Results 1 to 37 of 37
    XPost from 29ers: How have 29ers changed trail design?
    Something I've been thinking about as we are closing in on finishing a trail project in my neighborhood...to what degree do you think 29ers have changed expectations for what a good new trail is?
    Down south USA where I live, the flow trail has gained a lot of currency. Undulating, rhythmic, not a lot of stopping and starting or stuttering over tight technical bits. How much is that a function of more folks riding bikes that are more fun when you can keep the speed up?
    Conversely, do you expect more technical features on your trail to make counteract the inherent ease with which the big wheels plow over the chunder?
    What do you think?
    "Bikes aren't fast--people are fast. Bikes are overpriced. It's an important distinction."---BikeSnob NYC
    Unpredictable
    Reputation: Ridnparadise's Avatar
    I've been thinking about this too. Apart from improvements in technology making larger wheels more sturdy without weighing a ton, I actually think the development of contour and flow trails has made 29ers more popular rather than the other way around.
    Heavylegs
    My thinking is some what different in the reguards to in Ohio there seems to be a large push for as many rocks as possible. Riders here seem to want nothing on a trail but rocks. The 29er has much better roll over than a 26er so here it seems to be influencing builders to construct alot of rock gardens.
    memento mori
    I do a bit of trail building and ride 29ers,if anything I've been trying to keep a slightly larger radius in the turns. Fairly rocky where I live so the trails are technical. Rocky-flowy is the goal.
    I don't think you can focus on 29" wheels as a cause of design change but it might be part of a suite of hardware trends that drive what riders ask for. Singlespeed bikes, wider handlebars, STRAVA in addition to 29ers(and more stuff I am sure) have all played a role in what riders ask for. It seems like anything that causes riders to touch brakes will get negative feedback around here. Of course if you build a more open trail that allows riders to keep up speed you will hear some grumbling from riders that say they want more technical difficulties but evidence on the ground suggests they are small in number. If we put in a minor tech feature in the main line it will immediately get either a bypass or modification. If we do an optional line the easier fast route will be heavily used and the tech feature will be overgrown and almost lost in a short time.
    The comment about corner radius gets at what I am talking about. Some of the more established trail on the project we are finishing has some corners which you really have to slow down for/haul the front end around for on a 29er. They have been complained about by our almost universally 29er riding local crew. I just got my 26 inch hard tail back from a long term loan...I'm looking forward to slinging it around theses corners to see the difference.
    As to the point about the larger wheel size being part of a suite of technological features that could be driving trail design....when did we hit the tipping point from designing bikes to accommodate the terrain at hand to sculpting the terrain for the bikes we prefer? I know heavily manicured bike parks are nothing new, but that's still an interesting point.
    In my case I am talking about minimally manipulated, follow the topography Xc trails.
    Off the back...
    Reputation: pinkrobe's Avatar
    With regard to turn radius, most of the trails around here are/were hiking trails, which means they're fairly straight with few tight turns. I have been asked to leave trails very root, but that doesn't seem to be a wheel-specific request. When I build a berm I aim for a larger radius to accommodate longer wheelbases, not specifically bigger wheels.
    @pinkrobeyyc
    #pinkrobeyyc
    trail rat
    Reputation: slocaus's Avatar
    We build 95% multi-use trails, and so far, no horses or hikers have switched to 29ers, so no design changes for us. I guess they are just slow adapters.
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
    Delirious Tuck
    Reputation: thefriar's Avatar
    Note: This is somewhat incendiary in a push to get discourse going. I have been thinking about this all off season, discussed it with shops and other builders, and its seasoned with feedback from newer riders on 29ers.
    I think 29ers (or their riders) have contributed to dumbing down and sanitizing trails. Yes, 29ers like rocks, but anything that requires wheelie, manual, floating the front, step up, will get dumbed down.
    Seriously.
    Since the big brands have shifted to moving 29er and touting the benefits of "smoothing out the trail" I've seen a bunch of technical sections rearranged or sanitized, log overs and rock ups ramped.
    The larger and newer population of 29er riders, not the early adopters, are looking for an edge of some sort. The 29er has been sold to them as that edge,"You'll be faster!" Faster is equated with better, so when that rider feels a bit faster seat of the pants on the 29er, they assume they've ALSO gotten "better." Yet still can't clean the techy section giving them trouble pre-29er. This dings their ego and by their logic since they're now better, the techy section must be impossible therefore there's no reason the challenge shouldn't be removed or made more accessible. I have had this conversation with multiple riders, pre-dominently newer 29er owners, and people I kinda like socially and that come out on build days (so otherwise good peoples).
