Results 1 to 36 of 36
    Reputation: KRob's Avatar
    Tips for building switchbacks on steep sidehills
    I'm all but finished with a five mile trail build. Now we just need to figure out how to get off this ridge. One side is loose, and erosion prone. The other is very steep, without a real obvious flatish landing for a swicthback.
    It is mostly a downhill trail but I've been trying really hard to make everything on the trail rideable going up as well. I need to put one switchback in on the steeper sidehill option but, dang, I've dug quite a abit and still don't see how I can back it climbable. It's got a big enough arc to make it doable (but still a bit scary/dicey) going down without having to do the euro, nose wheelie/tail whip method, but can't figure out how to make it climbable.
    Tips from the pros?
    Isaiah 58:14
    www.stuckinthespokes.com
    Moderator Moderator
    Reputation: Harryman's Avatar
    This is a good place to start.
    https://www.imba.com/blog/mark-eller...ing-switchberm
    On a really steep side slope, you're going to have to excavate and build a substantial platform into the hill, so looking down on it, it's not a V or U shape, but more of an Omega.
    Shaped more like this:
    https://trailism.com/insight/switchb...limbing-turns/
    As you've found out, doing it right takes a lot of effort.
    Jun 2005
    Didn't look at the links above but I have 3 thoughts. First off, never start "Building" until the route is complete. Time is our most valued resource and it's always under-estimated, particularly when hand-benching on steep side-hill.
    Second, even with machines, digging a proper switchback requires a ton of material moved......actually a couple few tons. Some sort of cribbing/retaining will lessen the material needed.
    Third, tight turns can work and flow if you bring the side-hill trail up hill enough to reduce rider speed....or even just give an up-hill section of trail just before the turn.
    Allowing riders to brake on an uphill section of trail, even if it's a short piece, like 10-15 feet, will result in a more natural force vector. It will still feel flowy, press the tires into the tread instead of skipping, skiddering along on a down-slope. Even if the turn is very tight....if you provide an area to decelerate, it will flow. .
    I think many folks think flow trail or flowy trail needs to be fast all the time. Natural slowing and accelerating is a much more interesting experience IMO. Bringing folks uphill when they have a ton of velocity to almost a stop with no braking....then throw in a little low speed tech like a tight, armored through the fall line turn can be awesome. The Flow State is reached by variety and irregularity. Over-stimulation. When velocity slows down...featured and directionally changing tread will keep your brain engaged which is the key to staying in Flow. Like a good tune.....the blur-speed sections will compliment the low-speed noodley, chunky sections.
    $.02
    May 2013
    Maybe some phots of the trail? Is it possible to avoid turns on the steep pitch and post pone them until the terrain flattens or until the terrain favors a climbing turn?
    Jun 2005
    Quote Originally Posted by endo_alley View Post
    Agree with this.....keeping it flowing side hill rides way better....even if you have to deal with stream crossings and such. Assuming this is not possible hence the switch-back.
    May 2013
    Sometimes people make poor layout choices early on in mapping a trail and wind up painting themselves into a corner further down the line. Best to layout an entire trail wisely before moving the first shovel of dirt. And if you have yourself in a bind, explore all easier fixes before putting a switchback or two in on a steep hillside. I truly dislike them.
    Apr 2005
    I wonder what you can do with some wood. Maybe you can build half of the turn onto a wooden platform and build a ramp back down onto the tread.
    May 2013
    Is the turn necessary? Why not cut a bench into the slope and follow the slope all the way along the side of the ridge until you hit less steep ground? That is the proper way to layout a trail.
    Yes, pretty much necessary. If you just keep following the slope down you'll end up in a steep/v-shaped washed out canyon on one side of the ridge and the side hill gets interrupted with some ledges and deeper drainage cuts on the side we're working on.
