Bandit 29 crank question
Printable View
  • 12-11-2012
    trailbrain
    How many spacers did you have to use on the drive side for your XT crank and BB to work?
    I tried mine with the 2x10 SRAM rings during the build but even with one spacer on the drive side it was way to close for comfort with the chainstay. I then installed the sram BB and crank with no spacers and that had more space away from the chainstay without any issues.
  • 12-12-2012
    Transition Bikes
    It should be one 2.5mm spacer behind the driveside BB cup.
    Most of the GXP SRAM cranks work backwords... spacers on the non-driveside will change the chainline.
  • 12-12-2012
    trailbrain
    I tried it with one 2.5mm spacer on the drive and the 38t ring does clear the chainstay but it was very close. After my first ride I noticed that the 38t ring must have hit the chainstay on suspension compression or flex as there was a very small notch in the chainstay and I could see there had also been contact with the housing on the rear derailleur cable.
    For comparison I mounted the SRAM crank that came with the build 2 kit has noticably more space from the chainstay.