    As a builder, I now assume that even on challenging trails, the main line has to be a rollable option where momentum alone will cover the up/over. Anything that requires front tire loft or manual/up skill that is on the "A-line" will get ridden around or ramped... thus designing a B/Skill/Feature line to keep flow for the skilled rider gets more challenging (but challenges are why we love building). So I build a dumbed down variation "A" to appease and keep vigil on making sure the TTFs stay as hard as they were built to be (which means isolated vs. trail wide focus).
    In CT, the Wisconsin glacier dropped a ton of rock and glacial erratics and luckily there are still places where its impossible to not progress your skills regardless of wheel size. Some of these parks have natural barriers to entry so to speak, but you'd be surprised at the attempts some folks will go to to make the parks accessible to them. At those parks we can keep things interesting and punish a bad pedal stroke or misplaced line and make it a walk if you miss.
    The false "skill" imbued by the 29er is one of the largest contributors to why we've seen widespread trail sanitzation in CT over the past 3 years or so. Nothing is sacred to these cats except their ego.
    The IMBA folks will say that having more accessible trails is great for our sport, more voices + more hands, etc. I agree, but I think we shouldn't be conveying that every trail needs to be accessible or reverse engineering old good trail (i.e. sustainable shared use), it ends up instilling a false sense of confidence and skill and leads to us fixing things elsewhere.
    Improve your skills, not the trails is my riding crew's motto.
    Note: I ride a 29er SS HT and a 29er Trail/XC bike, and I can do a manual on both bikes.
    Nov 2008
    I don't agree at all. People are lazy and scared of trying anything new. If they wouldn't ride a techy section on a 29er, they weren't gonna ride in on a 26er either.
    trail rat
    It is the massive influx of new riders that cause trails to be sanitized. The sport has been growing every year. The more total new riders we see, the more they will sanitize trails, sad but true.
    saddlemeat
    Reputation: bsieb's Avatar
    Aug 2003
    Re: XPost from 29ers: How have 29ers changed trail design?
    Wow, I have not noticed this 29er dumb down phenomenon. I would assume the opposite since 29ers roll over bigger obstacles with less input. You sure it's not 26ers dumbing down obstacles that aren't affecting the bigger wheels?
    I don't think the difference is enough to affect the lines after observing for several years. Wheelbase varies considerably with both wheel sizes, but I would expect it to be a bigger factor on trail lines than wheel size.
    I ride with the best dogs.
    Off the back...
    700c wheels have caught on big here, but I don't think there has been any impact on trail tech because of it. If anything, I see trails getting gnarlier due to lack of maintenance. Trails that were a little rough with a Mag 21 are now sketch on 5" FS bikes. I'm exaggerating a bit, but I don't see things getting easier.
    @pinkrobeyyc
    #pinkrobeyyc
    Reputation: dirkdaddy's Avatar
    I have to agree with the people about dumbing down the trail. Here in gulf coast we have near zero rocks and flatish terrain, so there are few barriers for those riding trails who have little skills. I grew up mid-atlantic and we had trails with plenty of trees cross the trails to have to cross over with your chainring digging into the tree, rocks, roots and tricky bits.
    A new trail was cut I found out about and tried recently, its nice but even small dia trees that fell across the path were removed, its basically like a narrow dirt sidewalk its very smooth. I was glad my 10 year old daughter with basic skills could ride the whole thing w/o too much effort, but when I contacted the trail steward online, he said that he is a "racer" and prefers flowing smooth trails where speed can be maintained like was described above. He is open to adding technical features and ramps in the future, but wanted to keep it smooth. I noticed a guy last time out there who appeared to be race training like he had a stopwatch on himself and low and behold, he was riding a 29r.
    I had not thought about it but maybe there is something to this theory.
    I am looking to build a trail in a spot I found and just saw this forum and thought I would look around for some pointers.
    Quote Originally Posted by Sasquatch1413 View Post
    Quote Originally Posted by slocaus View Post
    ^^These are the reasons trails get sanitized. Trying to blame it on the diameter of your wheel seems a bit far fetched to me.
