2011 Covert with RC4
Printable View
  • 05-30-2013
    808biker
    I have a 2011 Covert with a DHX RC4. I want to upgrade my spring to a TI spring. I can't find one anywhere that has the same specs as my current spring. I am running a 500 x 2.35, I see TI in 2.30 and in 2.50
    Could I switch to one of those, or do I need a 2.35? Any advice is greatly appreciated. Thanks
  • 05-31-2013
    Chad_Money
    That number is where spring bind occurs according to the manufacturer. The Stroke on the Covert in 2011 is 2.0, so I would not go over the 2.35 you have, but anything in between is fine.
  • 05-31-2013
    808biker
    Thanks Chad. I looked at Kronos and Renton, but still didn't find the right one yet. Do you know of any other companies or if your shop has any in stock? Thanks
  • 05-31-2013
    Chad_Money
    ya man, we have the renton springs. You can run the 2.25 stroke springs on that shock.
  • 06-04-2013
    808biker
    Hey chad, what is the inside diameter of the Renton? The only one I found has a ID of 1.43. I was told it was to big. Is that the same one you guys got? Let me know. Thanks. Appreciate all the help.
  • 06-04-2013
    Chad_Money
    the DHX springs are 1.38, but they do rub on the RC4, the 1.43 is correct, it will be a little big in the spring seat but its normal, once you get some preload on it it wont make any noise.
    CM
