Results 1 to 3 of 3
    Oct 2007
    2013 Covert shock fouling the frame
    Just wondering if anyone else has had an issue with there shock fouling there seat stay joint weld. My frame came to me via a friend who got it as a warranty replacement for another model so came without a shock and both my 8.5 x 2.5" fox shocks are fouling on the seat stay joint weld, just above the lower shock bolt. There's very little in it maybe a mm or so but its enough to not let me fit the shock. The joint weld is heavy exactly @ that point so im just gonna file it down to allow clearance. Just asking if anyone else has came across this issue
    D
    you will need a replacement seat stay, some had a very large welded area that interferes with the shock, just contact Transition!
    The Dropnzone
    Bellingham,Wa
    www.dropnzone.com
    1-888-95 Pin it
    Oct 2007
    Cheers Chad, il give them a shout
    Fingers crossed
    D
  1. Shock tune 2013 covert ?
    By a2themfk in forum Transition Bikes
    Last Post: 10-23-2013, 10:33 PM
  2. Replies: 0
    Last Post: 04-23-2013, 01:22 PM
  3. 2013 Enduro - coil shock and frame flex?
    By JimEG in forum Specialized
    Last Post: 10-23-2012, 06:03 PM
  4. Covert shock?'s
    By ratty2k in forum Transition Bikes
    Last Post: 06-16-2012, 12:49 PM
  5. Covert mk2 frame - shock tunes
    By Steve.E in forum Transition Bikes
    Last Post: 06-26-2011, 02:59 PM
