Results 1 to 5 of 5
    Tonic Fall Guy
    »» Help with TransAM headtube
    Hi folks. I have what I believe to be a 2010 TransAM (originally I thought it was an '09, but my model has ISCG05 tabs and I don't think those were out yet, no?). I also have a Bandit and I'd like to know if there's a way for me to run my tapered fork on the Bandit on my TransAM. Here's some pics of the headtube. It's 44mm outside diameter (like Transition says of their new 2012 models) and the inside diameter is just under 1.5". Thanks a lot!
    <a href="http://www.flickr.com/photos/40484320@N05/8223319819/" title="Untitled by crashwins, on Flickr"><img src="http://farm9.staticflickr.com/8486/8223319819_782fa55c74_z.jpg" width="478" height="640" alt="Untitled"></a>
    <a href="http://www.flickr.com/photos/40484320@N05/8223321309/" title="Untitled by crashwins, on Flickr"><img src="http://farm9.staticflickr.com/8339/8223321309_4de754d088_z.jpg" width="478" height="640" alt="Untitled"></a>
    Reputation: in the trees's Avatar
    Mar 2005
    If I remember correctly, ISCG tabs were added after the first batch of frames on the '09s. The 2010s have more "sculpted" ISCG05 tabs that are different than the ones posted.
    As far as running a tapered fork, I do not think that it is possible to do so. Since the frame requires a Campy integrated headset, I don't think that you can to install a lower external cup headset to accommodate the tapered fork's 1.5" diameter. Campy headsets and 1.125" forks are your only choices.
    Reputation: eurospek's Avatar
    Quote Originally Posted by in the trees View Post
    +1 to everything said!
    And good thing it came with the TBC headset, trying to find one in 45/45 Campy style yielded me no results, I could only find 36/45 at the time.
    konahonzo
    Jan 2009
    Quote Originally Posted by eurospek View Post
    There are a million "campy" size integrated headset from BMX companies. That is the main headset used on BMX bikes. It is much less common int he MTB world, but the FSA Impact is pretty readily available. The 36/45 is the "cane creek" size integrated headset and not compatible with those frames.
    And correct... that frame will only work with a 1.125" fork. The newer frames are a 44mm inside diameter, not outside.
    Cheers!
    undercover brother
    Reputation: tangaroo's Avatar
    Quote Originally Posted by Transition Bikes View Post
    Cheers!
    +1 on the FSA Impact. I got mine for about $35 and it works flawlessly. Comes with Cane Creek bearing cups and it's nice not to have to press the headset.