    I'm sure there correlation between new riders, "racer" types and 29'r bikes. These are the folks most likly to buy 29'rs and coincidentally the folks most likely to sanitize trails. But to blame the wheel diameter for trail sanitation? Really?
    In regards to 29'r changing trails design... again, really?
    I think it is more of a desire to ride "flow" trails. Lets face it, flow trails are fun and are a fairly new concept to the masses. Here in NY we have plenty of technical knar that is slow going and requires a decent level of skill to clean. I've been riding these type of trails for years and LOVE them. However "flow" trails offer a very different and fun trail experience. There arn't many "flow" trails around my area so when someone is planning a new trail they tend design a "flow" style trail because it's a nice departure from the techy trails we already have.
    Oct 2011
    even before 29'ers came on the scene there were often an A line and a B line. I've never been on a trail day and had folks say we need to widen this turn for the new wheel sizes. etc...
    regarding the jabber about the flow concept taking hold. .yes, over the last few years I have heard and seen a lot of support for creating such...I don't think it's due to 29'er folk newbies or otherwise.
    Good discussion. Keep it informational, don't yell at each other. As with all things Internet, your results may vary.
    The racer culture is huge in my town. That has always led to a preponderance of trail elves cutting roots and the like. Even long before the big wheel craze. Rogue changes to trail aren't what I'm talking about necessarily.
    Little design cues on the front end like turn radius, mentioned above, are more like it. Other examples....when we were building some rolling compressions, we (maybe subconsciously) paid attention to hollowing them out to accommodate the big wheels. There's a downhill section on our trail that, though there is very little pedaling, is kind of a bear on a 29er. All tree slalom, you see. Just feels awkward. Not the way I would have built it, again, with my 29er in mind.
    Rider, Builder, Dreamer
    Reputation: sambs827's Avatar
    Dec 2008
    Quote Originally Posted by GrantB View Post
    In my town the 29er guys all develop low-input rake'n'ride trails (when they do trail work at all) with super tight, twisty turns. These are mostly the older guys in town (45+) who don't push themselves in speed very often. Our younger crew, who ride mostly 26" bikes and do the vast majority of the trail work, are the ones who open things up a bit more. So kinda the opposite of what you'd expect.
    Go ride your bike.
    Delirious Tuck
    I still think the tougher manualing characteristics of the 29'' wheel and bike designs make some of our newer and less skilled brethren and sisters think its not the bike/them, its the trail.
    On new trail builds we really try to get the most flow possible and are in the camp that believes a rock garden can be flowy if its placed appropriately in the trail system (i.e. what's before it or after it and surrounding trail difficulty). Especially if its launch or gappable or you have the power & stall moves spaced to create some rhythm. A good "in" or previous section of trail that appropriately adjusts rider speed/momentum is absolutely critical (i.e. can't have a bomber DH smooth dirt ribbon hit a right turn rock over into an uphill mini trials course).
    Don't really consider wheel size in turning radius or how we actually construct the trail. We have some wicked lil groms on 24'' wheels that can shred the tech too so we just build a trail that will be:
    -sustainable - require minimal tweaks/long-term maintenance and low impact to resource
    -fun & different ride both ways, i.e. flow and challenge and character are similar enough but different enough that it does feel like another trail the opposite directions (no using same line in both directions if there's a rock garden isn't easy to design)
    -appropriate sight lines/minimizes negative user interactions
    -Avoids barberry
    I need skills
    "to what degree do you think 29ers have changed expectations for what a good new trail is?"
    Absolutely zero.
    sambs827, that was an interesting idea.
    Builder of Trails
    Quote Originally Posted by thefriar View Post
    I agree with Sas and Slo. I started riding in 1992 and have seen the dumbing down of trails since then just about everywhere I've ridden. Even with technology making more capable bikes (more gears, quicker & crisper shifting, disc brakes, suspension, geometry, better tires), trails still get dumbed down.
    I've never understood taking something technical and making it easier when there are easier trails to ride. Certainly, it's partially due to an increase in the number of riders and thus the number of riders building or attempting to build their skills and maybe not being satisfied with the progress. I've even seen it on private trail I built with very limited access.
    Potentially, you might be able to chalk up an altered feature to maybe it not being the right feature for the trails speed, but, even then, that's probably a small percentage.