    We've got the switch back pretty well cut in now. It's very nice going down. We were able to make a pretty good patform/landing zone on the downhill side with a downed tree propped up against a sturdy tree fill in with bigger rocks and mineral based fill dirt. The climbing portion of the turn is still a bit too steep to climb so I'm thinking off angling the exit portion on top more to make the grade more doable. One of the problems we're facing is the dirt is fairly loose so no matter how much we dig out (so far anyway) it still doesn't seem to get down to a really firm rock/mineral base.
    I uploaded some photos although it's hard to get an idea for the steepness of the slope from these images. The vertical drop from the top of the trail to the bottom is 8-10 feet.
    Attached Thumbnails Attached Thumbnails Tips for building switchbacks on steep sidehills-pbsidehill.jpg
    Isaiah 58:14
    Jun 2005
    You're in mineral dirt, it's just dry as moon dust. You need rain then go out and tamp like a mad man. Your vertical back slope is no bueno. You'll generate a good bit of material from cutting that back. Use it to build up the ramp and lower part of the turn so you're gaining vert over a longer piece of trail. Got yourself in a tough spot. That tread will always get chewed up either from #VanLifeBros roosting the tight, steep turn, or from folks climbing up it in light gears. Preemptive surfacing might be a good idea. Something wicked grippy might make it climb better. Got much rock around?
    $.02
    K&K
    Reputation: ki5ka's Avatar
    What Dave says
    WillWorkForTrail
    Jun 2012
    Yep. Like Dave says, clean up that back slope and use the material to build up the low side of the turn. Then either wait for rain or carry a bunch or water in and tamp that down. It's a steep hillside, and if you have to turn across it, it's always going to be challenging. It takes a lot of work to build a good turn on something like that even with a machine. There are a couple of places I've ridden where there are certain turns that you just resign yourself to "I'll try it every time, and maybe I'll make it one day" and it's not because it's a crappy build, it's because it's the only thing you could do on the side of the hill. When you start to run out of options, you're sometimes left with less than idea choices, but if you can put something solid there that will last, it may be the best you can do.
    May 2013
    It looks as if you need to widen the bench along with stabilizing the backslope. When we have built over soil like that, you can easily lose a third or even half your bench over a the first winter as the hillside sloughs into the trail and the soil tries to stabilize. If you can keep both approaches to your turn fairly flat, that will let the riders set up for the turn. Find a lot of big rocks and boulders for the apex and bottom of the berm, it will probably hold up better in the long run. Batter the rock wall so that he rocks roll into the hill. Hammer (shatter) smaller rocks into the gaps. And finally cover the whole thing with mineral soil. That kind of soil may need a lot of grade reversals and nicks to hold up during a monsoon season.
    Reputation: twd953's Avatar
    Quote Originally Posted by DaveVt View Post
    $.02
    This x1000!
    I don't care if it's a machine built flow trail that can be ridden at a 20 mph average or an old school hand built technical trail that is ridden at a 4 mph average, I don't want to be going 20 mph or 4 mph the whole time.
    Despite the type of trail (and I like both) those momentum changes keep it interesting, and if you can use the terrain to achieve those momentum changes without having to use heavy braking, that is by far the best from a rider experience and trail builder's perspective.
    In the KRob's case, using the terrain to scrub the riders speed without heavy braking in what appears to be dry/loose/non-cohesive soils will keep the trail from blowing out so badly under heavy use.
    Also, since it is intended as a two way trail, putting a short bit of "uphill" after the turn (when ridden in the downhill direction) or at least a short bit of flat will give climbing riders a bit of a rest before climbing a switchback that may be a bit too steep.
    You don't need so much elevation change that a downhill rider needs to pedal out of the switchback, but it's amazing what a couple of pedal strokes of rest before grunting up a steep switchback will do on a long climb.
    May 2013
    Yeah Dat.
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    Are there no washes? Those are perfect to build a switchback into because the sides are already angled.
    It did rain the past couple days and I got up there this morning and tamped it down best I could. I also pulled some dirt down from the inside of the turn to the bottom and tamped it down to build up the run up. I see what your saying about the steep climbing section. It's almost impossible to descend it without dragging the rear wheel a bit or climb it without spinning out.
