Results 1 to 2 of 2
    170mm reverb in Large Smuggler, Patrol Al, Scout Al
    How deep can you insert a 170mm reverb in a Large aluminium Smuggler, Scout, Patrol?
    Can you insert it right up to the collar?
    Transition information on maximum insertion depth indicates it won't but the carbon patrol has the same max insert (210mm) and I have seen 170mm reverbs fully inserted on those 170mm reverb in Large Smuggler, Patrol Al, Scout Al-img_6079-750x486.jpg
    https://www.mtb-mag.com/en/first-loo...patrol-carbon/
    I'd like to know too.
    I have a 150 fox transfer, in a L Scout. doesn't go all the way down, doesn't even use all the available depth. A tape measure down the seat tube goes 20mm further (right down to the pivot) than the seat post, I think the tube gets a bit tight around where the pivot support is welded in. Perhaps it can ground a bit bigger.
  1. Smuggler vs Scout? Can I make a smuggler more nimble?
    By BobbyLight350z in forum Transition Bikes
    Last Post: 02-02-2016, 12:24 PM
  2. Scout/ Smuggler- Orange County,Ca.
    By Chicane32 in forum Transition Bikes
    Last Post: 10-01-2015, 08:56 PM
  3. Can't Decide: Scout or Smuggler
    By MaddSquirrel in forum Transition Bikes
    Last Post: 09-01-2015, 04:07 PM
  4. Ditch my Bronson for a Smuggler or Patrol?
    By gfowkes in forum Transition Bikes
    Last Post: 08-06-2015, 10:54 AM
  5. new scout 2 vs used smuggler 1
    By f0nz0 in forum All Mountain
    Last Post: 06-16-2015, 08:54 AM
