Results 1 to 1 of 1
    2012 Bottlerocket assitance needed
    Hi Guys,
    Im running the 2012 version of bottlerocket.
    Note: bike came build with the rear shock mounted backwards. and at 130mm (guessing) setup.
    Here's my question:
    Lets assume top mount as A, bottom mount as B
    Which mounting is 130 and which is 150?
    Does the inverted shock make a difference if i were to mount it for 150mm travel?
    Here's what actually happened. while trying to set the shock, i mounted it on the top A with shock facing backwards as per original. Shock travel uptill midway. Feels like i bottom it out with the rubber marker max at midway with a thud feeling which i would assume should not.
    when mounted back to B position, the shock is able to travel all the way without any bottom out feeling.
    I would like to have 150mm travel, and ensure that the shock is able to travel to the max.
    If i were to switch the shock around, the piggyback sits a little too close to the bottom tube, is there any issues with that except that i will not be able to adjust the low compression easily?
    Please let me know if you guys need more pictures.