    So when you say the vertical back slope, are you talking about the berm? That dirt is very fine and loose. I can't see how pulling it into the trail will help. I think I need to dig the top part down more and pull that rocky, more mineral based dirt down onto the bottom where it starts to ramp up, no?
    There are rocks about but not big paving type rocks. What about actual pavers like I see at some parks out West here (Northstar and Mammoth)?
    Isaiah 58:14
    Jun 2005
    The back slope is the uphill edge you left when you cut into the slope. In your photo it looks almost vertical. That will not be stable. You should cut it back with your hoe to be slope as shallow an angle as you can, although it will always be pretty steep as the slope you're working on is steep.
    Pavers could work, but also smashed rock will settle in if the rock breaks up enough. It might be a bit loose at first. If you mix dirt into the rock as you smash it it will settle in.
    May 2013
    Are there any local mountain bike clubs or trail advocacy organizations? I think you would be well served by letting someone with trail building experience look at the sight and help you with the difficult sections. Easier to get it right early on than to rehab a bad design later. If you don't yet understand the basic terms of trail building, you need to read up some of the pertinent literature or such as IMBA trail book, or USForest Service handbook better yet take a course from IMBA.
    Jun 2005
    Another option for improving the riding characteristics of an over-tight turn is a very steep berm. Might not be a durable shape for you considering soil type. A steeper berm would allow riders to roll through the turn with more speed, so less braking potentially.
    Be interested to see how the interlocking pavers work. Never done it but have seen photos.
    Reputation: evdog's Avatar
    Quote Originally Posted by KRob View Post
    Pavers would work great to help hold the trail surface in place. With dry, loose dirt you will always have problems with ruts forming and material getting dragged around by tires even if people aren't intentionally dragging their brakes. I'd put the pavers below the corner and right through the switchback turn. I'd put them above it for a ways too, if possible, to prevent braking bumps. This will help with climbing traction too, big time. Of course pavers have to be carried in, so access may determine what distance you're willing to pave. I've seen wooden snow fencing laid down on Navajo Rocks in Moab.
    You mention the section below the switchback being fairly steep. Is there any way to adjust the trail alignment so it climbs up sooner, leaving a more gentle grade into the turn? Ideally when laying out a switchback you want to minimize grades both below it and above it, so when you connect the two with a climbing turn, that turn will have a reasonable grade. A gentler grade above also means riders won't have to break as hard into the turn - even better if you can have a short uphill into it to bleed off some speed, as someone mentioned.
    If pavers don't look like they will work out, I've successfully laid down thick stucco wire over a steeper trail surface to help hold it together. It provides grip when climbing and descending helps prevent ruts from forming. It will be higher maintenance but where I used it, it lasted 4-5 years before needing replacement. In Moab I also noticed with interest that they laid down wooden snow fencing on a section of Navajo Rocks. Seemed to work well there too, although it could be too wide for bench cut singletrack.
    May 2013
    Any rocks set in the tread should be quite large. 175-200 lb minimum and dug in fairly deep.
    Jun 2005
    Disagree. Crushed stone of variable size with dirt mixed in a properly compacted will be stable. Your solution is more ideal, but less versatile as you need large rocks with the right shapes close by.
    May 2013
    The USFS won't let us use anything smaller in the tread. With the exception being a Turnpike filled with crushed rock.
    Jun 2005
    Has nothing to do with what works and what doesn't work. I'll trust my experience over federal guide lines on trail construction.
    Oh, Ok. Actually that vertical back slope on the top of the switchback is nearly solid, somewhat soft limestone rock. It also extends onto the actual trail surface right at the top so it's pretty stable (took quite a bit of pick work to dig that back slope). That also helped me make a small upgrade coming into the turn from the top just before the rock. So that gives you some natural slowing of momentum into the turn going down. Also the turn off the top of the ridge is a ninety degree affair only 30-40 feet before that so that slows thing down too.
