Results 1 to 6 of 6
    Feb 2010
    2011 Covert with RC4
    I have a 2011 Covert with a DHX RC4. I want to upgrade my spring to a TI spring. I can't find one anywhere that has the same specs as my current spring. I am running a 500 x 2.35, I see TI in 2.30 and in 2.50
    Could I switch to one of those, or do I need a 2.35? Any advice is greatly appreciated. Thanks
    That number is where spring bind occurs according to the manufacturer. The Stroke on the Covert in 2011 is 2.0, so I would not go over the 2.35 you have, but anything in between is fine.
    The Dropnzone
    Bellingham,Wa
    www.dropnzone.com
    1-888-95 Pin it
    Feb 2010
    Thanks Chad. I looked at Kronos and Renton, but still didn't find the right one yet. Do you know of any other companies or if your shop has any in stock? Thanks
    ya man, we have the renton springs. You can run the 2.25 stroke springs on that shock.
    The Dropnzone
    Bellingham,Wa
    www.dropnzone.com
    1-888-95 Pin it
    Feb 2010
    Hey chad, what is the inside diameter of the Renton? The only one I found has a ID of 1.43. I was told it was to big. Is that the same one you guys got? Let me know. Thanks. Appreciate all the help.
    the DHX springs are 1.38, but they do rub on the RC4, the 1.43 is correct, it will be a little big in the spring seat but its normal, once you get some preload on it it wont make any noise.
    CM
    The Dropnzone
    Bellingham,Wa
    www.dropnzone.com
    1-888-95 Pin it
  1. Covert 2012 vs 2011
    By b4 stealth in forum Transition Bikes
    Last Post: 02-23-2012, 02:02 PM
  2. Paid Spam: 2011 Covert frame
    By nixgame22 in forum Transition Bikes
    Last Post: 12-05-2011, 09:40 PM
  3. Replies: 1
    Last Post: 08-22-2011, 08:04 AM
  4. 2011 covert headset confusion!
    By hugh_b in forum Transition Bikes
    Last Post: 06-08-2011, 01:17 AM
  5. Covert 'V2' (2010/2011) - small bumps?
    By Steve.E in forum Transition Bikes
    Last Post: 03-17-2011, 09:32 AM
