Results 1 to 6 of 6
    Mar 2005
    2012 Covert Steerer length
    I'm looking to get a used x-fusion vengeance and was wondering what length steerer I'd need to ensure it has for the Covert.
    Any help would be much appreciated!
    Thanks.
    DBY
    DBY is offline
    Quote Originally Posted by yinyang View Post
    Thanks.
    Headtube length on the small frame is 110mm, medium frame is 125mm, and large frame is 140mm. Zero stack lower headsets are minimal height, but not quite 'zero'. Add in any height for stem spacers you might need and the stack height of the stem.
    Depending on frame size you'd "probably" be safe with a steerer length range of 165-175mm for the small, 180-190mm for the medium, and 195-205 for the large.
    Mar 2005
    Feb 2012
    hello
    I'm interested to buy a covert 2013 frame in L size and i have a problem, the steer lengh of my lyrik is 185mm.
    can it serve me?
    thanks
    DBY
    DBY is offline
    Quote Originally Posted by pernando69 View Post
    hello
    can it serve me?
    thanks
    I *think* it could. You'd need a stem with a short stack height such as a Straitline, Chromag Ranger or similar that is 38mm or less to be on the safe side. Wouldn't be able to use any spacers under the stem most likely, so keep that in mind if it's a concern.
    Feb 2012
    I planned to put a fsa headset of 1 cm and the syntace megaforce(36mm) or funn funduro(30mm)
    140+10+36= 186mm
    140+10+30=180mm
    I think it will serve
  1. Need help with steerer length.
    By sivan.carmi in forum Shocks and Suspension
    Last Post: 10-28-2012, 10:02 AM
  2. 2012 5 Spot Steerer Tube Length
    By Heretic Skeptic in forum Turner
    Last Post: 07-15-2012, 03:26 PM
  3. steerer length for HD
    By brankulo in forum Ibis
    Last Post: 07-28-2011, 04:35 PM
  4. Mach 5.7 steerer length.
    By paddy73 in forum Pivot Cycles
    Last Post: 03-12-2011, 09:02 AM
  5. Steerer Tube Length?
    By pfox90 in forum Beginner's Corner
    Last Post: 01-07-2011, 09:51 PM
