Results 1 to 12 of 12
    software to design a bike park
    Can anyone recommend a software program to use to put together a plan for a bike park?
    www.corbamtb.com CORBA-Working for MTB Access in the L.A. area.
    www.otbmbc.com
    Aug 2005
    I use xara xtreme on Ubuntu linux. Also you can use inkscape for a free windows program.
    Builder of Trails
    Reputation: redriderbb's Avatar
    Aug 2005
    I have found sketch up good for creating wooden features, but doesn't work as well for soil-based, organic shapes and forms.
    I think your best bet, honestly, is to work with someone who owns CAD. It seems to do a good job creating overlays for site maps and such. See if your club maybe has an engineer in it or a landscape architect. You can draw things out to scale on graph paper and then pass it on to them.
    CAD is the only thing I have found that works well.
    Reputation: Spindelatron's Avatar
    Use gmap pedometer image of a contour map of the area, stick that image into a word document, then import to autocadLT as an OLE and then scale it. If you can use autocad for a long time then draw up your plans on there.
    If you don't own autocadLT find someone that does and have them print out the image to scale on a 24x36 page, make a couple copies, and go to town with a pencil, french curve, straight edge and an arch. scale.
    You will probably want to do some detailed elevations of TTF, that may/maynot be harder.
    good luck!
    Linerider
    Quote Originally Posted by General Hickey
    Linerider
    El Oh El
    The Voice of Reason
    Reputation: Megashnauzer's Avatar
    how big is your area? i used AutoCAD and the software that came with my GPS but i'm dealing with several hundred acres. if it's small, why not pencil and paper?
    I'm never gonna be a Rock Star
    Thanks for all the feedback!
    I am on a Mac and xara xtreme is not available to Mac users yet. The site says they are working on a Mac version. I downloaded Inkscape but have not messed around with it yet. I did check out sketchup and like the fact that you can use it with google earth. The few proposals I have done so far I have used google earth. Like redrider mentioned it seems like it will be good for drawing up TTF's and maybe a pump track but as far as drawing in trails.. I don't think it will work well or maybe I just have to play with it more?
    I had thought about doing the plans by hand but since they are for proposals I want them to look professional.
    One guy told me he uses a landscape program and illustrator. He did not mention which landcape program he uses?
    Any one using illustrator? I hear it is not an easy program to learn.
    www.otbmbc.com
    Aug 2005
    Illustrator, Xara, Inkscape are all vector drawing programs. Illustrator is the expensive version of the three.
    I would say that all three are around the same difficulty to use. I basically used Xara like a CAD system. I laid out a grid with my paper the size of my park dimensions, then I drew all my jumps, berms etc. to scale, then copied them and placed everything where I wanted.
    For drawing trails I've used a gps and overlayed the recorded GPS track onto a satellite or topo image. I used to have a program that mapped gps coordinates to satellite images download from somewhere other than google, but I fogot the name.
    I'm not a great artist, so I'm sure others can do better, but here's my park map:
    Quote Originally Posted by kevin marley
    Looks good!
    Thanks for the info! I am giving Inkscape a try! I like that it is free! Can't go wrong with that!
    www.otbmbc.com
    caninus xerophilous
    Reputation: SunDog's Avatar
    Topofusion?
    I used to have a program that mapped gps coordinates to satellite images download from somewhere other than google, but I fogot the name.[/IMG]
    BTW: nice work.