    D
    Reputation: cmc4130's Avatar
    Quote Originally Posted by dburatti View Post
    . . . . . Even with technology making more capable bikes (more gears, quicker & crisper shifting, disc brakes, suspension, geometry, better tires), trails still get dumbed down.
    D
    that is definitely true... but on the flip side, technology has also allowed people to ride way more difficult trails than in the 80's.
    look at Downhill and Freeride. without suspension, they wouldn't be what they are today....
    Builder of Trails
    Quote Originally Posted by cmc4130 View Post
    Oh, for sure. The same technology has allowed riding longer and farther, hucking from higher and higher. I wouldn't attempt a third of the features I know ride using my first bike, a rigid Univega Alpina 5.0.
    D
    Unpredictable
    Here's the photographic evidence. Ashley is a diehard 26 rider (after grudgingly letting go of his 24 passion a bit). This is his first ever ride on a 29er. It was donated by a passing friend and used to test out a bit of trail. Note the clipless pedals and full safety gear. Conclusion - even a 29er rider could have fun here....
    XPost from 29ers: How have 29ers changed trail design?-p1110148.jpg
    Reputation: ABud's Avatar
    Feb 2012
    Dumb Down you can't believe the upheaval on our club website when a rock is out of place. I am in Eastern PA one mountain south of the Appalachian Trail. And I'm talking one rock out of I don't know several hundred thousand baby heads, bricks, and boulders.
    If anything Strava has a bigger impact on dumbing down trails.
    Dec 2008
    Quote Originally Posted by ABud View Post
    ^^This^^ Gawd, I'm glad not many guys in my town use it.
    Go ride your bike.
    Terrain Sculptor
    Reputation: Trail Ninja's Avatar
    I'm building a flow trail specifically designed for 29er's. I moved from this area 2 years ago and at the time I was the only person who rode a 29er. I came back a couple of months ago and I find half the people who ride my trails are on 29er's. And yes, they tweaked the trails to suit their bikes and riding style while I was gone. So, I build for the riders. The trail will be just as much fun (or more) for the people on 26er's. I'm not going to insist on building old school trails when most of the riders are new school riders.
    As far as dumbing down existing trails goes, this has been happening for as long as I've been building (over 45 years). The more new riders you get the greater the odds that someone will be willing to do "a little trail work" to make the trail "more fun/better/easier to ride".
    Quote Originally Posted by Trail Ninja's Son
    You may be happy to hear that my dad has kicked cancer's ass. Now he's looking for whoever sent it.
    Reputation: pascale27's Avatar
    sanitizing of trails has been going on for years. I know at the 2 local trail systems that I help build at, I never here is this too tight for a 29er or that logover is too high for a 29er. I think alot, in our area anyway, has to do with landowner liability. We've had too sanitize some of the bigger wooden features and jumps. BUt again, I've helped layout trails and designed some primarily by myself and really don't think about wheel size when I build
    Salsa Timberjack 27+
    Niner Jet 9
    Misfit diSSent 1x11
    How are you designing differently for 29ers, TrailNinja?
    Reputation: Chalkpaw's Avatar
    Thefriar's response is spot on. The wheel size does not make much difference in trail riding layout as it does say in a bike park setting; a corner/jump made for a 20" wheel vs. a larger wheel/frame size. Out in the forest it doesn't make any difference. There is just the minimum turn radius to consider. What I see is important to a trail's characteristic's is the disruption feedback to the riders experience makes people change what is there in the wheel pathway. In other words, people are seeking out a particular flow to the trail that is an enjoyable ride. When the rocks and roots get in the way, unfortunately they are torn out without thinking about the bigger picture. The old, out of fashion tracks are either modified or abandoned in favor in the current trend of the average trail ride, which is fast, flowy, and race track like. This is viewed as "dumbing down" the trails. One way to slow down the dumbing down factor is to provide a written history of the trails, making a point to leave things alone. Have the local trail advocacy group make a statement. Or do you want the land manager to get involved?
    But on the flip side, the sustainability side of things, many trail issues have to be modified or else the trail turns to dung. In some of the trail maintenance solutions I've had a hand in is to use rocks or logs to funnel most riders into a easy way through option, while keeping the tech factor alive for the A rider, and at the same time provide a way for water to quickly leave the trail.
