Results 1 to 5 of 5
    2017 Carbon Patrol - Reverb stealth install
    Hi!
    Maybe Im missing something but I dont understand how I should be able to route the Reverb-hose from the seat tube side?
    The hole is about 50 cm down and the hole is not much bigger than the hose in diameter.
    Routing from the front and backwards is not possible because the Reverb hose has a pressed socket/clamp(word?) at the post side of the hose for the connectamajig.
    As I wrote, it seems Im missing someting here.. but I dont know what.
    aaarrrggghh!
    Reputation: Ivan the Terrible's Avatar
    Unthread the hose from the remote and thread it down through the seat tube that way. I drilled a small hole in the hose, routed a string through the frame from front to rear, connected the string to the hydraulic hose and then pulled the hydro line through the frame and then reconnected it to the remote on the bar. Hope that helps.
    Yes, that sounds like a good solution!
    Reputation: Calhoun's Avatar
    Nov 2008
    If you haven't already installed the post make use of this guy:
    Should have came with your Reverb.
    Use any hydraulic house and feed it from the head tube to through the frame and out the seat tube. Thread the red barb into that hose and thread the other side of the barb into your Reverb hose (after disconnecting from lever) and pull through.
    "Mi amor Nuevo Mircoles!"
    -cabra cadabra
    As I wrote, Im missing something...
    Of course, I have used it before. Have been away from Reverb for some time, so it seems like I forgot about it.
  1. Replies: 0
    Last Post: 03-25-2016, 06:26 AM
  2. Replies: 0
    Last Post: 11-13-2015, 02:41 PM
  3. 2015 Specialized Carbon Comp & rockshox reverb stealth?
    By helio3 in forum 29er Components
    Last Post: 10-05-2015, 08:29 PM
  4. Reverb Stealth and 7mm x 9mm Carbon Rails?
    By Lu-Max in forum Fat bikes
    Last Post: 08-19-2014, 09:38 AM
  5. super clean nomad carbon with reverb stealth
    By fixtup in forum Santa Cruz
    Last Post: 12-09-2012, 03:52 PM
Members who have read this thread: 8
