    2017 Smuggler - Minimum seatpost insertion??
    Hi, building up a large 2017 Smuggler - 5'11" tall - does anyone know the recommended MINIMUM seat post insertion on these frames?
    I've emailed Transition - just waiting on a reply.
    I know the old role of thumb was to make sure the base of the seat tube extended below the bottom weld of the top tube/seat post junction, but that's not easy with these new dropped top tube frame designs.
    Feb 2010
    Did you get any answer? I'm looking for this information as well
    Transition said;
    You should just follow the minimum insertion line marked on whatever seatpost you have. Usually it is 80mm or sometimes 100mm.
    Cheers,
    TBC
    Feb 2010
    Ok, thank you. Reverb has 80mm minimum insertion depth and at 95mm I should be safe.
  1. LEV DX minimum insertion.
    By HitmenOnlyInc in forum 29er Components
    Last Post: 07-16-2014, 07:36 AM
  2. Seatpost minimum insertion point
    By Paris Galanis in forum Giant
    Last Post: 01-18-2014, 08:46 AM
  3. Minimum insertion for KS Dropzone?
    By fongster in forum General Discussion
    Last Post: 12-05-2012, 01:31 AM
  4. Minimum Seatpost Insertion for ML/FTM
    By MootsRider in forum Titus
    Last Post: 03-19-2011, 08:19 PM
  5. Covert V2 minimum seatpost insertion?
    By Neily03 in forum Transition Bikes
    Last Post: 01-24-2011, 12:47 PM