    There is a big difference between ripping and skidding.
    Jun 2012
    Big wheels are faster on non tech/stranger trails with no tight turns, but who wants to ride that. Really it's all about the operator of the 26er or 29er, your skills is what will pull you thru not the damn bike, when taking about modern trail bikes.
    Ya 29ers have changed trail design for me. I try to build in a way that it is less fun to ride a gravel road bike then if you just rode like a boss on the 26" wheel. Which is done by snappy turns and tight tech.
    Hint for the 29er people, you seat can go down you know.
    It will make you faster over all if drop it hear and there.
    Epic trails get built in the Northwest by epic people!
    Sustainable quality trails please.
    trail rat
    Quote Originally Posted by mtbty View Post
    So - I need to take this off my old Ritchey and put it on my 29er?
    Unpredictable
    This thread is a melting pot for all sorts of trail design options, plus the juicy stuff like 29er hate.
    Trail design should be terrain specific and as already stated in the thread, offer alternate lines where necessary. To confuse poor trail design with a wheel size is not going to help us understand where or whether trailbuilding is progressing with MTB.
    Not sure I think you can compare 20 inch with 29 inch wheels though - any 20 can pump over dramatic drainages that need to be manualed or jumped on bigger wheels. However, if we are talking rock gardens back from the extinct list, then 20's are not going to be making too much of an appearance.
    Just now a lot of our recent work has been smashed by ongoing and heavy rain and riders who cannot stay away. When you are trying to somehow turn old-style trail into something that modern LMs are looking for and something that will last (if ever this rain would stop), things like dumbing down, gravel road etc all get muddled into some emotional mess.
    So what does a 29 rider look for that those with inferiority wheel complex syndromes do not require, or on the other hand, how can you design a trail that just does not welcome 29ers as much as everyone else? Or is this all bull$#it because a great trail welcomes everyone (and never changes and has unlimited volunteers re-buffing it)?
    I am confused
    This more a question of people confusing flow with making trails too easy. In our area it's not a wheel size, some trails have been made easier w go arounds or removing features(unfirtunstely). But we've also added some burly stuff off the beaten path too. Our one local park people riding a variety of bikes on a daily basis. I've seen everything from cyclocross to DH bikes on our trails during the same ride. 29er hate if you must, but this "issue" has been around longer that the wheel side in question.
    Niner Jet 9
    Misfit diSSent 1x11
    saddlemeat
    Aug 2003
    If I were designing a 29er specific trail in my location it would have more and larger obstacles, be half the width, and feature longer steeper climbs.
    since 4/10/2009
    Reputation: Harold's Avatar
    I really don't see how a trail design would be modified to better accommodate 29ers vs 26ers aside from adding a bit to the radii of tight turns. And even then, I haven't actually seen that happen. It seems in practice, a tight turn for a 26er is a tight turn for a 29er.
    I don't link trail sanitization to wheel size. As has been covered already, that issue has been around for as long as there have been riders who stopped to tweak a trail to their preferences.
    I don't link flow trails to wheel size, either. Going fast and carving corners is fun. So are technical trails. If anything, I think aging riders are attracted to flow trails since they don't beat on the body as much, and young riders are attracted to flow trails because of the gravity, opportunity for air, and speed feeds the adrenaline addiction of the younger crowd.
    If there's a flow trail in a system I'm riding, I'll pay it a visit or two, depending how much trail I have to ride to get back to the top. I won't spend all day sessioning the same short section of flow trail, though.
  1. Have 29ers changed trail design?
    By GrantB in forum 29er Bikes
    Last Post: 03-26-2013, 12:05 PM
  2. When MTBR changed the design in January...
    By marpilli in forum Site Feedback/Issues
    Last Post: 03-09-2012, 01:46 PM
  3. thoughts on 29ers? Cannondale Trail SL 29 2 VS TREK Fisher Mamba & others
    By loves2ride in forum Bike and Frame discussion
    Last Post: 07-18-2011, 02:37 PM
  4. Any one riding Laser TCS Trail 29ers?
    By db9 in forum Wheels and Tires
    Last Post: 07-12-2011, 07:30 PM
  5. Magic Gear BanderSSnatch (xpost 29erS)
    By TheSingleGuy in forum Singlespeed
    Last Post: 02-07-2011, 06:00 AM