    Having the berm fairly built up allows the turn to flow really nice without a ton of speed (5-10 mph) through the switch back and the bermed up landing area up against that tree keeps the visual line back onto the trail below the switchback, preventing folks from overshooting the switchback and ending up rolling head over heals down that steep side hill.
    evdog: The trail just before the switch back when climbing is reasonably flat (maybe 3-5% grade) for a good 20-30ft and allows you to get a pretty good run at the steep switch back. I haven't cleaned it yet going up but if I can incorporate some pavers right on the steepest section and at the bottom I think it would be doable for most folks that would be climbing this trail (no small feat in and of itself) and would hold up much better for the inevitable wheel dragging while descending. Making the switchback going down should be straightforward for any intermediate to advanced rider. It flows nice. Beginners could do it, but would be sketched out by the steepness I imagine.
    Fortunately this is the final switchback near the bottom of the trail so getting pavers up to it shouldn't be too tough. I'll look into that. In fact I'm liking the idea of pavers more as I think about it. That short semi-solid rock section at the top could become a ledge if the part right below it starts washing away with traffic and rain. I'm not sure smaller rocks packed into that section would hold up long in that dirt. It was already full of 1-3" rocks as I was digging it out and they didn't offer much support/resistance. I think packed down with some moisture it would hold for a year or two, but this dirt gets loose pretty quick with much wheel spinning out or sliding.
    Isaiah 58:14
    May 2013
    Switchback? Or climbing turn? The vertical back slope on the inside of the turn looks to be dirt, and not rock. Maybe an optical illusion in the photo. But I would still recommend that a professional walk your trail if possible. Who is the land manager? Maybe they could give input. Or is it private property?
    Yes, more of a climbing turn. And yes the inside of the turn is mostly dirt (and a tree stump).
    And yes, I would love for a professional to walk the trail. This is an approved, flagged trail on FS land that was built 100% by hand with volunteer labor. Mostly me. Unfortunately the land manager knows almost nothing about trail building for mtbs . We did have a professional come out this week to work on some trail planning and routing for our future trail network and he did ride the trail though I wasn't with him and haven't gotten his input on the trail yet. I'm sure he has some suggestions.
    Other than an IMBA trail building weekend I attended several years ago, some reading on the internet, and just riding and studying a bunch of trails in 20 years of mountain biking, my education has been mostly on the job. It's interesting to see how my trail building has developed over the past five summers building this trail from top to bottom and I've learned a lot. However, I'm sure it's going to need some additional work and a few reroutes to bring it up to accepted sustainable standards.
    Isaiah 58:14
    May 2013
    It's great that you are putting such an effort into building the trail. Users of the finished trail will probably never appreciate the man hours and challenges of building the trail. Around where I live, the Forest Service micro manages every aspect of trail placement and trail building practices. Biologists and hydrologists study trail placement too. And would never defer that power to the guys (and girls) swinging a pick and pushing a shovel. So you have a unique situation.
    Thanks. Yes, it's been a labor of love and I have to say a bit of an obsession. My wife considers this trail my mistress, Ha ha. I never thought I would ever get this excited about trail building. Very addictive (and oddly therapeutic). I've close to 1000 hours up there over the past 5 summers.
    We are fortunate (?) to have a lot of latitude with the FS as far as building on this trail and designing and expanding our trail network. We do have a trails advocacy group, The Great Basin Trails Alliance (GBTA) of which I am a board member. We are small and only have a handful of guys and gals that get involved but we have a very good prospect for getting a rather large grant in the next year or two to help fund some new trails so hopefully in the future the building and design will be left to professionals and machines. LOL.
    Isaiah 58:14
    May 2013
    I am sure after you have tackled all the obstacles and thought out all the best solutions you will be one of the experts. I guess my previous points were that once you have a working trail that is pretty much it. You can repair features. But the layout will always remain pretty true to what you have built. So think it out well. When I say get professionals to help, it is not meant to be derogatory remark. We can all learn something from people who have design experience. Sometimes they will see a solution that never crossed your mind. I wish we had more decision making discretion around here. Sometimes the trail builders will have a novel idea. But the people on top already have their minds made up. So we may have to build sections that we really may not have our heart in. But after a few years of riding in, most trails improve.
