
    Reputation: kustomz's Avatar
    Bandit 29 - SS Compatable?
    I see that the Bandit 29 can swap to a pair of horizontal dropouts and possibly be run single speed? Of course that would depend on how the chain reacts to suspension compression... is that what is referred to as chain growth? Anyway, will it work?
    Reputation: rollertoaster's Avatar
    It will not work. You would need to run a chain tension device like the Paul or Yess.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    Team _________
    Just Ride!
    Not at all or not well? Do you know what the chain growth numbers are?
    Not at all without a chain tensioner. I have a double and even with only 80mm travel it still requires a tensioner.
    Team _________
    Just Ride!
    Ok, thanks for the insight!
  1. Shifter not compatable?
    By ohiogsp in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-22-2013, 07:25 PM
  2. SRAM XX1 freehub compatable
    By global in forum 29er Components
    Last Post: 06-23-2013, 06:04 AM
  3. New 3x Gripshift compatable with 2x setups?
    By rr in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-20-2013, 08:10 AM
  4. 5.10 Minnarr compatable with shimano?
    By AZGroundPound3r in forum Downhill - Freeride
    Last Post: 05-14-2012, 12:08 PM
  5. Are XTR Ext. BB compatable with XT 770 cranks??
    By S-Works in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-13-2011, 09:44 PM
