Results 1 to 8 of 8
    2013 trans am 29
    Will it be able to run ss
    Reputation: in the trees's Avatar
    Mar 2005
    Looks like you'll just need a set of SS dropouts to run it singlespeed. (Same as it is with the 2012 frame.)
    eci
    Reputation: snowskilz's Avatar
    just need these
    http://transitionbikes.com/Store_Detail.cfm?Token={ts_2012-09-23_19:53:36}-f9e425dd141d4ee3-3E0C1D5C-E857-2B69-835C3AEA8D5E3615&P=2553&o=7
    Cheers guys,when is it out in uk ?
    Anyone know what the new frame weight is
    New weight
    Hopefully it's less than it is now, because if thats the case then I'll have to buy one.
    Reputation: WarPigs's Avatar
    Dec 2005
    any problems if I run the vertical 135mm dropout on the right and horizontal dropout on the left? I'm using Hadley bolt on hub.
    Si Vis Pacem, Para Bellum
    Feb 2012
    my local transition dealer said 2013 colors were going to be orange, green, and white......the white might be cool...not a big fan or orange or green on a bike......would be cool if it was lighter, but something drastically different would have to happen for that