    Oh, absolutely. Even though I think I have learned a lot over the course of construction, I know experts could give input/solutions that I hadn't even thought of. In fact when we had our professional trail builder/planner come out to get some ideas going for our 5 year trail network plan he wanted to look at some of our older existing network (he used to work as a rec planner here) and I was like, "No, those trails are fine. Let's just build more new ones". but when he presented his plan to us he made some suggestions for our existing network that made a lot of sense and would make the trail way more fun/interesting.
    Isaiah 58:14
    Jun 2005
    The trail building becomes the most rewarding experience, I have found. Once you ride so many trails, you come to realize the trail is the experience, and you can just hope to ride it well enough to really absorb what a trail is offering. Creating that out of natural surroundings, and having it ride as you envisioned, or watching a skilled rider interface with trail you have created, and watching them ride it just as you had imagined is awesome. So hard to build what you see being ridden in your head. Everyone who rides should dig.
    $.02
    Yes, I understand now what you're saying about the vertical backslope and I have been trying to slope those more going forward. Once I finish the trail (I'm nearly at the end) I'll go back and start pulling some material off that back slope just before the turn. Now that the dirt is moist with rain and snow it'll be easier to build up and pack in that ramp up to the turn. Thanks for the suggestion.
    Literally six feet to go after this morning's dig.....then I can go back and start fixing some of my early learning mistakes.
    Isaiah 58:14
    Reputation: prooperator's Avatar
    Krob,
    I think the best solution would have been a switchback in your case. That climbing turn looks steep from the down hill side. i have build a lot of trail and a switch back would have served you better. The switchback would allow an easier transition because the upper leg and lower leg would be closer to the same elevation. Turn the upper leg into the hillside more and create a pitcher's mound shape and then bring the lower leg in level for 5-10 feet and then let the lower leg tie back into the flag line.
    Too wet to ride!
    May 2015
    How did it turn out? I have seen maybe 2 well built switchbacks in my life. Even the picture in the IMBA Building Better Trails book shows a poorly designed rolling crown switchback. From entry to exit, you have to make certain there is zero change in elevation. Zero. It has to be flat. Also, make it as wide as possible and teardrop shaped. Just because one expert rider on a small framed bike can ride around a switchback without dabbing, does not mean you designed it well.
    Let's say you are climbing up an 8% grade. Bring it to 0% slope and build your switchback. Then maybe 5-10 feet away from the turn, return to an 8% grade. What a good switchback often requires is a massive retaining wall, so it can be wide and flat, to last long and hold up to horses and bikers.
    Here is some pictures of a serpentine trail we built as part of a reroute. It required two switchbacks about forty feet apart. We had to jack-hammer a lot of solid rock to create the wide turn platform, as well as build a serious retaining wall below both switchbacks.
    Just try not to walk away thinking; that's close enough, that's good enough. Keep digging. Be thankful you aren't on top of a rock slab. Just keep making the upper part lower and lower and lower, until it is a perfectly flat platform. It will last for centuries. But also dig back into the hillside until you have a wide turning platform as well. It can never be too wide. A great switchback can take a five person crew a couple days to build, if it is on good soil. If it is on rock, it can take a week or more.
    Post more pictures, Krob.
  1. Replies: 25
    Last Post: 11-19-2014, 05:25 PM
  2. Building corners and switchbacks
    By butryon in forum Trail Building and Advocacy
    Last Post: 11-17-2014, 04:15 AM
  3. Replies: 19
    Last Post: 10-03-2014, 09:01 AM
  4. How steep is too steep?
    By ZXFT in forum Frame Building
    Last Post: 04-21-2011, 07:49 AM
  5. Trail building questions: Switchbacks?
    By edenger in forum Colorado - Front Range
    Last Post: 02-27-2011, 07:47 PM
Members who have read this thread: 29
